Heath's Hatch
#101
Posted 15 September 2013 - 07:22 PM
#102
Posted 15 September 2013 - 08:59 PM
Heath, i'm all for personalising your car but WTF is with the race seat and harness, it's turned a nice car into a ............ dare i say it "a ricer", personally i think it spoils the whole look of the car, even though it's a UC it's not a bad looking UC.
What was wrong with the other seat.
#103
Posted 16 September 2013 - 01:06 AM
Geezus I think the general consensus is people don't like that seat Heath.
I have to agree mate, not a fan, but you're the one who has to sit in it so up to you I guess.
I think the red seats look cool as.
#104
_2_many_torries... never!_
Posted 16 September 2013 - 02:01 AM
#105
Posted 16 September 2013 - 12:32 PM
The people who don't understand that seat don't drive fast enough
#106
Posted 16 September 2013 - 12:38 PM
I'm tipping the seat is all about function over form, and aimed at what the OP is intending on using his car for. Looks tough, I reckon anyway, even if it doesn't conform.
#107
Posted 16 September 2013 - 08:24 PM
The other seat would have you sliding all over the place as soon as you hit a corner.
Yes.
This!
What I thought was a nice photo from the weekend.
Edited by Heath, 16 September 2013 - 08:39 PM.
#108
_greenmachine215_
Posted 16 September 2013 - 08:39 PM
#109
_Matvex_
Posted 16 September 2013 - 08:42 PM
Nice Pic Heath, Shows off yr cars Rack!
Edited by Matvex, 16 September 2013 - 08:56 PM.
#110
Posted 16 September 2013 - 08:46 PM
Picked this baby up for the BW78. Harrop modified Eaton True-Trac, 28-Spline.
Edited by Heath, 13 May 2021 - 05:17 PM.
#111
_LS1 Taxi_
Posted 16 September 2013 - 08:48 PM
Gorgeous car Heath.
Stunning!!
#112
Posted 16 September 2013 - 08:52 PM
I would say "not bad for a UC", but I won't say no to that!
haha cheers
Edited by Heath, 16 September 2013 - 08:52 PM.
#113
Posted 17 September 2013 - 09:41 AM
That's the angle you wanna show off mate, looking pretty damn good!!
#114
Posted 17 September 2013 - 10:10 PM
Thanks Re the diff, its a VL std length by the look of it, comes in 25 or 28 spline. have you counted the splines yet?
Not so easy to get 28 spline axles, but if it,s 25 spline, probably heaps strong enough?
#115
Posted 18 September 2013 - 12:51 PM
Fixed backs are totally ricer spec
You can have just as much support with a reclining bucket seat
And where have you got the harness bolted to?
#116
Posted 05 October 2013 - 02:33 PM
Turned up a solid bearing spacer for the pinion bearings:
Measured up what it had already. Tight setup on the gearset, but the open centre was worn out and was giving it a fair bit of backlash.
Made up a tool for getting the pinion nut on and off during setup:
Made a tool for installing new carrier bearings:
Ended up getting a bit of a hand from a diff shop around the corner from the factory - G&J Diffs in Dandenong. I went there to swap some shims and discussed a problem where the gearset seemed to be binding, ended up actually having a slight fouling problem on the TrueTrac centre with the factory pinion which turned out to be a BW75 gearset. I happened to get an "old stock" centre and after a bit of machining from the pinion head, it was all good. They also gave me a hand with the final setup too.
Also got my hands on an 18mm rear bar. The mounting points don't line up perfectly so I will need to change the setup a little later, but I put it on.
#117
_SLEDGE_
Posted 07 October 2013 - 06:43 PM
Nice work.
How do you find the helical gear type diff compares with a clutch type LSD? Trying to decide whether to invest in a TrueTrac... only shortcomings I can see are loss of torque if you happen to pop a rear wheel up in the air, which shouldn't be happening in a street car.
On paper seems to be a good compromise between a stock BW LSD centre and a KAAZ centre - both of which I'm also considering for my BW78 conversion
#118
Posted 11 October 2013 - 09:08 PM
I find the TrueTrac very good. I've been in plenty of clutch-type LSD cars including quite a number of the OEM BW ones. I've been in one KAAZ car and actually thought it was a bit much (I'm normally pretty damn forgiving towards that kind of thing).
I haven't done a lot of k's because I ran low on oil pressure with this motor recently and it's out ATM, but for the time I have driven it, I've been very impressed. Seems to be the best option for a street car at least, you could argue that a KAAZ is more suitable for track work on paper at least.
#119
Posted 20 October 2013 - 09:50 AM
Well the motor developed a surprisingly bad leak a few weeks ago, got low on oil without me realising and through a few corners ran outta oil pressure.
Crank needed grinding so thought it was just as worthwhile to get my spare Black 202 crank and blade the ends of the counterweights, I'll get some better photos of that when it is back from balancing.
I can't fit a Black flywheel into my bellhousing with the rat-trap clutch arrangement, and don't want to get too involved in changing that stuff around so I'm sticking with the Red flywheel which is not ideal, but I at least put it in the 4-jaw and took a bit of material off the engine-side. Would have prefered to put it on a rotating table and take proper mass off the clutch-side but didn't have access to the necessary equipment.
Gotta bit of work to do in the next fortnight or so.
#120
Posted 20 October 2013 - 09:56 PM
Why don't you just change it to a full cable clutch?
#121
Posted 21 October 2013 - 06:35 AM
So why doesn't the blue/black flywheel fit? Dimensions are the same as a red, except less material in the back similar to what you have machined out.
#122
Posted 21 October 2013 - 12:00 PM
Blue/Black is a nicer flywheel, but I believe the clutch to suit (which I don't particularly want to spend money on when my red clutch is perfect) is a bigger unit that doesn't clear on the rat-trap arrangement. The reason I don't change to full-cable is that it's just more parts to buy and more money to spend on a setup that will not be in the car for all that long. I know the existing combination worked well
Not much love in this thread, hah!
#123
_Matvex_
Posted 21 October 2013 - 12:10 PM
Why Why Why?
Your skills are impressive Heath. I can barely change spark plugs let alone machine fly wheels etc..
#124
_LS1 Taxi_
Posted 21 October 2013 - 12:18 PM
This car is cool Heath, and it's very interesting what you've done.
I'm looking forward to seeing it out and about over summer hopefully.
#125
_LS2 Hatch_
Posted 21 October 2013 - 01:36 PM
What are the plans for the car? If the engine is going to be replaced, what do you have up your sleave?
