Great Man Ryan,
takes time for it all to sink in, but simply,
if you want power = Big Cam, and the bigger the Cam, the bigger the bang
Posted 30 April 2014 - 10:18 PM
Great Man Ryan,
Posted 30 April 2014 - 10:19 PM
I think the cylinder head and intake/exhaust may play a part to Dave....
Posted 30 April 2014 - 10:23 PM
stage 5 coming up DJ
we are getting the facts straight first before we can move on Hey
Posted 30 April 2014 - 10:43 PM
Big bit of Poke in that Cam Jonesy,
I would like to know your inlet port sizes, when you see them next. Dave I
and increase your PSI in the pots by 50 psi too
But I am decreasing your Engine life, so maybe don't listen to me
300psi pots, is my next challenge in the 208
Edited by TORYPOWER, 30 April 2014 - 10:51 PM.
Posted 30 April 2014 - 10:46 PM
Well then why bother asking questions here?
no harm in getting corresponding opinions
Posted 30 April 2014 - 11:25 PM
Sorry mate, must have taken you the wrong way, i saw them as statements.
Hard to portray emotions and body language over typed media.
In the first quote you use the term "considering there chamber design"
This put me under the impression you were rather knowlegable in these kinds of things?
As i said, must have taken you the wrong way.
And your dead right, I didnt even know what a compression ratio was when i joined this forum 12 years ago, but its all been covered in depth in several threads since then.......
Cheers. still dosent understand understand about c/r after 12 years.
still dosent understand about c/r after 12 years.it is a fact.
Posted 01 May 2014 - 06:45 AM
How much total timing are you running?
Posted 01 May 2014 - 07:12 AM
Posted 01 May 2014 - 09:55 AM
If you are using NO2, 25°-28°, but NA I'd be aiming for about 32°-35°, which is what I was using when I run petrol & 10.8cr & the 12 port head, now I'm using methanol I've tried 30°-40° with no changes in et,mph or any other issues, so I keep setting it at 34°.
When you are on 98 are you using an additive as well?
The 12 port motor that I have does ping a little if no additives are used, if it's on avgas no issue. Nulon Pro-strength is what I use with petrol.
Posted 01 May 2014 - 10:48 AM
Just for comparison, I run 10.5:1 and have total advance around 26-27 deg.
Why would one motor want an extra 5+ degrees over another?
Posted 01 May 2014 - 11:05 AM
Posted 01 May 2014 - 12:36 PM
Lots of things come into play here ie; cam timing, spark curve, jetting , port flow/shape,combustion chamber shape etc. The 12 port motor with it's current cam does ping slightly if the fuel isn't correct, but when I built the motor I didn't get the phasing on the crank checked, & it does show signs of detonation on #5 plug, all the others are clear. I had this same engine in a UC Torana for a couple of years fitted with efi & a 220° cam. I replicated the spark curve in the efi but had to remove a heap of timing out in the middle of the curve then lifted it back up, it still pinged slightly on the dyno so I added more fuel in that area & it was fine after that.
The 9 port motor has 12.5cr fitted with the same 254° cam from the 12 port motor doesn't ping anything like the 12 port does, port shape/flow etc. comes into play.
Oldjohnno may be able to add more to this.
If you can get E85, I'd be using it. I'm playing with E85 in mine at the moment.
Edited by warrenm, 01 May 2014 - 12:41 PM.
Posted 01 May 2014 - 12:49 PM
Posted 01 May 2014 - 02:33 PM
How do you modify the spark curve in a bosch electronic dizzy?? I've never done it!
Mine was done on the dyno but I'd like to do it myself.
I'm guessing Warren is using Delco efi or similar and simply had to plug in the numbers.
Posted 01 May 2014 - 02:46 PM
When it pinged on the dyno what sort of afr where you aiming at? and what made you put more fuel in instead of taking out a little timing? I'm not questioning your methods at all I'm just curious because I have always wondered whether it's better to have a slightly leaner mix with less spark advance or be a little on the rich side with more spark advance.
Posted 01 May 2014 - 05:47 PM
They are a bit of a pain to do but if you are happy with the total advance which like warren said should be about 12deg initial plus 22 deg in the dizzy for a total of 34deg for your combo ,then you can change springs to get your required curve . I kow a bloke not far from here who can set your curve but it will cost for every change . What usually works for me is to have no centrifugal advance until about 1400rpm then have all 22deg in by 3000rpm . You will have to use Nulon pro strength booster all the time though .
Posted 01 May 2014 - 06:10 PM
Here you go Mick
If you have dialed the cam to the cam card and the cranking psi is 180 it sounds like the cam timing is not the major issue at the moment .The aim here is to increase low end torque while keeping or increasing top end power .I agree that you first have to look at ignition total timing an curve ,fuel mixture and su oil and springs . Before changing springs i would try straight sae 30 oil in the dashpots as well as the lighter oil to see what it likes ,mine responds instantly with sae 30 and is a bit doughy with lighter oil .To make it easier get a syringe and a tube to fill and suck out the oil .
Posted 01 May 2014 - 06:16 PM
I used a Delco ecu with a locked dizzy, & adjusted the timing within the tune.
It was a couple of years ago, but I think I was aiming at 12.5 afr & ended up with something like 11 something, I'll have to look at the tune which I'll have a look at tomorrow. I think the timing was less than 20° at the points that we added fuel.
Posted 01 May 2014 - 10:55 PM
Ok so my distributor is set on 12 degrees initial, if i DO have 22 degrees in the dizzy, it should read 34 on the balancer, correct?
Just trying to get my head around this...
Posted 01 May 2014 - 10:56 PM
Posted 01 May 2014 - 11:09 PM
Good Stuff Rob,
I enjoy reading your work. Dave I
Posted 01 May 2014 - 11:27 PM
Yeah good read Rob, i also like reading about someone else's pain & agony over 6 cylinders
Posted 02 May 2014 - 07:03 PM
yep u got it , the way to do this is to plot a graph of rpm in 500rpm increments across the bottom edge and measured degrees running up the page , and also check the total advance as you said .
Posted 02 May 2014 - 07:14 PM
wish, I knew about graphing 30 years ago, but I still remember 17° @ 650 rpm with the Standard Distributor and using the vacuum from a 500 holley and a 41/73 cam. Dave I
my self Dyno Tune found the sweet spot while under power to 7000rpm on the street ( real time stresses )
