This is a typical formula used by a simple HP calculator.
HP = ( MPH / 233 ) ^ 3 * lbs
This is the formula used by a simple mph calculator.
MPH = ( (HP / lbs ) ^ .333333 ) * 233
This is a typical formula used by a simple ET calculator.
ET = ( ( lbs / HP) ^ .333333) * 5.825
They are handy calculations to be used as a rough guide but that's about all it is. Relying on a formula with two variables to accurately predict the performance of a car on a drag strip is rather optimistic.
At the end of the day such a simple formula will only be able to produce a rough guess that is not bad for a NA engine. If you have a forced induction engine then it is going to be even more inaccurate. According to the simple formulas a 600 hp 3.0L turbo engine will perform exactly the same as a 600 hp 8.0L naturally aspirated engine over the 1/4 mile.
This is what the parameters for a more comprehensive computer model looks like. If you were to input the figures from a dyno run into this sort of computer model then you would expect it to be reasonably accurate.
You can download a free trial from here.
http://performancetr...ag_race_pro.htm
