* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#76 _mello92_
_mello92_
Posted 24 August 2013 - 09:57 AM
Wow, that's impressive Heath. Looks cool.
Would you mind explaining what benefits there are in dropping the UCA pivot point please?
#77 76lxhatch
  • 7,205 posts
Posted 24 August 2013 - 10:02 AM
Nice tidy job on the steering column, looks good.
The only thing worth noting for others looking at this is that shortening the column brings the intermediate shaft slightly closer to the engine; its not much but for those with V8s and limited extractor clearance every last thou is important!
#78 Heath
  • 18,385 posts
Posted 24 August 2013 - 10:16 AM
Cheers blokes. Carmelo, PM sent re: where the hell you've been!
Dropping the UCA pivot point instantly gives you more static camber which should be adjusted out, but once you are back to where you where, the lower pivot means you have more camber change upon bump. So when you wrench it into a corner with stiff springs that would otherwise provide less negative camber on the outside, it provides a fraction more, some calculations have been done by other forum members. The different Torana models came with different height UCA pivot point mounts. Offsetting them (front one up vs rear one down or vice versa) allows you to adjust dive in the front end too. But I left mine neutral.
#79 _mello92_
_mello92_
Posted 24 August 2013 - 10:25 PM
Ahh ok yep I figured it would be for camber on compression, thanks Heath.
#80 Heath
  • 18,385 posts
Posted 25 August 2013 - 09:13 PM
Wheel alignment went as planned, with really good results. Recommend Edgar's Tyre Power (Notting Hill) to anyone in the Eastern Suburbs. Awesome blokes and the best equipment around.
Loaded it up that night and took it up into the Lerderderg Gorge with my girlfriend. The suspension works on the Torana a bit better than the Datto so it didn't mind the rough roads at all. Oh yeah didn't have a hatch hutch but I am a resourceful person lol.
#81 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 25 August 2013 - 09:27 PM
Looking good Heath, so the suspension works well and doesnt mind the rough...uhh roads hey??
#82 _LHSL308_
_LHSL308_
Posted 25 August 2013 - 09:31 PM
Be careful going there in the winter Heath.
I remember I took my LX 253 there about 20 years ago in the winter and we went down a track that ended up beside the river. We had no rain all night and 2 friends cars went up the hill before me which ruined any chance I had of getting up. I was wheel spinning and ended up stuck at the bottom. As it turned it the ranger had to come and pull me out and we all ended up getting a fine because we used a closed road haha. Those were the good old days.
#83 _Matvex_
_Matvex_
Posted 26 August 2013 - 12:36 PM
Good to see your having fun with your car Heath. The cars stance is really nice. I cant wait to put mine back together and start clocking up km's too.
#84 Heath
  • 18,385 posts
Posted 26 August 2013 - 07:06 PM
The stance has definitely been improved, but will be improved a lot further in the future. I've gotta say I actually really don't mind the wheels all that much now that it tucks tyre. Also rolled the guards which made a big difference.
#85 76lxhatch
  • 7,205 posts
Posted 26 August 2013 - 08:13 PM
Why so much negative camber and so little caster?
#86 Heath
  • 18,385 posts
Posted 26 August 2013 - 08:56 PM
How much caster do most people run? That's significantly more than I had on the green car. I expected the goal to be a bit less camber but he seemed to think that was cool with what I use the car for.
#87 76lxhatch
  • 7,205 posts
Posted 27 August 2013 - 05:31 AM
You're about at the absolute max caster possible for an LH or LX front end, but for a UC that's still within factory spec I believe. My opinion would be similar to yours on the negative camber - that's a bit much for road use and will wear out tyres and track into the ruts - I've used up to 1.5 degrees when there's no choice but with a nice straight front end that gives you options I'd keep it down to 1 degree. The great thing about the UC geometry is you can wind more caster in to make up for it without the side effects; mine is currently just over 5 degrees static caster, with only 1 degree negative camber.
