I’m no professional but Yep as said ^^ basically aim for equal angles at either end (within reason) & more than 0.5 degrees to make the needles roll.
This is always good to watch too
https://youtu.be/Idk3BVDVHq4
Thats Great.... thanks Trevor
Posted 05 April 2021 - 04:07 PM
Posted 05 April 2021 - 09:30 PM
Posted 06 April 2021 - 10:39 AM
straight will cause harmonics and the unis to collapes
Posted 07 April 2021 - 07:48 AM
Uni angles rob power and uneven angles between front and rear is where harmonics generally start. Most new vehicle designs have the drive line and tail shaft all inline and driven with rubber doughnuts on both ends. You don't have to worry about harmonics and uni joint rollers ware. Most drag cars have zero or very low uni working angles for performance, but unis are checked and replaced regularly.
Posted 24 April 2021 - 11:18 AM
Does anyone know if there is a place that refurbished door catch mechanisms. Got a couple of springs that need replacing and rust. Or How hard is it to replace the Springs??
