* * * * * 9 votes
Heath's Hatch
2139 replies to this topic
#2076 neglectedtorana
neglectedtorana
  • 1,057 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 07 April 2024 - 07:20 PM
Hi Heath,
My engineer told me to reinforce the trailing arm mounts during my build by adding some flat bar inside and bolting through it.
This is how it looked. I don't know why there is 2 of the first pic.
Hope you get everything sorted before the Optima and maybe even get some time to relax.
Cheers, Tom
Attached File  P1090956.JPG   141.67K   13 downloadsAttached File  P1090956.JPG   141.67K   13 downloads
Attached File  P1090965.JPG   151.98K   17 downloads
#2077 Heath
  • 18,403 posts
Posted 08 April 2024 - 10:14 AM
Pretty smart engineer! I still don't think that bracing work would have quite saved me from this problem but it would have helped. Mine has been stitch welded and has a brace from the lower arm mount to the upper arm mount, so its position on the floor is a lot more secure than standard. BUT I haven't made the integrity of the mount any better, and that has become the weakest link. I am told Group C A9X's when they were new had issues with the integrity of those mounts also. They are fairly long and also flimsy.
You would take a bit of a weight hit but you may have to consider fitting an engine oil accumulator in there somewhere?
Yep, the plan was to make the sump as good as I could and give it a proper test before adding any band-aids like an Accusump. So that's back on the table now of course.
The Porsche starting to look "more fun" now Heath?  :)
lol, I just kicked it back into life after about 6 months on the weekend. Gotta fix a few things and take it to LuftWasser this coming weekend. I get to put my mind at ease with the luxury of racing a dry sump! Haha
Hi Heath,
Regarding the oil surge issue/ track day surge issue.
I had a look back through your engine pics, but couldnt find any that showed rocker cover drains? ( maybe I missed them).
I have had the same issue on track days with a fully tricked up track sump. As the experts say, a trick sump only works if the oil is actually in there, and not all pumped up into the top of the engine.
We added drains ( 6 cyl ) and all good.
Apologies if this is all old news to you.
Thanks mate, I believe that was absolutely a huge concern of the car when I raced it with the old sump, but with the new sump I actually did add a drain-back on each side. The only reason you can't see it in the rocker covers, is that I tapped it below the covers, in the oil bath of the cylinder heads themselves.
https://www.gmh-tora...atch/?p=1101531
#2078 RallyRed
  • 8,213 posts
Posted 08 April 2024 - 10:54 AM
All good.
#2079 AbsynthHatch
AbsynthHatch
  • 741 posts
  • Name:Mark
Posted 08 April 2024 - 02:55 PM
I heard suspension bind involving the top arms on a torana can be rather bad, which by the looks you proved.
Is there an option to go a Panhard rof & add in a very soft bush in the top arms to avoid binding?
#2080 Peter UC
Peter UC
  • 771 posts
Posted 08 April 2024 - 04:49 PM
There's no binding as Heath converted the top arms to a wishbone, this would just be from the lateral load placed on the mounts.
#2081 SHEEL
SHEEL
  • 352 posts
  • Name:Daniel
Posted 09 April 2024 - 10:10 AM
I wonder if there is more load because of the wishbone setup...
I've got no idea with engineering things, especially suspension geometry / load etc... just throwing the idea out there
#2082 Bigfella237
Posted 09 April 2024 - 10:51 AM
Unless the axis of both pivot points (IE the mounting bolts) on the upper mounts are parallel, which they aren't on a Torana, then there MUST be bind through the arc of travel.
I'd think that this bind would be exacerbated with a solid "wishbone" setup because each side doesn't move independently like the two-arm factory setup.
Looking at the result, you can see how the pivot points have tried to 'straighten' themselves...
#2083 Heath
  • 18,403 posts
Posted 09 April 2024 - 11:38 AM
I have a fair idea of how it pivots as I can just bolt my wishbone into the car without the diff and take it through its range of travel, which of course I have done.
It isn't a perfect system with infinite articulation (and it would be better with rose joints, not that I would want the NVH sacrifice of having undampened mechanical connections at both ends), but within the tiny range of travel that my rear suspension actually sees, I don't think the angular misalignment is problematic. And the angle of the ends mean that the the force vectoring has a fair bit of load acting nicely in shear through each bush and 1/2" bolt (double shear) which I think is somewhat desirable.
