* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#1451 rexy
rexy
  • 3,763 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 20 August 2021 - 06:50 PM
Heath is too young to know what a bush is.  :D
It’s weird how no one has pubes anymore.
Where do all the crabs live these days?
#1452 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 21 August 2021 - 10:55 AM
Blokes beards?
Rob
#1453 Heath
  • 18,401 posts
Posted 25 August 2021 - 10:41 AM
Golly.
Look I'm well enough travelled in that area to know what you're talking about, but they're a rare sight and I consider that a blessing of being in my generation.
I decided that my K-frame locating blocks were stupidly heavy and over the top, but I didn't want to lose the nice precise look of them.
Oh my god where did the mass go?
Ah!
Cleaned up the heads and squirted a bit more assembly lube down onto the cam.
This is why you dry-fit parts... did a dry fit of the inlet manifold (which was machined to suit the heads and I slotted out all the bolt holes at the time as well!), oh my god no chance of getting these bolts in the holes with the throttle bodies in situ.
Bit of work in 4 places with the die grinder:
I test fit the dizzy & clamp using the Aeroflow unit that my motor came with. Not sure what was was for... it didn't really fit around my inlet manifold, bellhousing or even my distributor very well, so I grabbed out some ally plate and got to work.
A few little dabs with the TIG in the right areas made some 'feet' on the bottom and a curved boss to ensure it has a good clamping effect in the right spots.
Also clears everything around it nicely and fits the dizzy beautifully.
Lifted her up and the assembly under.
I am actually going to use some hubcentric slip-on spacers for fine adjustment of the wheel fitment at the front end, so I bought some 2.5" long wheel studs from Strange and pulled my hubs apart to install them:
Together with some springs, shocks, and swaybar.
#1454 Peter UC
Peter UC
  • 771 posts
Posted 25 August 2021 - 12:55 PM
Why did you paint the springs red and not orange?
#1455 Heath
  • 18,401 posts
Posted 25 August 2021 - 01:07 PM
Oh, that's just so they go faster.
#1456 76lxhatch
  • 7,216 posts
Posted 25 August 2021 - 01:44 PM
I would have just bolted the manifold on before attaching the throttle bodies... could be why I have bolts everywhere that require contortionist skills to access :-/
Those throttle bodies still look great, will be a shame to close the bonnet!
#1457 myss427
myss427
  • 1,636 posts
Posted 25 August 2021 - 02:56 PM
What's you plan with no booster, VE Vacuum pump?
#1458 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 25 August 2021 - 04:38 PM
Hi Heath,
is the " hubcentric " spacer to push the rim further to the outside of the car?
Is that a word you made up?
Are they legal?
Why do you need longer studs?
Why are the spacers needed between the K-frame and body?
Regards Mando.
#1459 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 25 August 2021 - 10:44 PM
Are the k-frame spacers for engine clearance?
How do the spacers change the rear k-frame bolts lining up with the chassis rail?
#1460 myss427
myss427
  • 1,636 posts
Posted 26 August 2021 - 09:17 AM
I have the spacers, it helps with the engine angle to get 3 degrees, extractor clearance, also more tunnel clearance for gearbox height, especially with T56ers. Most of the reason with mine is big engine no room, ground clearance with big pipes.
#1461 Heath
  • 18,401 posts
Posted 26 August 2021 - 12:11 PM
When you heavily modify a car, you have so, so many opportunities to make things hard to service.
I have fallen into that trap enough times on this car, I really want to try and avoid/revise those areas where possible. Plenty of things need to be assembled in a particular order etc. - I don't need to add to that list! LOL
Certainly not, I want manual brakes on this car.
I think my motor would still make enough vacuum for a booster to work if I wanted one, though? Like it's only got a 238/238 @ .050" cam so not absurd.
Are they legal?
Yes, it will push the wheel to the outside of the car a small amount.
Haha it may not be in a dictionary but it is an established term.
Are hubcentric spacers legal? A Porsche 930 came standard with 20+mm hubcentric spacers and nice long studs, so, maybe? Don't know/don't care. Mine won't be very thick, they'll be sized up correctly and I have 1/2" UNF wheel studs, so they'll be safe and that's all I am concerned about.
The longer studs are just to ensure there's plenty of thread engagement even once there's a spacer installed.
The spacers are the same height as the standard rubber bushes. In my case they don't help with gearbox clearance, pipe clearance, engine clearance, or anything. It is just to locate the crossmember further forward in the body to move all of the suspension pick-up points and wheels forward.
I cut my engine mounts off the crossmember and moved them back to compensate for the crossmember coming forward, so it still sits in the standard location (apart from where the Tuff-Mounts move them)
Attached File  IMG_20170611_122054.jpg   511.63K   18 downloads
You are correct in pointing out that the rear bolts of course do not line up. I solid mounted those with some small adjustments.
Attached File  IMG_20170612_195035.jpg   456.57K   17 downloads
Attached File  IMG_20170613_182939.jpg   463.25K   19 downloads
#1462 myss427
myss427
  • 1,636 posts
Posted 26 August 2021 - 01:09 PM
Wow missed that part with crossmember forward shift and spacers. You will still enjoy a little added room out back around bell housing and crossmember out riggers. With the shift forward, how does your tyre to flare clearance go, did you move them too, or just cut a wedge out of the flare?
#1463 ls2lxhatch
  • 5,335 posts
Posted 29 August 2021 - 02:20 AM
FWIW spaces and adaptors are not legal in any state unless they were a factory option.
