Rusty Lx 4 door rebuild.
293 replies to this topic
#226 slar
slar
  • 498 posts
  • Name:AL
Posted 13 December 2015 - 11:44 PM
Alright small update time.
Havent made too much progress since the last update as my engine went in for machining and due to a backlog of work at the reconditioners it took 8 weeks to get it back.
So whilst I was waiting for the donk to return I spent my time getting a few bits and pieces that I needed  ready for the engine.
First up got my new manifold....expensive but a nice looking bit of gear
Then I decided to install the new radiator......alloy 3 core....good looking unit but not the most expensive.....welds look good so hope it does the job.
Still waiting for the engine so it was time to whip the heads into shape......got them recoed....new stainless valves...valve job...new bronze guides and LT1 springs.....didnt machine any off as they had been done not to long ago and where still straight and where 10 thou undersize which suited the compression ratio I was aiming for.....around 10:1
Finally the engine was ready to pick up.....square decked 15 thou...bored and honed 20 thou over.....new flat top pistons.....hastings moly race rings......hot tanked.....all new bearings.....linnished crank ......new fly wheel.... crane H286 cam.....new push rods and crane lifters.....all rotating assembly balanced and he got it to 0.5 gram overall says the balance computer readout sheet....pretty impressed with the quality of work done and all was spot on.
And yes its all been hot washed with soapy water and cleaned and blown out till no black on the rag from any area.
Got the crank installed...clearances where perfect and end float was 5 thou
Ringed up the pistons and installed them
Time for the camshaft.......checked the cam with a degree wheel to ensure the timing as per cam card was very close.
Ended up 1/2 a degree from spec....close enough for me ....used  a new rollmaster timing chain and sprocket kit with mulit keyway but didnt need to advance or retard so its set to 0 position.
Got the heads on and tensioned up.....all is fitting very well
Installed all new brass welsch plugs....cam plug and gallery plug
Decided to have a mock up evening just to check the fit of all the bits that need to go on the engine.
Even got my newly refurbished quaddie out for look.....im happy with that
Fitted up the new sump with a one piece neoprene gasket......it fitted perfectly...was a bit worried since its aftermarket.
Ok all looks good....time to mask her up ready for paint
Hit it with a splash of 2k Rocket Red after etch priming it and there you have it....beautiful.
Not sure what colour to paint the rocker covers or leave them Rocket red....they are VN rocker covers and they need painting...Im not sure about black just doesnt look right to me.
Any way thats it for now but heaps more to come
Cheers Al...... enjoy
#227 Ice
  • 15,200 posts
Posted 13 December 2015 - 11:58 PM
Paint the rocker covers red to Al it will look more factory if thats the look your going for
buy the way awesome work as usual
what brand is the radiator Al
#228 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 14 December 2015 - 12:22 AM
Engine looks fantastic. Well done
I know what you mean about the rocker covers, I think there would definitely be a market for early head looking rocker covers that fit VN heads.
#229 _parsons5000_
_parsons5000_
Posted 14 December 2015 - 07:36 AM
make sure u get good earth to block , using 2 k especially
#230 _Mox_
_Mox_
Posted 14 December 2015 - 09:34 AM
Great stuff, rusty is sitting under the covers waiting patiently, i bet you cant wait to see what the engine looks like in the engine bay, and better still that first kick and fire up, on a new engine its a bit stressful and gets the heart beating, but there is no better feeling when its all good.
#231 SmacT
SmacT
  • 977 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 14 December 2015 - 12:25 PM
Neat work as usual Al. I also want to know what brand radiator you went with and where from. There's so many of them these days, it's hard to know which to choose!
I vote red or silver (to match the water pump etc) for the rocker covers.
#232 slar
slar
  • 498 posts
  • Name:AL
Posted 14 December 2015 - 08:51 PM
I bought the radiator online....evilbay......took a risk i know but when I got it i was suprised by the quality and Im pretty fussy....looks to be well made and cant find a defect on it anywhere.
The sellers name was Autoparts100....was only $165.00 delivered....obviously chinese for that money but looks pretty good...only time will tell I suppose.
Rightio I decided not to paint my rocker covers at all...instead I hit them with a DA sander and a bit of wet and dry....removed all the factory paint and polished them.
They came up a treat......took 4 hours to do both covers but you"ll need a dremel with polishing wheels to get into the tight areas......other than that Im pleased with the result.
Before...after sanding
After....about 30 mins worth of polishing on bench grinder buff wheel
Both together
Quick mock up...looks good
Al
#233 Ice
  • 15,200 posts
Posted 14 December 2015 - 08:57 PM
Gee your a patient man Al looks awesome
#234 slar
slar
  • 498 posts
  • Name:AL
Posted 14 December 2015 - 09:04 PM
Trust me Gene I get the shits with things like anybody else but I'll give it a go ....if my polishing had failed I just would of painted them lol.
