DIY tools
106 replies to this topic
#51 76lxhatch
  • 7,205 posts
Posted 10 September 2014 - 08:55 AM
The other side of the master cylinder lid for those interested
#52 _76lxJAS_
_76lxJAS_
Posted 10 September 2014 - 02:34 PM
cheers thanks mate, do you have a pressure gauge in this set up also?
#53 76lxhatch
  • 7,205 posts
Posted 10 September 2014 - 03:32 PM
You can see it in the first photo green thing hanging out the left side of the bottle
#54 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 10 September 2014 - 06:00 PM
I did a similar thing on a HR Holden plastic reservoir when I was a youngster.
Stuck a compressor fitting into a lid and screwed it on.
The plan was to pressurise the cylinder with air and push the fluid through.......
Hit the air and blew the whole thing to bits....shit puckin everywhere...
oops........
#55 rodomo
  • 18,037 posts
Posted 10 September 2014 - 08:39 PM
This is nothing new but I've just used it for the first time today and its magic - pressure brake bleeder made from a $10 weed sprayer and some bits and pieces I had laying around
I had one of those but I used it to pump gear oil into the aussie.
#56 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 11 September 2014 - 07:18 PM
Anyone made a decent valve spring compressor ? I made one that bolts to where the rocker arm bolts but its to awkward to put the valve seals in .
#57 rexy
rexy
  • 3,739 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 29 September 2014 - 05:24 PM
Made this out of shed debris to remove and refit the outrigger rubbers in the hatch. The big silver bit is a piston out of an LX caliper.
#58 rexy
rexy
  • 3,739 posts
  • Name:Rexy
Posted 29 September 2014 - 10:24 PM
Home whittled spigot bush removing tools.
#59 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 29 September 2014 - 10:40 PM
Hammered in with grease in front?
#60 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 30 September 2014 - 07:58 AM
Wet news paper works ok as well.
#61 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 30 September 2014 - 04:37 PM
The spanner used for getting at those ever so easy to get at top bell V8 housing bolts when just lifting the
engine out.
#62 rexy
rexy
  • 3,739 posts
  • Name:Rexy
Posted 02 October 2014 - 01:37 PM
Yep. Scrape it up and put it back in the "dirty" pot for next time. Using grease seems to help with the wood staying intact compared with the wet newspaper.
#63 _Sandpit Daz_
_Sandpit Daz_
Posted 08 October 2014 - 07:38 PM
This is more like equipment but there home built.
#64 _judgelj_
_judgelj_
Posted 08 October 2014 - 07:53 PM
I like this wheel stands. Very sturdy!!
How does the spigot removal tool work? What is the newspaper method?
#65 _CraigA_
_CraigA_
Posted 08 October 2014 - 08:01 PM
Grease and rolled pieces of newspaper forced in behind spigot then a drift used to push through the bush centre.
Hydraulic pressure pushes the bush out. Easy and effective.
#66 _miki76lx_
_miki76lx_
Posted 08 October 2014 - 08:37 PM
Instead of using grease you can use wet paper  make like a pulp it is very effective and not as messy.
Also have used a sllde hammer to remove the bushes as well.
#67 _Duke88_
_Duke88_
Posted 11 October 2014 - 05:35 PM
Im not too sure if this counts as a tool but I whacked this together as a way of moving the shell around the workshop with an earth mover with tow ball attachment.
Duke
#68 dattoman
  • 16,487 posts
Posted 11 October 2014 - 06:27 PM
You can use bread instead of grease and paper too...just so you know
I made something similar for moving the hatch about
#69 _76lxJAS_
_76lxJAS_
Posted 11 October 2014 - 09:50 PM
torana hatch tricycle, love it mate,
just need a motor and some cables to the bars,
#70 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 28 October 2014 - 05:27 PM
I made this offset measuring tool for when I worked out the wheel offsets for the hatch.
I was pretty nervous while the wheels were being made, but it worked well. :D
10551060_456022941201271_638211772399475
Cheers Paul.
#71 N/A-PWR
  • 9,637 posts
Posted 28 October 2014 - 05:38 PM
Like Button for you Paul,
we did see your work earlier, but now is great too.
Cheers Paul.
Just wondering if you accounted for spring compression as well?
#72 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 28 October 2014 - 05:43 PM
I also made this rim splitter for when I widened some 13" Torana rims.
I'll have to show you the end result, it's only fair. :D
Cheers Paul.
#73 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 28 October 2014 - 05:46 PM
That apprentice is earning his money...
Great jig.
Cool looking wheels.
How did they balance up?
#74 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 28 October 2014 - 05:49 PM
On the rear, no, but on the front I did, all I did was take out the spring and move the hub up and down making sure it didn't clash. :)
Great jig.
pretty good, Craig, nothing a little lead wouldn't correct. :)
That Apprentice is my son Stephen and he is a tradesman, but was all good, we had a play day. :D
Edited by its Paul, 28 October 2014 - 05:52 PM.
#75 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 28 October 2014 - 05:50 PM
The wheels or the apprentice? lol
