Oil pressure gauge not working
52 replies to this topic
#26 S pack
  • 15,743 posts
Posted 20 August 2013 - 12:45 AM
Should I throw the earth wire on it again for a second to make sure the gauge is still working?
By all means, but ensure the gauge is being monitored so the earth wire can be disconnected or turn the ignition off the moment the needle reaches the highest mark.
#27 _LHSL308_
_LHSL308_
Posted 20 August 2013 - 12:57 AM
No worries Dave I will do it tomorrow and report back.
#28 S pack
  • 15,743 posts
Posted 20 August 2013 - 01:13 AM
You'll find with the sender wire earthed the needle will rise quickly, so be ready to terminate the test.
It would be better and safer if you could get a 10 ohm resistor to connect in line.
Edited by S pack, 20 August 2013 - 01:15 AM.
#29 _LS1 Hatch_
_LS1 Hatch_
Posted 20 August 2013 - 09:18 AM
I believe the VDO part number is 360-005 for the LH/LX oil pressure sender. Someone please correct me if I'm wrong.
Yep, that is the one I had bought for mine, and works perfectly.
#30 _LHSL308_
_LHSL308_
Posted 20 August 2013 - 11:21 AM
Where did you get that one from Jeff?
#31 _LS1 Hatch_
_LS1 Hatch_
Posted 20 August 2013 - 11:32 AM
Bursons....where else? :D
#32 _LHSL308_
_LHSL308_
Posted 20 August 2013 - 11:55 AM
Ofcourse silly me :spoton:
#33 _LS1 Hatch_
_LS1 Hatch_
Posted 20 August 2013 - 12:00 PM
:spoton:
#34 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 20 August 2013 - 12:39 PM
get someone to help you and just touch it on or get about a 10 - 16 watt globe and put in series between the lead and the terminal
#35 _LHSL308_
_LHSL308_
Posted 20 August 2013 - 09:47 PM
Tried the gauge again tonight with the help of the wife. Earthed a wire from the earth on the engine to the wire connector and luckily the oil pressure gauge still works. Thank god I didnt stuff that up. :D
#36 S pack
  • 15,743 posts
Posted 20 August 2013 - 09:53 PM
Good news. A new oil sender should see it all back in action then.
#37 _LHSL308_
_LHSL308_
Posted 20 August 2013 - 10:28 PM
Actually while I am here, at what position should i hope to see the needle on the gauge when its all working again?
New oil sender is on order, hope to receive it by the end of the week. Cheers you guys are legends :spoton:
Edited by Gonedeaf, 20 August 2013 - 10:30 PM.
#38 S pack
  • 15,743 posts
Posted 20 August 2013 - 10:46 PM
Can't answer that one for you, LJ's have proper instruments with numbers on them. :stirpot:
#39 _LS1 Hatch_
_LS1 Hatch_
Posted 21 August 2013 - 12:39 AM
LX's are far superior....all those numbers just distract you when you are going fast :P
#40 _LS1 Hatch_
_LS1 Hatch_
Posted 21 August 2013 - 12:42 AM
Depends on the engine condition I suppose, oil you run, etc, etc.  I would say over all, somewhere between 1/4 and 3/4 perhaps. Obviously when it is hot and at idle it will be lower, and as you bring the revs up the pressure should climb some.
#41 _LHSL308_
_LHSL308_
Posted 21 August 2013 - 11:37 AM
Brand new engine which has only got 800km on it so far, still running it in. Not sure what type of oil is in it but I think it is some special oil that is used for the initial running in of the engine.
Gotta take the car back to the mechanic at 1000kms so the oil can be changed and a few other things need to be done possibly something to do with the solid cam. Come to think of it we need to put a higher temp thermostat as the 160F one is too cold, modify the car to run 12V at the coil, might change the plugs too as well as a few other things that dont come to mind.
#42 _The Baron_
_The Baron_
Posted 21 August 2013 - 01:05 PM
Earth the wire then have a look at the gauge. It should have moved to full pressure. If not the problem is elsewhere.
If you do this, do it for a very short time or you can stuff the gauge or voltage regulator.
Best to use a 10-70 Ohm resistor in series with the connection to earth and that will mean you can take your time waiting for the gauge needle to rise.
I wonder what other earths have been stuffed? Like the one onto your dash (back) mounted voltage regulator.
Your temperature and fuel level are also supplied from the voltage regulator. If they are OK, maybe check with a replacement sender. Your should be able to swap the oil and temperature wires at the senders (within the engine bay) to help with the fault finding.i.e gauge or sender being the cause. (of course you may need a couple of lengths of wire to do this)
Good Luck.
#43 _The Baron_
_The Baron_
Posted 21 August 2013 - 01:08 PM
Ah  bugger, missed there was another page. I hate accessing the WEB when in remote locations!
#44 _LHSL308_
_LHSL308_
Posted 21 August 2013 - 01:25 PM
Haha good one Baron. Thanks for your help though mate even if it was already mentioned.
#45 _LS1 Hatch_
_LS1 Hatch_
Posted 21 August 2013 - 01:26 PM
... I hate accessing the WEB when in remote locations!
I suppose Australia is pretty remote....but you guys seem to make due ok. ;)
#46 _The Baron_
_The Baron_
Posted 21 August 2013 - 10:14 PM
One week Eromanga, south west Qld (great place, wonderful people), next week Tirrawarra in the Cooper basin (search for Moomba Jeff).
The wild life around Eromanga is incredible, wallabies, kangaroos (including Big Reds), cattle, pigs, cats, emus, sheep, horses, goats, wedgetails, brolgas and every other bird of prey. There was wild life behind every bush, could not travel faster than 40-60 in most areas. There was road kill at the exit to town which was fresh every day for the resident pair of wedge tail eagle!
Found a shed in Moomba with around 20 barn owls (I think that was the type of owl, light brown with a white face). I have seen inland taipans, browns, king browns (mulga) and woma snakes often.
Makes the job interesting.
#47 _LHSL308_
_LHSL308_
Posted 21 August 2013 - 10:56 PM
Jesus christ Baron, take a video camera out with you and you could actually make some money off what your seeing.
#48 _LHSL308_
_LHSL308_
Posted 22 August 2013 - 08:37 PM
Got the new oil pressure sender today. I will put it on tomorrow night after work and let ya's know how it goes.
#49 _LS1 Hatch_
_LS1 Hatch_
Posted 23 August 2013 - 01:16 AM
Sounds pretty cool ! I will have to do some google map work and get a vauge idea where some of those places are! :D  Lots of critters around it sure seems too !
#50 _LHSL308_
_LHSL308_
Posted 23 August 2013 - 09:27 PM
Replaced the sender unit tonight and thanks to all you guys its working perfectly. Gauge seems to be running at 1/4 to just over 1/2. Once again you guys pull it out of the fire. Thanks all :spoton:
Edited by Gonedeaf, 23 August 2013 - 09:27 PM.
