They fit i ordered them to suit comm pattern
3 1/2'' BS rims?
#26
_BOURKEY400_
Posted 15 September 2013 - 02:22 PM
#27
Posted 15 September 2013 - 03:48 PM
Give Rocket Industries a call and ask them which standards if any the Weld Draglite rims comply with.
http://www.infrastru...Jan_2011 v3.pdf
Under the NCOP pg 20. replacement aluminium alloy rims must comply with one of the following standards.
Wheel Industries Association (Australia) (WIA)
Standards Association of Australia (SAA)
Technischer Überwachungsverein (TÜV)
Japanese Industrial Standards (JIS)
I expect that even if the NCOP does not apply in your state if a rim complies with one of the above standards it should be legal.
Are your wheels Ridler Draglite or Weld Draglite?
Edited by ls2lxhatch, 15 September 2013 - 04:03 PM.
#28
_LHSL308_
Posted 15 September 2013 - 04:21 PM
Looking at that pdf it sounds like it could be 2 things. Firstly it could be the tyre aspect ratio between the front and rear being more than 10, fronts are 65 series and rears are a 50 series. Secondly it might be the width of the rear tyre being more than 30% wider than vehicles manufacturers widest optional tyre, being a 265 my guess is your around 30mm over what is allowed.
Either way Dan like I said get some standard rims and you'll be good to go.
#29
_BOURKEY400_
Posted 16 September 2013 - 09:32 AM
Thanks for info i will check it out... weld draglite
#30
_gear_head69_
Posted 28 October 2013 - 06:06 AM
