Thoughts on this 202 combo
#126
Posted 16 January 2014 - 09:05 PM
Took the old girl for a spin the other night... really strong at the top end. It's pretty descent power until 5k, then it pulls harder (like you've flicked a switch) all the way to 7ish. WAY better than the previous combo felt even with the gas on.
#127
Posted 16 January 2014 - 09:24 PM
Out of curiosity, have you ever had the tank on a weigh bridge?
I think there about 13-1400kg without a driver, but would like a confirmation?
Posted 16 January 2014 - 09:26 PM
#129
Posted 16 January 2014 - 09:50 PM
So were talking a mere 50-80kg more than a LC/LJ?
About the same less than a UC?
Interesting, everyone calls them whales but thats not massive...
Posted 16 January 2014 - 09:54 PM
Who calls them whales??...
#131
Posted 16 January 2014 - 10:02 PM
Lads down at the pub
Depending on what yours weights now, i recon most of the quicker LC/LJ torries would be in the same kinda weight bracket.
i know mine (though it went far from quick) would have been before i pulled it apart again once you factor in the tractor diff and all the other little bibbs and bobbs you throw on, kilo here kilo there 100 grams over in that corner etc.
Posted 16 January 2014 - 10:53 PM
My LJ weighs in at 1120kg, with 8 litres of juice. So your EH isn't that heavy.
#134
Posted 20 January 2014 - 09:26 PM
2 cents noted Kev, they're some good power runs.
Out of interest, any ideas of what your EH weighs??
#135
Posted 20 January 2014 - 09:34 PM
Mine is light, should be around 2200-2250lbs with me in it now i think. I'm only 100lb's though, far from a road legal car
#136
_gmlj6_
Posted 21 January 2014 - 04:59 PM
Something else to remember is torque on the bottle is way different than all motor torque.
#137
Posted 15 April 2014 - 11:06 PM
I've been clocking up some kays in the old girl & she's going pretty well... but FARK ME what does it take to seal head gaskets!!! Even with this mls gasket I've still got a tiny bit of horsepower juice (compression) getting into the cooling system, making the thing boil it's arse off at the most inconvenient time.
Anyways this all became a little more obvious after a night of nitrous tuning...
Was going to try & retention the head when I get a sec but failing that keep an eye out in the "parts for sale" section.
On a different note i thought I'd give E85 a run the other night! Purely for shits & giggles I filled the tank at the servo, then stopped every 3 minutes thereafter to wind out the jet adjuster to give it more fuel. Thank god for su's! So on premium the jets sat down around 1.5mm, on E85 they're at about 7mm. WAY more fuel. I think I've got it nearly good enough, maybe... It goes ok anyway, a little hard to tell without numbers to back it up.
Got some street drags happening here on the 26th so I'm trying to sort out my bugs before then.
_to4turbo_
Posted 16 April 2014 - 12:01 AM
what type of head sealant do you use jonsey?i use hylomar with a 1.6mm copper head gasket never had a problem.
#139
Posted 16 April 2014 - 12:34 AM
I'd be finding some richer needles, remember that E85 needs about 1.5 times more fuel than petrol.
#140
Posted 16 April 2014 - 07:44 AM
No sealant on the mls gasket, it has a micro layer of rubber that does the sealing. I went through all the different sealants when I was running the copper gaskets... got sick of that hence the reason for changing to mls.
#141
Posted 16 April 2014 - 08:59 AM
Hi Jonesy I have a full bodied sedan , injected red motor ,trimatic, bw diff , 15inch wheels and I had it weighed on a public weigh bridge with half a tank of fuel and me in the car it weighed 1362 kgs or 2995 pounds . I weigh about 92 kgs . My Eh is 1270 kgs . I consistently run 14.20 secs at 99 mph . Im trying my hardest to crack 100 mph !!!! They cut the wind like a brick !!! Best of luck .
#142
Posted 16 April 2014 - 02:04 PM
#143
Posted 16 April 2014 - 08:29 PM
I like to know what the LC Torana weights too, when is completed Jonesy,
925kgs is my target. Dave I
#144
Posted 16 April 2014 - 09:03 PM
#145
Posted 16 April 2014 - 09:11 PM
OK Jonesy,
Looking forward to it. Dave I
my next project is the 925kg RAT, and is a 4 Door LC having the rear doors closed in, and here is the Photo Shop of it done by Troy 'UCSLE':-
note, the sill is removed for the side pipes
rear side windows are remade to be 50 odd mm longer
#146
Posted 17 April 2014 - 12:14 AM
My LJ is 1202 with me in it, so less 85kg is the cars weight.
Stoichiometric ratio for E85 is 9.8.
#147
Posted 17 April 2014 - 12:26 AM
E85 is on Tap here now, great Choice Warren,
Need to learn about your Stoichiometric ratio, thank's:-
https://www.google.c....64764171,d.dGI
#148
_to4turbo_
Posted 17 April 2014 - 12:27 AM
go and have a shit before you go racing.just a joke.
#149
_stretchlc_
Posted 17 April 2014 - 11:31 AM
Which is fine if you're totally full of shit I guess!.......can't help ET's that much surely??
#150
Posted 17 April 2014 - 12:34 PM
