hi, i have a 1973 lj torana with a 5 seed manual borg warner gear box in it what sort of oil should i be putting in it? the gearbox is quite noisey also what diff oil should i be putting in it? i beleive it has the stock diff in it cheers
3 replies to this topic
_blair_
Posted 10 July 2013 - 03:21 PM
Posted 10 July 2013 - 08:48 PM
BW T5 uses dextron trans fluid usually
But might pay to check
If its noisy its probablt due a rebuild
75-80 or 80-90 Castrol gear oil for the diff assuming its not LSD
_LS1 Hatch_
Posted 11 July 2013 - 07:47 AM
Yep, when I put a T5 into my old Charger it said to use ATF right on the trans from memory.... (My T56 uses it as well..)
Posted 11 July 2013 - 05:52 PM
Is it a T5 or earlier B.W. out of earlier commodore.
Also tagged with one or more of these keywords: gearbox, diff
Holden Tech →
Driveline →
Harrop or SCW TruetracStarted by salamiman , 01 Dec 2023 ![]() |
Holden Tech →
General HB-LC-TA-LJ →
LJ Torana Diff housing identificationStarted by Dickson , 01 Sep 2022 ![]() |
Holden Tech →
Driveline →
9 inch tru trac vs Banjo with Harrop Tru tracStarted by tsn007 , 29 Jan 2022 ![]() |
Holden Tech →
General Questions and Help →
4 speed opel gearboxStarted by _riccardo_ , 08 Jun 2018 ![]() |
Holden Tech →
Driveline →
A9X SUPER T10Started by Rainman , 15 Nov 2016 ![]() |
