Heath's Hatch
#201
Posted 11 January 2015 - 06:13 PM
Actually grind away the back of the spotwelds and peel the remaining strip off.
You could then fuse the dash in with your TIG, edge to edge.
Plug all the drill holes in the LH dash first and sand it up so it finishes up neat.
Its just a suggestion. Im keen to see how you go about it.
#202
_LHSL308_
Posted 11 January 2015 - 06:45 PM
Good work Heath. Its not offen you learn from a grasshopper but I am
#203
Posted 11 January 2015 - 08:02 PM
What I did on the car was drill the whole way through with every visible spot weld (as the UC dash was going to scrap) and then run along under the join with sandpaper and a torch to find all of the obscured spot welds, marked them on the top and went through from the top too. After a bit of buggering around and cutting it near the pillars, I got the dash out this arvo. Still not cleaned up at the ends though.
Also cleaned up the ends of the LX dash off the car
#204
Posted 11 January 2015 - 10:12 PM
Love your work Heath !
#205
_berro59_
Posted 13 January 2015 - 05:50 PM
Great work Heath!
Been there done that!
You are going to have fun welding it back in with out getting burnt. When I did mine I joined it back on at the original mounting points over the steering column and got cooked.
You may also need a LX/LH steering columm and wiring harness as the instrementation and indicator stalk witing connections differ from UC.
Good luck and feel free to PM me with questions.
#206
Posted 13 January 2015 - 09:53 PM
I'm not used to UC's... this panel hanging from the plenum is not something I recognise from LH/LX? Am I losing my mind? Or is this a UC-specific thing? What's it for?
Edited by Heath, 13 January 2015 - 09:54 PM.
#207
Posted 13 January 2015 - 10:19 PM
#208
Posted 14 January 2015 - 05:10 AM
#209
Posted 14 January 2015 - 06:32 AM
#210
Posted 15 January 2015 - 06:47 AM
#211
_ott308_
Posted 15 January 2015 - 12:14 PM
Shouldn't need to bend it??? It should be the easy bit....
#212
_berro59_
Posted 15 January 2015 - 02:29 PM
Yeah i didnt bend mine either. Should just fit.
#213
Posted 15 January 2015 - 05:53 PM
#214
_Matvex_
Posted 16 January 2015 - 07:39 AM
Can you see any evidence of accident history to yr hatch? maybe crosscheck yr measurements with another torana?
Also your cut possibly could have been in a stack and the metal has stretched? Im no expert but thought id put it out there.
#215
Posted 16 January 2015 - 10:05 AM
lol nothing is out of whack (if your firewall was outta shape, it would be fairly clear), it's simply that everyone else seems to have cut the ends of their dash on/left the ends of the UC dash in there. I carefully removed the UC dash 100% (sacrificing it in the process), and kept the LX dash 100% complete (sacrificing everything around it) not realising any of this, and now while the dash is the right size, there's no way of getting it in the hole past the kinks in the pillars and I actually bent it last night trying to get it in.
Ah well. I'll have to be a little more creative.
Edited by Heath, 16 January 2015 - 10:06 AM.
#216
_ott308_
Posted 16 January 2015 - 11:33 AM
Just went back over my build thread mate. I trimmed mine down about 10mm. As I did the same thing and spent hours getting the UC dash out neatly then more hours getting the LX dash out nicely. Then I trimmed it haha
#217
Posted 21 January 2015 - 07:31 PM
#218
Posted 21 January 2015 - 08:41 PM
Feel like I haven't made much progress recently, still got my mind on the car, doing gearbox research and finishing little things that don't show up in photos much.
One of the plans was to lose the handbrake. Welded up the holes so far, but I will also be unpicking the brackets from the underside of the car etc. I want this car to be on a diet even with the heavy driveline and all the shit I'm too stubborn about to do without, so any un-necessary factory bracketry I can get rid of is good haha
Edited by Heath, 21 January 2015 - 08:42 PM.
#219
Posted 23 January 2015 - 10:08 PM
To answer Toranamat69's question, I'm planning on keeping the brake lines going down the guards. I'm so used to seeing them that it just feels Torana-ish to have them. But I don't love the holes through the the tubs too much.
#220
_mello92_
Posted 23 January 2015 - 10:18 PM
#221
I recommend a 3mm grinding disc (old style cutting disc) to gently knock the welds into shape first, brushing the wheel gently across the weld.
Concentrate on only grinding the weld and NOTHING ELSE
Slowly slowly catchy monkey.
If you put the guard back on, you can use your thumb against the top of it to help gain finer control of the grinder, too.
#222
Posted 24 January 2015 - 07:26 AM
Sounds like good advice, though. The guard does go on for some jobs.
#223
Posted 25 January 2015 - 11:21 PM
Used a spare bit of one of the donor front cut's inner guards as it already had a similar compound curve:
#224
Posted 26 January 2015 - 08:19 AM
#225
_parsons5000_
Posted 26 January 2015 - 05:46 PM
