Best 253 - 308 Oil Pump to Buy
Engine Oil Pump 253 308
8 replies to this topic
#1 _Shoey_
_Shoey_
Posted 03 September 2013 - 11:35 PM
Hi all, I need a new High Volume Oil Pump and was looking on the net and found the following -
Austral Part # M308HV
JP Performance Part # JP9491
Speedmaster Part # PCE303.1015
Does anyone know which is the best one to buy or is there another option I haven't seen yet.  They vary in price from $85 to $200.
Or more importantly is there any one of the three that have know issues and I should steer clear of?
Any help would be appreciated.
#2 Ice
  • 15,204 posts
Posted 03 September 2013 - 11:50 PM
Stick with JP you cant go wrong
#3 _Shoey_
_Shoey_
Posted 03 September 2013 - 11:52 PM
Ok Thanks.
#4 TerrA LX
Posted 03 September 2013 - 11:58 PM
Pull it apart and clean it out thoroughly before you put it into service.
#5 _greenmachine215_
_greenmachine215_
Posted 04 September 2013 - 12:47 AM
I had a JP worst thing I could have ever done, High volume doesn't fix the low pressures of the holden motors,
You can ask any engine builder you would be better off getting your standard oil pump blueprinted and the relief valve re shimmed, and it costs half the price of a JP
#6 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 04 September 2013 - 10:48 AM
See this tread from AussieV8 some good info ih here about blue printing the oil pump. You could do this to the existing one as greenmachine has pointed out or buy an new std JP pump and do the same if your original one is too far gone.
http://www.aussiev8....rmance-use.html
#7 slr5640
slr5640
    XA9X
  • 798 posts
  • Name:Brian
Posted 04 September 2013 - 05:18 PM
How about COME racing,,,they list a blueprinted one..
http://comeracing.co...ump-blueprinted
#8 gtrboyy
gtrboyy
  • 3,215 posts
Posted 04 September 2013 - 05:42 PM
STD pump if you can then pull it apart to check/blueprint like in aussiev8 thread lots of good info on there.
#9 _Shoey_
_Shoey_
Posted 05 September 2013 - 01:04 AM
Awsome, thanks guys lots of useful info.
Also tagged with one or more of these keywords: Engine, Oil, Pump, 253, 308