#235 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 14 December 2015 - 09:25 PM
Thanks Al. I will go evilbay at as well, though I noticed yours doesn't have tabs for mounting thermofans which I need. Still, if the $165 option is good so far, a $200 option must be kick-arse, right? :-)
Too work on the polishing. Looks good.
#236 slar
slar
  • 498 posts
  • Name:AL
Posted 14 December 2015 - 09:38 PM
Yeh Im just using one of those high capacity type fans that are fitted to aircon fitted cars......plenty of radiators out there with the extra mounts for thermo fans or shrouds.......picking the right one is a bit of a minefield though.
#237 _Macca97_
_Macca97_
Posted 05 January 2016 - 07:42 PM
looks great mate, keen to here the idle with the 286, the few I have heard have a great sound, I think someone need to make red motor style tappet covers for the vn heads, for the more stock look
#238 slar
slar
  • 498 posts
  • Name:AL
Posted 09 January 2016 - 11:51 PM
Ok time for an update....
Been busy over the xmas break finishing off the engine and finally got 90% of it together.
Needed and engine crane so waited till the boxing day sale a supercheap and got a 40% discount on this crane
Finally got it on the hoist....slipped the gearbox on and got her mounted in the front end K frame
Test fitted the extractors and guess what......the drivers side fouled on the K frame and sway bar...dissapointing.
Had to remove this much to get clearance.....not a big job but fiddly
Passenger side fitted perfect.... clearance all round
All good now....quick coat of VHT extreme heat paint and on they went for the final time.
Whipped up a little trolley to rest the gearbox on and the whole front end is mobile and ready to slip under the car.
A quick check of my lift points on the car and a couple of chassis stands under the rails and where set for the engine install.
Under she goes.....its a good feeling when your finally getting to the end of the road.
Finally back on 4 wheels after 7 years
Pretty happy with the front wheel fit......clears the front spoiler and firewall on full lock.....was a bit worried I might have to cut and tuck but all is good
Spent today sorting the wiring and making battery cables.......a quick power up on the battery and I was lucky...everything works and no smoke in sight.
The air filter was a close fit but the bonnet closes with about 10mm clearance at the front
And today I finally got bitten cause I bought a cheap starter motor.......its a hi torque brand....absolutely no good.
I busted the thing just tightening the bolts up to specs 35ft/bl
Heres the break......just under where the bolts sit.......I was wondering why it wouldnt tension up.......piece of shit chinese casting.
So heres the remedy.......Go buy a proper starter and stop being a cheapskate.
Bosch....well at least I know this one will work.....and it did.
Well thats it for now but the next update will be the first start of the new engine......Im getting nervous lol...wish me luck
Al
#239 Ice
  • 15,200 posts
Posted 10 January 2016 - 12:05 AM
Looks great Al top work but then again i dont expect anything less from you
Cheers G.
#240 _j.e.d._
_j.e.d._
Posted 10 January 2016 - 07:27 AM
Good god damn that's amazing Al !!!
Got the update thru my phone but had to look at it on the bigger screen to appreciate those pics man. Nearly there!
#241 _Mox_
_Mox_
Posted 10 January 2016 - 10:04 AM
There a nice set of legs sticking out in one pic, and the car doesn't look to bad either, LOL. Hopefully i will be doing this at some stage this year, when i do i will come back and check these pics again, looks like a good idea to bolt a chain across the front of the chassis rails to lift the car. I was going to put a length of channel under the rails an lift the car with a sling, but your way would be more secure, no chance of slipping, good stuff..
#242 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 10 January 2016 - 10:56 AM
I've been wondering the same with lifting the front of the car - Thanks for showing us that AL
Getting there mate and as usual looking Awesome - good luck on your start up can't wait to see a vid on the first test run.
Cheers Az
#243 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 10 January 2016 - 12:42 PM
What is it with LX/H Toranas and extractors? Why don't the buggers ever fit?
Great update. Pity you didn't ask to borrow my engine crane - I would have delivered to have a perve on your car! :-)
#244 _Bomber Watson_
Posted 10 January 2016 - 02:18 PM
LC/LJ ones never fit either, so dont feel bad.
Good work mate.
#245 slar
slar
  • 498 posts
  • Name:AL
Posted 10 January 2016 - 09:36 PM
Im getting worried about you blokes........perving.......and nice legs......your not a couple of lady boys are you lol....jeez
#246 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 10 January 2016 - 09:46 PM
Don't knock what you haven't tried, Al. Ha ha.
#247 slar
slar
  • 498 posts
  • Name:AL
Posted 10 January 2016 - 09:47 PM
I think Im gonna be sick......
#248 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 10 January 2016 - 09:51 PM
Id stick to the car Al, that's obviously where your talents are :) looks fantastic
#249 slar
slar
  • 498 posts
  • Name:AL
Posted 10 January 2016 - 09:56 PM
I intend to Mav.....no time for silly business lol
#250 Ice
  • 15,200 posts
Posted 10 January 2016 - 10:12 PM
Watch him ????