NCOP11 Section LS Suspension and Steering V2.1 15Nov2015
4.2.2 Wheel Attachment
Wheel spacers (or adaptors for dual wheel conversions) between the wheel mounting face and [/size]the road wheel must not be used unless fitted as original equipment by the vehicle manufacturer.
#1464 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 29 August 2021 - 07:46 PM
Hi Heath,
did you drill the holes on the fire wall for your wiring loom before or after you painted?
If after, what did you use?
Regards Mando.
#1465 Smog
Smog
  • 25 posts
  • Name:Tim
  • Car:Group Nc race car
Posted 29 August 2021 - 08:03 PM
Hi Heath,
I’m new hear and just stumbled on your build thread and you have just blown me away with your attention to detail, skill sets and the
dedication to the vision you have with this car.
A build like this is always going to be a long road, but the exciting finish line is not that far away where you can enjoy the fruits of your hard labor.
This will be one very cool ride.
Not sure if you have answered the question about running straight LPG. Interested in your thoughts?
Also on that issue, when you finally crank this thing, can you fill the tank prior to fitting it to the car or are you going to have to trailer the car to the servo to fill it?
Cheers Tim.
#1466 Bigfella237
Posted 29 August 2021 - 08:21 PM
Not sure whether it's legal but I had an adapter hose made up to fill my Caprice from an upturned 9kg LPG cylinder, kinda like a jerrycan for gas.
But it looks like you can buy them pre-made now. Have a look on ebay for forklift LPG filler hoses...
You could always put some gas in the tank before you fit it to the car if you know a servo attendant who will look the other way while you do it! :rolleyes:
#1467 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 30 August 2021 - 08:21 AM
Servo attendant? Aren't they extinct?
A mate made one of these up years ago so he could fill 4.5kg bottles in the boot of his car to run his barbecue. That certainly wasn't legal, but worked very well.
early Holden nut
The gun fitting would have been female come to think of it.
early Holden nut
#1468 Heath
  • 18,401 posts
Posted 30 August 2021 - 06:14 PM
A few things to reply to here...
Yeah I also did all this stuff to the crossmember to buy more space. Is the real estate I gained actually useful? I don't think it's anything life-changing but no harm of course.
Regarding the front flares and wheel clearance... I don't want to profess a good outcome until my car is on the road with an alignment. I may have challenges ahead still.
The test fit I did prior to paint showed promising results regarding clearance but everything on this car seems to go very wrong, so I'll assume I might have a challenge by the time I actually get to that bit.
The flares were not "moved". They were manipulated a bit with some fibreglassing efforts of mine. If I have to cut a wedge out of the front of the flares, I'll probably just throw the car in the bin at that point. That would be an AWFUL outcome I'd be very unsatisfied with.
Nothing revelationary there.
Hi Heath,
lol I put masking tape over the paint, triple checked the location of them, clinched as tight as I could and drilled away with a holesaw. Then changed pants.
Followed that by cleaning up the edges with a die grinder for a good final size, deburring, then I used a small paint brush to add some paint around the edge to try and seal it up.
Certainly this is NOT best practice. But what else was I to do? I've never built a car before and didn't know any better. A full dry build would have been smarter.
Hi Heath,
Cheers Tim.
Thanks so much, Tim. It certainly feels like it isn't too far away! Which is refreshing.
Just on the weekend I did a dodgy and connected a spare filler hose, went to the servo with my LPG tank in the boot of my Chaser surrounded by packing materials, and put 30L of gas in it. One less thing to worry about later.
What was the prior question regarding straight LPG?
#1469 Smog
Smog
  • 25 posts
  • Name:Tim
Posted 30 August 2021 - 07:12 PM
Yeah Heath, just wondering why you went LPG over petrol?
Cheers Tim.
#1470 Heath
  • 18,401 posts
Posted 31 August 2021 - 10:00 AM
Oh, just a personal preference of mine mostly.
What comes out the tailpipe is a lot more comfortable for people to breathe, I like that a lot. And I am a huge tightarse and want it to be cheaper to run than my other cars so I don't feel guilt about driving the wheels off of it.
#1471 Bigfella237
Posted 31 August 2021 - 11:39 AM
LPG has a pretty good octane rating too, generally over 100 octane, so a good alternative for performance as well as emissions.
#1472 rexy
rexy
  • 3,763 posts
  • Name:Rexy
Posted 31 August 2021 - 11:47 AM
Over the 20 years I had my old LX sedan on GRA straight LPG I saved enough money on fuel to pay for all my engine upgrades and general maintenance on the car.
Still went hard enough to win the traffic light derbies.
#1473 Smog
Smog
  • 25 posts
  • Name:Tim
Posted 31 August 2021 - 04:25 PM
Fair call.
Also, bold move on the interior ..... but love it!
#1474 myss427
myss427
  • 1,636 posts
Posted 01 September 2021 - 11:34 AM
I did the triangle wedge thing to mine, so long as you keep the inside curve looking round and do not cut off the inside return edge, you cant really tell its been cut. You can get up to 30-50mm extra room with this. Also you can make some A9X flare supports, they push out the bottom of the flare and bolt to the base of the radiator support panel, they make a huge difference with tyre scrub at the base of the flare. I run a 10 inch wheel on the front with a 245 tyre and have heaps of clearance.
#1475 Heath
  • 18,401 posts
Posted 01 September 2021 - 03:54 PM
I think I misunderstood your post. I thought you meant the corner off the flare like some people do. Yuuuuuck.
I have already re-shaped the return lip on the flare to change the shape of it, I assume that's what you're referring to, and also expect to make a flare support for it (once I hang panels).