Keep in mind the car has done 20,000km with this geometry in the rear end and it goes on the hoist very regularly as it's a shitbox that always needs work, so I am looking at things often. I believe this damage is very recent... like at Wilby Raceway on sticky rubber the other week recent.
Adding a panhard bar to this setup would corrupt the roll centre... you'd have two features fighting each other. At that point I would put a top link in the car that's straight down between the rear seat bases.
#2084 Peter UC
Peter UC
  • 771 posts
Posted 09 April 2024 - 12:52 PM
Just to add to what Heath said, I also moved the arm through it's range of motion and, although there is a twist through the bush, there didn't seem to be any loads that would have caused the arm to bend the mounts other than lateral loads.
#2085 claysummers
claysummers
  • 3,715 posts
  • Name:Clay
Posted 09 April 2024 - 02:05 PM
Parallel arms will still bind with differentiated suspension travel between left and right.
#2086 Shiney005
  • 9,826 posts
Posted 10 April 2024 - 01:38 PM
Hi Heath,
It didn't take long to figure out that 10 inch wide slicks were going to find the weak point.  This is from October 1974.
Attached File  Screenshot 2024-04-10 113740.png   616.88K   26 downloads
#2087 76lxhatch
  • 7,222 posts
Posted 10 April 2024 - 02:38 PM
Unless replaced with significantly more bolts than rivets I don't see the advantage in terms of strength. Making certain suspension parts "bolt-on" for racing purposes could be another matter of course?
edit: oh unless they have very large washers I suppose
Edited by 76lxhatch, 10 April 2024 - 02:39 PM.
#2088 Hatchback13
Hatchback13
  • 190 posts
  • Car:1976 SS hatchback mint julep
Posted 10 April 2024 - 08:44 PM
Always interesting reading with you Heath. Cheers
#2089 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 11 April 2024 - 08:57 AM
One thing I noticed when playing with Griceys old hatch was that there were links between the roll cage and the upper suspension mounts.
The area was 'upgraded'.
A mate had a UC years ago with a 308 in it.
He had lots of trouble with the floorpan cracking around the upper mounts.
It was suggested that he reinforce the area, and I showed him what was done to the race shell.
But he wouldnt part with the extra bucks.
Eventually it ripped apart that badly that he scrapped the car.
Rob
#2090 jeffblanco
jeffblanco
  • 389 posts
  • Name:Mando
Posted 19 June 2024 - 01:09 PM
Hi Heath,
I have the pictures that looked through the "Heath's Hatch" shows the front Wilwood discs.
I there may a spacer after the rotors or have I'm looking at something or am I wrong.
I think is on Build Thread on V8 Torana Hatch with the lot.
Regards Mando
Edited by jeffblanco, 19 June 2024 - 01:15 PM.
#2091 jeffblanco
jeffblanco
  • 389 posts
  • Name:Mando
Posted 22 June 2024 - 10:34 AM
Hi Heath,
would you able to please give the fronts and rears rotors size and do your rims are 15"or different.
Regards Mando.
#2092 Heath
  • 18,403 posts
Posted 05 July 2024 - 01:25 PM
In that photo, I did have a cheap slip-on spacer on the front hubs. I've now replaced that with a hubcentric slip-on spacer to locate the wheel nicely and push it out to a touch to fill the flare better. From memory it was darn close to the upper balljoint but I might have that wrong.
Front rotors: WIL-160-7104-BK & WIL-160-7103-BK
Rear rotors: WIL-160-7101BK & WIL-160-7102BK
Front wheels are 16x10" +4 and Rear wheels are 17x12" -31. They both do run spacers but they haven't been taken into account with the offsets described there.
#2093 jeffblanco
jeffblanco
  • 389 posts
  • Name:Mando
Posted 05 July 2024 - 03:48 PM
Thanks Heath,
the 310mm rotors are both but they look awful using 17"
REAR
Attached File  DSC_3731.jpg   289.99K   8 downloads
FRONT
Attached File  DSC_3733.jpg   295.46K   7 downloads
Was told 355mm rotors are not used on18" wheels
Regards Mando
#2094 jeffblanco
jeffblanco
  • 389 posts
  • Name:Mando
Posted 05 July 2024 - 04:03 PM
Hi Heath,
see spacers on your wheels which as I will want do after rego.
Now I see the studs need to be longer as well as far back to set the flares.
