I was looking into a 700 or 4l80 but seems every builder has said ill spends lots of $$$$ and still not to strong for what I'm after, I suppose I'm trying to find a good balance of drag/street obviously people say you can really only set up for one or the other but I'm going to try and set mine up so I can still cruise down highway on weekends
and drag when ever I feel like it,
I will be going a th400 but still unsure about a gear vendor. Everything I have read about the GV is they give a like half gear in every gear if you want,
I really want to find out firstly if it is going to even fit for Torana, secondly is like to find out ratio it gives for the 4th gear ( or 3 1/2 gear )
I've Read a GV can handle big massive hp so if I have th400 built super strong a GV should handle as well ??
Also If anyone knows how to calculate what RPM at 100km by using wheel size,diff ratio, transmission ratio. Could you post a link on here please.
