Hi, I'm putting an injected 5l into my lx. Engine is from a VS commodore.
What do,I have to do to the fuel tank to get the fuel pumping.
Internal swirl pot? Lift pump? Or is there an external pump that will do the job.?
Can anyone suggest someone in Queensland that can set tank up?
2 replies to this topic
_m_att_
Posted 20 September 2013 - 05:05 PM
_GreenLH LS3_
Posted 15 December 2013 - 03:24 AM
Hi not sure if your still sorting your tank out out but I've just pulled my modified standard one out to go a droptank, I cut the ring out of a commodore tank ang tig welded it in original spot it's got the commodore in tank pump fitted if your interested in the whole tank. I also have everything else you would need as I just pulled my injected 5 litre out to go ls3
_greenmachine215_
Posted 15 December 2013 - 12:58 PM
From your fuel tank feed line, just run an inline efi filter then carter black as a lift pump to your swirl pot feeding the top then line out from the bottom of the pot to something like a bosch 044 and feed line straight to your engine, then return line from your fuel rail run your regulator inline and return back to swirl pot at the top then overflow from the swirl pot back to tank
Your gonna want to have a swirl pot that has 3 fittings ontop and one on the bottom. You can use an existing fitting on the fuel tank as an overflow return from the swirl pot.
There's a few threads on here how some of us have set them up.
Edited by greenmachine215, 15 December 2013 - 12:59 PM.
Also tagged with one or more of these keywords: Engine, fuel
Holden Tech →
Engine →
Some Advice Re 202 Blue .Started by mandytory , 14 Apr 2022 ![]() |
Holden Tech →
Engine →
202 very rough idle at lights while in DStarted by avoidev , 19 Jan 2022 ![]() |
Holden Tech →
Engine →
2600N engineStarted by stealthxu1 , 28 Jul 2021 ![]() |
Holden Tech →
General Questions and Help →
Fuels, V-Power quality?Started by _scoops_ , 26 Apr 2017 ![]() |
Holden Tech →
Engine →
LH 6 Cylinder Engine DecalsStarted by _fuzzslr3300_ , 08 Nov 2015 ![]() |
