* * * * * 8 votes
Heath's Hatch
2139 replies to this topic
#1976 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 21 August 2023 - 12:14 PM
Maybe something in it Heath, the machining grooves could possibly be contributing to oil being screwed out. I found the following reference in relation to older MG crankshafts: "Perhaps the most annoying source of oil leaks in older British sports car engines is the mechanical oil slinger/seal arrangement designed as the primary rear crankshaft seal.  The theory of this Archimedes-principle seal, is that the spiral grooves at the back of the crank fit with only a slight clearance to the stationary upper and lower oil control surfaces.  As the crankshaft rotates, the action of the reverse oil control threads against the flat sealing surfaces draws the excess oil back into the hollow cavity next to the rear bearing where the oil drains harmlessly back to the oil pan."   The difference in your case is that the seal is spinning and the grooves are stationary. Nevertheless interesting to see if the smoothing operation provides a solution.
Edited by V-SLR5000-P, 21 August 2023 - 12:19 PM.
#1977 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 21 August 2023 - 06:03 PM
And is the same reason that old MG's with proper wire wheels had left and right hand thread retainers. They didn't leak oil, but had other issues...
Edited by Uncle Chop Chop, 21 August 2023 - 06:03 PM.
#1978 rodomo
  • 18,041 posts
Posted 21 August 2023 - 09:05 PM
Early "Aussie" boxes, 3 and 4 speed, had a reverse slinger input shaft seal rather than the positive neoprene seal.
There is also  the speedie sleeve option if what you've done doesn't fix it? https://www.ebay.com...phoCUloQAvD_BwE
Or, the Ol' remove the spring from the seal, cut 5mm off it and refit it tighten up trick?  :ph34r:
Edited by rodomo, 21 August 2023 - 09:07 PM.
#1979 SHEEL
SHEEL
  • 346 posts
  • Name:Daniel
Posted 21 August 2023 - 09:30 PM
very much looking forward to Sept SM!!
#1980 MRLXSS
  • 12,414 posts
Posted 23 August 2023 - 11:44 AM
And amazing news... Street Machine's September issue will cover the full car feature! :D
So... will it COVER the September issue as well?
Either way, I can't wait to see the photos and read the story!
#1981 Heath
  • 18,394 posts
Posted 23 August 2023 - 05:20 PM
I guess "Cover" is the operative word here. Haha!
Certainly a childhood dream for me.
#1982 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 23 August 2023 - 07:45 PM
What one magazine staff member indicates is one thing. The editor has the final say,doesn't he?
#1983 Shiney005
  • 9,613 posts
  • Car:Toyota Mirai
Posted 26 August 2023 - 09:11 AM
New poster for the workshop!
#1984 Heath
  • 18,394 posts
Posted 26 August 2023 - 09:21 PM
Well I found another error of mine! When I made my exhaust, I just welded some stainless bar to two convenient locations on the floor of the car and didn't laminate or brace where they were attached.
Anyway, here we are with 9,000km down and one has cracked through the floor after thrashing the car on some bumpy B roads last weekend.
Ripped the rear seat out and started peeling back the insulation to find the damage from the inside.
It has only broken the floor on the LHS where it is more "flat" and I guess it's bent the floor up and down a few times until it has work hardened and started to crack through.
Funnily enough, I had already bought some material for a second pair of exhaust mounts as I noticed the rubbers weren't fairing too well, just hadn't made too much time to execute it yet.
So what I've done is jacked the mount back up to its old position, re-welded it together, and added two gussets on the inside of the car to make those small sections of the floor nice and strong.
Added more insulation:
And started work on some (hollow this time) extra exhaust mounts on the rear mufflers:
Plus I horizontal-cut the tailpipes because I found they were a bit too close the ground on those rough B roads when I had the smaller rolling diameter Hotwires on the back anyway. Probably looks neater also.
#1985 Heath
  • 18,394 posts
Posted 26 August 2023 - 09:40 PM
In slightly more significant news than exhaust mounts, as Shiney kindly eluded to, my car made it onto the poster in the September issue of Street Machine.
Well, it made it onto the poster, it is the topic of an 8-page feature, and it's the cover car. Holy. Shit.
That could not have gone any better. Had the legendary wordsmith Simon Major (Simo from the Thongslappers podcast) to write the feature, and Tappy's outside and in-studio (studio being my warehouse at work) pics came together so nicely. I reckon the cover shot is bloody mental. The graphics team had a lot of fun with the bold pallette of the car and working with that theme all through the pages of the feature as well. And I'm of course thrilled that they chose my car to represent this classic modified car institution and its shelf presence in-front of punters for a whole month.
#1986 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 26 August 2023 - 09:41 PM
Saw some engineering stuff that suggested 5 points.
You are pushing some limits.
But apparently 5 points works well.
Rob
#1987 Bruiser
Bruiser
  • 861 posts
  • Name:Bruce
Posted 26 August 2023 - 09:49 PM
Well done fella
#1988 LXCHEV
LXCHEV
  • 3,614 posts
  • Car:'76 LX - 383 Chev
Posted 26 August 2023 - 11:34 PM
Well done Heath, and so well earned. Love the 'Back to the future' title too, very good!
I no longer buy or read Street Machine, but this month will be a clear exception!
#1989 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 27 August 2023 - 01:52 AM
Second that, will be grabbing a copy too
#1990 Shiney005
  • 9,613 posts
  • Car:Toyota Mirai
Posted 27 August 2023 - 08:40 AM
I've kept every issue since 1986. Looks like I'd better buy two this month. Well done Heath.
#1991 clarky9999
clarky9999
  • 121 posts
Posted 27 August 2023 - 09:09 AM
Well done, bloody good effort has been a joy following all of your builds from BBQ202 to this, if only i had the skills that you show.  Your threads are sensational to read and see how its done,  Cheers
#1992 claysummers
claysummers
  • 3,641 posts
  • Name:Clay
Posted 27 August 2023 - 10:13 AM
Truly awesome Heath. Haven’t bought one for years, but I’m on to it.
#1993 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 27 August 2023 - 02:16 PM
Well done Heath car looks fantastic !!!
Dream come true for a lot of blokes, cover of Street Machine. Enjoy .
#1994 FLY_LX
FLY_LX
  • 192 posts
  • Car:LX sedan
Posted 27 August 2023 - 06:15 PM
Hell yeah brother
I recon they'll sell a few copies this month.
#1995 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 27 August 2023 - 06:21 PM
Congratulations Heath, Well deserved mate… I’ll be definitely buying the September issue of SM
#1996 yel327
  • 13,658 posts
Posted 27 August 2023 - 06:37 PM
Well done Heath. I bought the first edition of Van Wheels, and used to buy Street Machine into the late 80's but stopped when the cars got less and less street cars and more and more open cheque book trailer princesses. Yours is certainly not that! Congrats.
#1997 gtrboyy
gtrboyy
  • 3,215 posts
Posted 27 August 2023 - 06:57 PM
Will surely buy the mag now.
#1998 snuff1966
snuff1966
  • 192 posts
  • Car:LH G pack
Posted 27 August 2023 - 07:44 PM
Great stuff Heath, have'nt bought an issue for quite a while but I'll be getting this one
#1999 SmacT
SmacT
  • 980 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 27 August 2023 - 08:08 PM
So much excellent - well deserved Heath. 👍
#2000 SHEEL
SHEEL
  • 346 posts
  • Name:Daniel
Posted 28 August 2023 - 09:25 PM
AMAZING!! well earned! next stop... smoty?