Attached File  IMG_0639.jpg   309.09K   8 downloads
Attached File  IMG_1185.jpg   310.89K   9 downloads
Regards Mando.
#2095 Bigfella237
Posted 06 July 2024 - 10:00 AM
~ see spacers on your wheels which as I will want do after rego.
Now I see the studs need to be longer as well as far back to set the flares. ~
G'day Mando, I assume you know that wheel spacers are illegal on the road?
NCOP11-Section-LS-Tyres-Suspension-Steer
I'm not trying to tell you what to do, I'd just hate to see an insurance claim denied after a mechanical safety inspection or anything like that.
#2096 rexy
rexy
  • 3,777 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 06 July 2024 - 01:01 PM
Glue them to the wheel….
#2097 yel327
  • 13,788 posts
Posted 06 July 2024 - 02:24 PM
I had thought the same thing Rexy. Or maybe tack weld them to the wheel. Or be really smart and follow the guidance of the second paragraph, ie making an adaptor ring out of alloy but incorporating it into a spacer. Something like the attached. These are to fit Simmons onto BA-BF brakes with 5/4.75" stud pattern. The ring would be only 1.1mm thick, it's been strengthened by incorporating it into a plate that sandwiches between the wheel and the disc. The idea is you put these on the Simmons wheels and lock them in place with the wheel studs, keeps the rims co-centric with the hub.
Attached File  Ring1.jpg   348.19K   19 downloads
#2098 jeffblanco
jeffblanco
  • 389 posts
  • Name:Mando
Posted 06 July 2024 - 03:09 PM
Thanks Andrew,
I alway thought the spacers were illegal.
My problems which are
1. the rotors look to small.
2. the rims both the front and rear to set to from the tyres or the edge of the flares. I would like the edge flares
    meet the tyres about 20mm.
3. yel327 idea on the adaptor ring into the spacer might be legal if the engineer looks.
4. 15" on new mags will the backplates the thickness came from.
5. new studs from longer ones.
Regards Mando.
#2099 Heath
  • 18,403 posts
Posted 15 July 2024 - 03:27 PM
Woah, that is a mile out. Clearly mistakes were made when measuring the wheels and diff... that package could go under standard guards; certainly doesn't need the flares.
You cannot have a diff that short and fill flares using off-the-shelf wheels. And you can't really - safely - do much with spacers to correct that severity of a wheel fitment issue. I've used concentric spacers on my car to fine-tune things (basically so I can chooose different amounts of tyre stretch without re-building wheels), but we're talking small adjustments. Everything on my car is made to fit.
Regarding brake rotor diameter, once again yeah I just chose something that was big enough for the performance I wanted and would suit the dimensions of the wheels I wanted to use. They fill the space really nicely which was important to me (on the front, I don't care as much about the rear)
Attached File  heath-van-der-waerden-lx-torana-side-wm-scaled.jpg   223.73K   7 downloads
You could put the rear wheels on the front of your car and get your diff made way longer? And buy a second pair of rears maybe? Then you'd end up with a square set and no stagger in dish. :(
Or just lose the Hotwires, go to custom 3pce step lip wheels on all four corners. That will make your brake package look better and you won't lose your car at a show in a sea of Toranas where everyone runs 17" repro Hotwires lol.
#2100 SmacT
SmacT
  • 1,007 posts
  • Name:Sam
  • Car:LX 4dr 355, TKX, BW
Posted 16 July 2024 - 11:31 AM
I agree, that far out is new diff time I reckon Mando, unfortunately. Or a fresh set of three-piecers, but that would be some mega dish on the rear and the Wallopers may not like that - they seem to have a target on crazy-spec wheels at the moment.
If you are thinking of changing front brakes, depending on what you go, they may help a little - my Hoppers Stoppers kit adds 8mm to track for instance. Just be sure to get it wheel aligned before making any changes, as camber/castor changes makes a difference to clearance inside and out.
I need to go wider on my front 3-piece wheels, so will order a set of outers from Spinners in Melbourne, drill them myself, re-build the wheel, then fit. I keep procrastinating because nothing scrapes at the moment and I hate cars scraping. I have already done all the mods you suggest for the front Heath (watched your video on YouTube, bewdy!) and from my measurements I will just need to trim the inner center section of the front flare, but worried I will open a can of worms... I will just drive it for now.
Heath - dat stance...  :P