#88 Heath
  • 18,385 posts
Posted 27 August 2013 - 07:24 AM
Okay, well now that it is at a benchmark (symmetrical etc.) I can muck around with some more shims in the back later on to experiment with an increased caster angle. My suspicion is that 5 degrees might be a bit too much caster for a manual LH rack (you do have power steering right?). Food for thought anyway
#89 76lxhatch
  • 7,205 posts
Posted 27 August 2013 - 11:57 AM
Yes 5 degrees is probably a bit much, although I've got 255 wide front tyres and I did run the (UC) manual steering that way for a bit - ok while moving but 3 point turns become annoying.
Depends on how it drives of course, but I would imagine if you could knock the camber back to -1 and add another degree of caster (total +3) instead then it would handle pretty nicely.
#90 LXCHEV
LXCHEV
  • 3,608 posts
  • Car:'76 LX - 383 Chev
Posted 08 September 2013 - 11:00 PM
Nice hatchback Heath - she looks the goods :)
#91 bryanw
bryanw
  • 294 posts
Posted 09 September 2013 - 01:11 PM
Looking good, height is much better looking, surprising the difference a little bit makes.
Are the wheels commodore pcd and offset? if so, what diff are you running? spacers?
I think the wheels suit it.
#92 _Leakey_
_Leakey_
Posted 10 September 2013 - 11:37 AM
Well done Hezath! Awesome looking machine. Jealous as all heck.
#93 MRLXSS
  • 12,413 posts
Posted 10 September 2013 - 09:45 PM
Looking good mate, looking forward to seeing it over the next couple of months once car events start happening again (and I get off my arse and get there!)
#94 Heath
  • 18,385 posts
Posted 10 September 2013 - 10:50 PM
bryanw yes mate it's Commodore PCD all round, wheels are aftermarket Commodore wheels with the positive offset and all of that - not something I am into but the setup does work quite well. I'll be selling all of that gear later on. Diff is a BW78 with Commodore rear discs but I keep forgetting to measure the length of it when I have it apart. I'm going to guess it's longer than an R31 diff.
Yeah it is a lovely looking car (for a UC) and the driving experience is getting significantly better with each little thing I'm doing. Just put a different gear knob on it and installed a fixed back driver's seat which made a mega difference, harness coming soon and also had a set of Koni reds arrive today which should help keeping it settled. But before I get too distracted I wanna get the diff sorted.
#95 _mick74lh_
_mick74lh_
Posted 11 September 2013 - 09:15 PM
It went alright the other night mate. It felt more like being in an early Commodore than a Torana.
#96 Heath
  • 18,385 posts
Posted 13 September 2013 - 09:58 PM
Keeping busy on this thing. Got around to painting the rear brake rotors to match the fronts:
Turned up some little crush tubes for the chassis rail so that I could mount a tow point on the chassis. Will put one on the front bumper bar iron later on too.
Installed a K-MAC 24mm Swaybar with polyurethane bushes:
Installed a composite fixed back racing seat onto standard Torana rails and a 4pt harness:
Set of off-the-shelf Koni Reds (adjustable), eBay $550 kit:
Loaded up with a swag in the back and in the morning I'm taking it away for a cruising weekend with my mates. Grouse
#97 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 13 September 2013 - 10:08 PM
very nice work heath
beautiful straight black hatch there mate
and great machining as well!
keep it up and enjoy!
davemc
p.s
love a hatch with four wheel discs
#98 bryanw
bryanw
  • 294 posts
Posted 14 September 2013 - 11:24 AM
Looking better all the time, did you measure the diff? what are the new shockers like?
#99 Heath
  • 18,385 posts
Posted 15 September 2013 - 04:59 PM
Yep the O/A length of the diff (including rotors) is 1530mm. That is why the lame offset wheels actually sit very well in the guards.
Just got back from an amazing trip through some unbelievable roads. Bloody awesome
#100 _LHSL308_
_LHSL308_
Posted 15 September 2013 - 05:27 PM
Looking good there Heath. Going a bit overboard with the racing seat aren't ya, I prefer the other seats you have in it, your choice but bud  :D
