Heath's Hatch
#151
Posted 05 April 2014 - 11:00 PM
#152
Posted 05 April 2014 - 11:07 PM
#153
Posted 05 April 2014 - 11:10 PM
#154
Posted 06 April 2014 - 12:29 AM
Thanks for changing the mirrors.
#155
Posted 07 June 2014 - 03:54 PM
Had to move out of my factory in a hurry, so quickly got the Torana running, yanked the motor out, fixed the speedo gear, shifter & sump gasket, adjusted the rockers again and chucked it back in.
Rear main was okay. Still got rocker cover leaking problems, will try a rubber gasket on that one soon.
#156
_LH327_
Posted 18 September 2014 - 07:20 AM
Hi Heath,
Im just about to chop my steering column to allow for the BBC and pipes to fit. I need the outer housing to be 40mm out of the firewall and I will cut the inner shaft as you did. I need to cut the shaft coming out of the rack and use a uni straight of the rack. I will need a Long shaft between these two uni's. what type material is the shaft you made up or what is the original shaft made of? Did you use 4340 grade round bar? is standard mild steel round bar alright to use? I was worried about twisting or the flats for cotter pin wearing.
Any help would be great.
#157
Posted 18 September 2014 - 10:05 AM
My steering column and rack is the same as you described. Had a hardened 5/8th steel rod made up with ends turned down to fit the universals, been in the car over 10 years and no signs of ware. Also I moved the column over at the base an inch and a half closer to the engine for more extractor clearance, made no difference to the steering wheel position inside the car.
#158
Posted 19 December 2014 - 10:05 PM
Hi Matt, sorry for such a slow response. I made that one using 4130 because I had access to some. I kinda doubt the standard Torana one is anything too exotic hahaha
#159
Posted 20 December 2014 - 10:59 AM
Well obviously this thread hasn't been updated in a while. Since posting last I've bought a new daily/work car which I've been having fun with.
And the Torana has been in storage for a few months. I found another spot where I can pay to work on it, so I pulled it out, got it running and now it's coming off the road properly. I didn't buy it to have another six (very regrettable/unsatisfying engine build two pages back) or to have a UC hatch. Time to get serious!
Looking a little different after last night's effort
There is a For Sale thread for the whole red custom interior, every part of the car that is UC-specific, bumpers, guards, grill, bonnet, lights, and nearly everything on the car will be available in time.
#160
_j.e.d._
Posted 20 December 2014 - 01:38 PM
Good on ya Heath, great to see you ripping in to it. What's your time frame? What engine/box are you putting in it?
#161
_Matvex_
Posted 20 December 2014 - 03:04 PM
#162
_LHSL308_
Posted 20 December 2014 - 03:16 PM
#163
Posted 20 December 2014 - 11:47 PM
Yeah well this is kinda the car I've wanted to build for a fair while now... hopefully having a spot in this workshop will enable it to happen. Was close to buying various houses this year so I could build a garage to do it, but now that can wait!
I don't have a time frame in mind; I wanna put in some pretty serious hours but I'd like to go for a pretty high quality result too. It will be Holden V8 powered and manual as I still haven't grown a vagina. Not going to give away all of my plans yet though. For now I pretty obviously need to focus on sheet metal work.
#164
Posted 22 December 2014 - 04:08 PM
I havent been updating pics on here much atm, i taking it you are doing UC/LX conversion. Are you removing innerskirts as well or doing it Dirtbag style?
Looking good.
#165
_mick74lh_
Posted 22 December 2014 - 08:16 PM
Nice one Heath. I can understand why you're frothing so much now.
#166
Posted 28 December 2014 - 10:07 PM
Looking good.
I was really on the fence about which way to go. I've gone ott308's style... probably just because I was looking at his thread most recently before I did it. I'm not sure if I'd do it this way again? Don't have a strong argument either way.
Excuse the low quality photos.
#167
Posted 28 December 2014 - 10:47 PM
gee you've done that well heath,thats cut to the mm lol.id say its worked out well
admire your work bud
Maz
#168
Posted 28 December 2014 - 10:57 PM
Thanks Maz. Honestly all of the conversions that I've seen on here appear to be of a really good quality - mine is certainly nothing special. Still the front clip came on and off probably 30 times for measuring & adjusting. The main plan was to get it accurate enough so I can take my TIG down to the factory tomorrow and do the long welds with that. Will see how we go!
Edited by Heath, 28 December 2014 - 10:58 PM.
#169
Posted 28 December 2014 - 11:03 PM
#170
_ljxu1torana_
Posted 28 December 2014 - 11:44 PM
you wont be late in a 308.
#171
Posted 29 December 2014 - 09:00 PM
Hahaha a 308 doesn't seem as thrilling as it used to, driving a modified JZX100 every day.
I made a mistake when I was cutting the two pieces and left a little void above the hinges, the repair is a little messier in that area. Otherwise quite happy.
Dusted the cobwebs off the TIG this morning and gave it a birthday, went down to a 1.6mm electrode, collet, #5 nozzle, 1.6mm steel filler, new lenses for the helmet etc. Also first time with the pedal which was good!
#172
_ljxu1torana_
Posted 29 December 2014 - 10:20 PM
i have had fried rice a fair while ago.but i prefer steak.
#173
Posted 29 December 2014 - 10:33 PM
But it's going to look so much better LXed
Az
#174
_LS1 Taxi_
Posted 29 December 2014 - 10:58 PM
#175
Posted 30 December 2014 - 10:00 PM
Thanks mate. What I'm proud of/impressed with at the moment is my dedication to treating the construction of this car like a full time job for this time I've got off work. Very much like your approach Darren!
Got heaps done today. Very happy.
I was going to make the landings in the engine bay out of cardboard covered with bog.
But then I decided steel may be a better material?
Edited by Heath, 30 December 2014 - 10:01 PM.
