Wilwood - Dynalite Pro - 4 Piston Front Brake Kit - 140-10996-DP
17 replies to this topic
#1 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 05 August 2013 - 04:52 PM
The time is coming soon to upgrade from standard front brakes to a more high performance application.  (street/club circuit)
I'm wondering if anyone has bought & installed this type of kit & are they satisfied with them? I still want to use my 14x8" 14x10" Hotwires atm & the wheel will just fit over using the 11" rotor (HQ size). The rotor has a third PCD option so it allows me to have it drilled the Torana stud pattern. The other bonus is the rotor already has the HQ stud pattern if I wish to change wheels in the future. Your feedback will be appreciated.
Ando
#2 dattoman
Posted 05 August 2013 - 09:52 PM
Too small for any real track work
Caliper clearance might be an issue
#3 _datpsi_
_datpsi_
Posted 06 August 2013 - 10:36 AM
Ran hq rotors and calipers on am old lj race car... Required ducting and rotors only lasted 3-4 race meetings.. With right pads pulled up great!
#4 _Romper_
_Romper_
Posted 06 August 2013 - 11:07 AM
I've heard Willwood brakes are Not Legal in Australia as they don't have dust boot's or similar, Wanted to buy some for mine but turned off when told they are illegal...
Anybody confirm...
#5 dattoman
Posted 06 August 2013 - 08:18 PM
Theoretically correct
But Wilwood does do many calipers with dust seals
However none were ever factory fitted to a car and have no ADR approval
So with any brake upgrade engineering/rego approval would be required on a case by case basis
#6 _05-BROCKY-05_
_05-BROCKY-05_
Posted 12 August 2013 - 11:16 PM
Castlemaine offer a full front end with Coilovers and the option of a wilwood brake setup and give engineers certificate with them, could issues with rego still arise if these are used?
#7 _LXSS350_
_LXSS350_
Posted 12 August 2013 - 11:32 PM
The certificate CRS give is not a licensing fitting approval. You still have to get an engineer (in your state) to approve the fitment of the CRS kit.
Edited by LXSS350, 12 August 2013 - 11:34 PM.
#8 Bigfella237
Posted 12 February 2017 - 09:17 AM
Apologies for the thread resurrection but I'm looking for a definitive answer on whether brake calipers MUST have dust seals or not?
I see that NCOP5_Section_LG_Brakes_V2_01Jan2011 (page 9) says: "Caliper pistons must be fitted with dust seals."
But I've searched through both the Second Edition ADR 31 & Third Edition ADR 31/03 and I can't find any reference to dust seals in either, so I'm wondering where the reference in NCOP5 came from?
Anyhow, based on the assumption that most engineers will go by the NCOP, I've been to Wilwood's Caliper Listing and none of the calipers that suit my application have dust seals (some do but the ones I want don't).
And I've been to AP Racing's Caliper listing and the only calipers I can find there with dust seals are some of the "Rally Raid" range, which is not exactly what I'm after either. I see quite a few cars here fitted with AP Racing brakes, so how are you getting these engineered (or are you not)?
Don't even ask about Brembo, their website sucks the big one, it's absolutely useless for custom applications. If somebody can point me to a technical listing for Brembo I'd be grateful, all I can find is a listing based on car models?
Do all Brembo calipers even have dust seals?
Or will it simply be a case of finding an engineer who doesn't care about dust seals... which is unlikely as most seem too concerned about covering their ass to make an independent decision (not that I blame them)?
#9 dattoman
Posted 12 February 2017 - 09:42 AM
Brembo caliper (road calipers) have dust BOOTS
AP's have whats called a DIRT SEAL on a lot and a dust BOOT on others (newer variants)
The AP dirt seal looks alot like the normal hydraulic seal and is inside a groove in the body
Both calipers with dust boots clearly look like boots like on a normal road caliper
Racing calipers don't have dirt seals or boots usually
WHat caliper do you actually want ?
#10 _mervx_
_mervx_
Posted 12 February 2017 - 09:51 AM
HI, been in this position myself. I got some JBT calipers that I might fit in the future, or have a look at  Hi Spec motorsport. They are an English company and have a good range and priced not bad.
#11 _datpsi_
_datpsi_
Posted 19 February 2017 - 10:51 AM
Or best and cheapest upgrade we've done to Coulee escorts is the nissan/subaru 4 pots..
#12 Bigfella237
Posted 19 February 2017 - 08:45 PM
Sorry, just realised I forgot to reply... I'm kinda restricted with my options...
I'm using the Strange Engineering F5010 full-floater on my diff housing, problem is, it's designed for one particular Wilwood brake kit only...
...with 4 piston Forged Narrow Superlite calipers...
Forged_Narrow_Superlite_4_Radial_Mt-Nick
...but obviously they don't have dust seals. They are a radial mount @ 152mm centres (which seems to be a fairly standard size) so I'm wondering if I can maybe buy the Wilwood kit without the calipers and find another brand of caliper (with dust seals) that will bolt on?
#13 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 19 February 2017 - 10:17 PM
I have same floater kit which included the
brake package and my calipers have
the boots.they are 4 piston dynalite pro
series...p/n 120-6806
Attached File  1487506372521-2075023620.jpg   157.07K   1 downloads
Checkout on john langs site (pro9) and you will see the floater kit..
Edited by madtoranajzedded, 19 February 2017 - 10:18 PM.
#14 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 19 February 2017 - 10:26 PM
Actually mines the street floater kit was
around 3400 from memory
Attached File  1487507206125-1474559042.jpg   111.5K   1 downloads
Edited by madtoranajzedded, 19 February 2017 - 10:27 PM.
#15 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 19 February 2017 - 10:29 PM
Attached File  14875073221021573213871.jpg   189.79K   3 downloads
#16 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 19 February 2017 - 10:38 PM
Looks a little different to yours bigfella
My rotor is only 12.19..i gather you are
running 17s or something.looks huge bud..
Attached File  20160219_165820.jpg   634.35K   2 downloads
Edited by madtoranajzedded, 19 February 2017 - 10:55 PM.
#17 Bigfella237
Posted 19 February 2017 - 11:16 PM
Looks like the same brake kit except for the calipers and mounting brackets, yours are lug-mounted, the one I'm looking at has radial-mount calipers.
The lug-mount brake kit (120-12420) is US$840 but the radial-mount brake kit (140-12435) is well over twice the price at US$1955
Although that doesn't really make sense because the Dynalite (cheaper kit) calipers sell for US$189ea and the Forged Narrow Superlite calipers sell for US$324ea, the difference is only US$270 ($135 x2) but the difference between the two "kit" prices is US$1,115
Something doesn't add up? Going by those prices (which all came from the Wilwood website) it would be cheaper to buy the lug-mount kit, throw those calipers in the bin and buy the Radial-mount calipers separately? That should leave you with US$467 to buy (or make) the radial mounting brackets, surely they couldn't cost that much?
EDIT: Okay I see what you're saying, your rotors are 12.19" dia to suit 15" wheels (according to Wilwood) and the kit I priced have 12.88" rotors to suit 17" wheels, so a little difference in price there too.
Edited by Bigfella237, 19 February 2017 - 11:26 PM.
#18 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 19 February 2017 - 11:42 PM
Wow thats not right hey.that radial bracket
must be heaps.and the thicker rotor..
Yeah the whole kit is a ripoff i reckon.
caliper pads are rather small but seeing it
was a package there is no muck arsing around
+ they had the boots to pass the engineering
side for street.but your right the radials
would b better but suxs with no boots..
Edited by madtoranajzedded, 19 February 2017 - 11:42 PM.
