is any1 here makeing billet pulleys for 308 blocks?
and or know any1 who is?
im looking for a single groove set up to replace my gilmer drive, needing crank alternator and water pump.
Posted 30 August 2013 - 02:26 PM
Posted 30 August 2013 - 10:19 PM
Posted 30 August 2013 - 11:09 PM
what is the price on the above?
can the water pump be done diffrent?
not a fan of the style of this one.
can they be done like this?
can any1 confirm short chev water pumps are the same pulley as holden?
Posted 30 August 2013 - 11:35 PM
Chev is 1.25" between holes
3" from top to bottom on a single pulley
Pump bolt up face is approx 2" 9/16 across
These are short pump measurements
Go measure a Holden... those bolt spacings looks alot wider in those 2 pics above to me
Posted 30 August 2013 - 11:40 PM
http://www.ebay.com....8-/130874691942
http://www.ebay.com....P-/120908443519
http://www.ebay.com....X-/120908444140
Posted 31 August 2013 - 12:01 AM
ive looked at these on ebay. just think there pricey when gilmer kits complete are the price of 1 of them pulleys.???
Posted 31 August 2013 - 02:25 AM
True... but gilmers are poo
And ozys setup is around $450+
Posted 31 August 2013 - 08:16 AM
Posted 31 August 2013 - 12:44 PM
I know people have been crying about the price.
I had a gilmer setup for a few years and ill just give a comparison from my experience, for the same time iv had these billet muilti rib pulleys, I would have been through 2 possible 3 gilmer belts, 2 complete sets of gilmer pulleys as they wear out, and due to the track work I had to slow the water pump speed down which required 2 different sets of gilmer pulleys, small size and large size, so I could use a small crank pulley and large water pump pulley.
so to me these billet pulleys were worth it, I can also get replacement belts easier and cheaper.
quality costs money.
anyone priced a QUALITY set of pulleys for a chev or ford engine, I have and there not cheap.
Posted 31 August 2013 - 07:09 PM
Posted 31 August 2013 - 09:03 PM
The reason serpentine belts have become so widely used by the OEMs is not because they are better, it's just that they are more compact when you have multiple accessories to drive. Back when most cars only had an alternator and fan/waterpump, a single vee belt was fine. Now that most cars have an alternator, fan, power steering and aircon it's much simpler and tidier to run them all from a single serpentine belt.
But for an old car with only the alternator and fan to drive, a single vee belt with steel pulleys is probably the lightest, cheapest and most reliable setup.
Edited by oldjohnno, 31 August 2013 - 09:04 PM.
Posted 31 August 2013 - 09:45 PM
Do you have to run a belt tensioner with the serpentine set up?
Cant it be tightend via the alternator like a gilmer or v belt?
Theoretically you could, but with a flat belt like a serpentine or a gilmer everything has to be very solidly and squarely mounted or the belt will shred. It's usually easier to solidly mount the alternator and run an idler.
Posted 02 September 2013 - 08:39 PM
Posted 03 September 2013 - 06:15 AM
Wouldn't want to get your hand near that top pulley would rip your friggin hand off, or a piece of clothing for that matter.
Posted 03 September 2013 - 12:07 PM
You can use the standard slide adjuster.
I changed this to a double rosé jointed link because I was worried about reliability when racing. Worried the slider would move.
Also made adjusting belt easier.
im just not a fan of the adjuster idea. sorry
can you make the water pump like the pic above?
and single v belt?
Aeroflow make alloy pulleys for holdens
these do look ok to. mite be going with these.
Posted 03 September 2013 - 12:36 PM
Aeroflow pulley's reliable.
