Gtr dash
#1 _Djbj70_
Posted 21 June 2013 - 03:11 PM
Just fitting a gtr dash into my lc, on the back of the gauges are two letters B and S which one is the positive ?
Posted 21 June 2013 - 03:23 PM
B = Battery or +12v
S = Sender Unit.
#3 _Djbj70_
Posted 21 June 2013 - 05:22 PM
Other questions have now arisen,
the temp gauge now goes all the way over and stays there, if I remove the sensor wire it returns back. I've put a new sensor in vdo #320-021. Any ideas ?
Does the back of the cluster need to be earthed ?
Posted 21 June 2013 - 08:14 PM
Yes, the main backing plate of the speedo and tacho has to be earthed and there should be a flat metal earth strap on the gauge mounting bracket on each side that connects to the main backing plate.
Posted 21 June 2013 - 09:52 PM
another tip, run and earth wire from the metal brackets of guages through firewall to engine block, can be attached to loom to look neat
this will stop guage readings changing when you turn lights on or use brake, also flickering when indicator is used
it can be very annoying
Posted 22 June 2013 - 12:23 PM
Djbj70, when you say "new" VDO #320-012 sensor, where did you buy it from?. I was thinking these were getting hard to source?
Posted 22 June 2013 - 12:30 PM
Limo, that problem is usually caused by a poor head light earth connection at the radiator support panel.
Posted 22 June 2013 - 04:36 PM
Have you disconnected the temp warning light test wire (Dk green) from the ignition switch?
Edited by S pack, 22 June 2013 - 04:36 PM.
Posted 22 June 2013 - 10:03 PM
yes I know that but even with good earth there I have had problems, as you know the electrical lighting system /guages /radio /heater earths to body and back to battery through 1 4mm earth strap connected at the headlight point can be quite large current
should be a decent size strap to stop voltage drop but if you want original you use that skinny wire that is part of the terminal connection.
Posted 30 June 2013 - 06:29 PM
Sorry to jump in to the thread, but rather than start another, a question re the "speed nuts" for the screws to hold the dash in. IE: just replaced a bulb in my dash and found the the screw supports/speed nuts/name? were missing. Any idea where to get replacements.
