home made spot welder
8 replies to this topic
#1 _73LJWhiteSL_
_73LJWhiteSL_
Posted 25 August 2013 - 08:58 AM
Gday all,
Was looking up spot welders and stumbled across this.
Thoughts?
#2 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 25 August 2013 - 09:42 AM
Very smart man.......
#3 N/A-PWR
  • 9,639 posts
Posted 25 August 2013 - 10:22 AM
Hi Steve,
Good idea except the heat generated may make your electrodes go soft and bend away,
I remember an industrial spot welder had 25mm diamenter electrodes about 150mm long top and bottom clamped solid and insulated,
so all you need to do is have a say 10mm diamenter electrode rod with the touching ends turned to a smaller point  say 2mm and clamped solid to a heat resistant insulator. Dave I
p.s. after typing this I though I better check out if I was leading us in the wrong direction and found this:-
Attached File  Spot Welder.jpg   15.41K   4 downloads
http://www.ebay.com/...Y-/270675536704
see the Duty Cycle is only 30%, which means use for 10 minutes and wait 20 minutes before use again I think?
where as your one could be 100% with beefy parts.
Edited by TORYPOWER, 25 August 2013 - 10:35 AM.
#4 N/A-PWR
  • 9,639 posts
Posted 25 August 2013 - 10:39 AM
Crikie, found this:-
http://mods-n-hacks....-cheap-0140873/
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 25 August 2013 - 11:11 AM
I got one of these from e-bay.
http://www.ebay.com....#ht_2763wt_1161
Wasted about 3 hours of my life using my HF inverting Welder on it - made all the right noises and sparks but I am yet to get the bloody thing to actually make 2 bits of steel stick together with it despite many attempts.
I havn't given up yet - maybe I could use the carbon electrodes from mine and use my welder but make up a set of timber clamps like this guy has made and see if that works any better.
#6 _73LJWhiteSL_
_73LJWhiteSL_
Posted 25 August 2013 - 06:49 PM
That's the article version of the video I guess. I was thinking even if you did this home job and used the correct electrodes maybe that would last longer?
I'm just considering options as I will be welding the new outer sills on the LC at some stage and plug welding vertically isn't working out so well.
Also spot welding would look a lot nicer when attaching the new front guards.
Steve
#7 _73LJWhiteSL_
_73LJWhiteSL_
Posted 26 August 2013 - 12:16 PM
The problem with that one Dave is its 110Volt, not 240Volt. Not sure it would work over here.
Anyone used one of these?
http://www.ebay.com....984.m1438.l2649
Steve
#8 N/A-PWR
  • 9,639 posts
Posted 26 August 2013 - 03:02 PM
Yes Steve,
And the trouble with both of them is that they are heavy as having the transformer built in,
so I found this that you could connect your own welding leads too:-
DNY_Series_Spot_Welding_Clamp_For_Spot.j
http://sell.bizrice....ng-Machine.html
#9 _73LJWhiteSL_
_73LJWhiteSL_
Posted 26 August 2013 - 10:56 PM
That looks pretty funky. So I could run that off my House mates mig welder maybe? Didn't even think of that.
Steve
