Hi, I am having a little trouble getting my temp gauge working.
I have a yellow needle SLR cluster with the temp gauge not working. once disassembled I found needle was glued in place.
I also have a early white SLR cluster with the mph on speedo for spares. I tested temp and fuel gauge with 10 ohm resister and went to full hot or full tank so seems to work ok.
Then I dismantled the white one and changed parts to yellow one put back together and testing with 10 ohm resister all temp, oil, fuel all moved.
yellow cluster is in car now and wired up. I purchased the VDO temp sender part 320 0003 blue ring.
Warmed car up and no movement on temp gauge but oil and volt gauge work fine. There is no fuel in tank at the moment to test fuel gauge.
I then swapped cables over from temp to oil connections and both gauges work fine but backwards due to the wiring.
Changed back to normal and temp gauge will not move.
Any help will be appreciated.
