Thoughts on this 202 combo
#201
Posted 28 April 2014 - 11:57 PM
#202
Posted 29 April 2014 - 12:03 AM
Get that head breathing Jonesy,
my one made a race motor on any block, that is the key,
and it only had 308 valves, plus 100 thou shaved, 44cc chambers and 250psi pots with a 30/70 cam at the time. Dave I
#203
Posted 29 April 2014 - 02:02 AM
Is the convertor the issue. It seems like there wasn't much until almost the 60ft mark and then it took off.
I don't know much, but just an observation. it sounded like it just needed to launch a thousand RPM higher.
#204
Posted 29 April 2014 - 07:26 AM
Apprecitate the info Mick, and yeah it is early days. I guess my expectations were too high.
I couldnt get it to wheelspin, even if i tried mate. best 60ft time at 2.159, crossing the line at 5k ish at 94.65mph.
Now the only downside is, i cant even let it warm up, do a 1/4 mile pass then return to the pits without the coolant spewing issue...
If you couldn't get it to turn the tyre's on the launch, add air to the tyre's. I'm sure that with some tuning, engine, technique & chassis you'll get some better times.
I haven't had any issues running up to 13:1 compression from an ACL race series gasket.
#205
_SLC186_
Posted 29 April 2014 - 09:39 AM
#206
Posted 29 April 2014 - 10:23 AM
Hi Jonesy whos converter is in it ? All converters are not equal Should come off the line a lot harder !! How modified is your transmission ? Have you been able to check what stall your actually getting ? Not saying this is the problem but all helps in the end . Like I said before with my EH still trying to crack 100 mph !! 14.2 at 99 mph with a similar combo to yours .
#207
Posted 29 April 2014 - 10:49 AM
#208
Posted 29 April 2014 - 11:32 AM
Mines a dominator too !! 4200 stall .
#209
Posted 29 April 2014 - 12:16 PM
Hi Jonesy , out of interest what style extractors or headers are you running ???
#210
Posted 29 April 2014 - 01:53 PM
#211
Posted 29 April 2014 - 10:21 PM
the short motor is bullet proof for now Jonesy,
just start swapping 1 bit at a time after your tuning don't do much better. Dave I
by the way, can you remove another 200 kg's from the EH
#212
Posted 29 April 2014 - 10:24 PM
Yep making it remote control would get you half way there ;p
#213
Posted 29 April 2014 - 10:25 PM
So after doing a compression check, all cylinders achieved between 180 - 190psi, with a couple getting there a little slower than the others (& now I know why).
Carried out a cylinder leak test... or pumped air into each cylinder & with the radiator cap removed, watched for any rise in level.
In short, 5 & 3 are loosing heaps of compression, 1 & 4 lose a tiny bit, and 2 & 6 nil. Great stuff! Guess it's my old friend Mr Head Gasket again, pretty sure i couldn't have cracks in the head on 4 cylinders
Funny crackers arent ya
Edited by SA EH, 29 April 2014 - 10:29 PM.
#214
Posted 29 April 2014 - 10:29 PM
Hi Jonsey,
if this helps, I only used Standard Head Gaskets and no glues, and still got 250psi every time,\
because that Head goes on each Motor and has a 30/70 or a 41/73 Cam. Dave I
#215
Posted 29 April 2014 - 10:32 PM
Yeah Dave im thinking of throwing the gas & running one of my many standard gaskets i have here.
Seems to be the easiest way.
#216
_gorto_
Posted 29 April 2014 - 10:58 PM
Compression is 11.5:1
wow, never heard of numbers this high in a 202 on pump fuel before? Surely there is some detonation? Can someone with greater knowledge than me (so anyone) please explain? lol
Just read the whole thread, very nice mate. You've got a great car and engine combo!
#217
Posted 29 April 2014 - 11:17 PM
hard to work out the Compression Ratio Ryan,
is why we don't hear much about it, but if you go by compression test, you can gather how much compression there is,
so standard is from 149psi and up from there. Dave I
also, I ran Super Petrol up until it was phased out
#218
_gorto_
Posted 29 April 2014 - 11:21 PM
Dad has a 588c.i BBC in his monaro, 11.27:1 comp. He recently had it rebuilt and engine dynoed by the guy who is building my 202. They had to get a digital ignition and pull ignition out arouuuuund about 2500-3500rpms, at a guess. then feed it back into it to avoid detonation.
I couldnt imagine a 202 having very good resistance to detonation considering their chamber design. If dads was detonating at 11.27:1, surely a 202 would at 11.5:1?
Also, please don't see this as me 'bagging' out the engine or anything like that, I'm just trying to gather some info for myself, sorry for the slight hi-jack..
Edited by gorto, 29 April 2014 - 11:23 PM.
#219
Posted 29 April 2014 - 11:25 PM
unleaded too I suppose,
that's where E85 or Methanol comes in
or AV Gas even
More Octane, but I had no trouble with 100 Super, so there is a Key
#220
_gorto_
Posted 29 April 2014 - 11:26 PM
ah yes sorry, forgot to add, on pump fuel, bp 98
#221
Posted 30 April 2014 - 07:33 AM
Keep in mind a lot of guys are running cam profiles that would be unheard of in a big block short of a pro street engine, dynamic comp ratio is the key.
Posted 30 April 2014 - 08:22 AM
And I'd rather sacrifice streetability, fuel economy, and cooling issues with high comp than horsepower any day...
#223
Posted 30 April 2014 - 05:22 PM
Without reading back through everything, what cam are you running?
Maybe detonation has "pushed" the gasket.
#224
Posted 30 April 2014 - 05:32 PM
#225
_gorto_
Posted 30 April 2014 - 06:10 PM
What do you mean by this? Can you please explain further? Thanks
