Hey all? Im wondering if a UC (sedan) tank will fit in the LH (sedan)?
Posted 06 October 2013 - 07:12 PM
Posted 06 October 2013 - 10:18 PM
#3 _Yella-5000_
Posted 06 October 2013 - 10:35 PM
^ That's cause the UC ones sit to one side, as the spare tire is on the side in a UC. Having said that, prolly not, as it won't have the LH/LX spare tyre curvy bit toward the front of the car. I have a UC and an LX one here if you want me to look.
Posted 07 October 2013 - 04:16 AM
all good thank you gents
#5 _j.e.d._
Posted 07 October 2013 - 07:04 AM
Do you have a drop tank or standard tank in your car mate?
Posted 07 October 2013 - 08:26 PM
just the standard one mate. would love a drop tank but that car has a few other priorities right now
butted because there was a drop tank on trademe a few weeks back - but know i needed it then
#7 _j.e.d._
Posted 08 October 2013 - 03:12 AM
Sweet as. I've got a spare drop tank here if you're after one at some stage (stainless). I'm not in a rush to get rid of it so whenever you're keen mate & it'll be cheap too.
I understand priorities with getting stuff sorted mate. You should start up a build thread with all the little improvements you do to your car
Posted 08 October 2013 - 09:09 PM
how much for the drop tank - in case mine is beyond repair?
Also what else typically needs changing to accomodate ? I imagine the straps change but do sender, uptake tube etc swap over or do i need bespoke stuff?
#9 _j.e.d._
Posted 09 October 2013 - 05:00 AM
Gimmie a day or two to get out to the shed & check it out cos I haven't looked at it for a little while, & I'll post some pic's here.
Posted 09 October 2013 - 05:16 PM
cool mate thanks.
Also tagged with one or more of these keywords: fuel tank, petrol tank
Holden Tech →
Engine →
17 Gallon fuel tank filler neckStarted by dacastle , 16 Apr 2024 Fuel tank, filler neck |
Holden Tech →
Engine →
Fuel tank 17 GallonStarted by dacastle , 09 Jul 2023 Fuel tank, 17 gallon install, LC |
Holden Tech →
General HB-LC-TA-LJ →
XU1 repro tank sender connectionStarted by _slick50_ , 08 Jun 2015 XU1, Fuel tank |
Holden Tech →
General LH-LX-UC →
Leaky Fuel TankStarted by KiwiRana , 30 Sep 2013 Fuel Tank, Petrol, Filler |
