Oh common man, your alot smarter than this.No water means no expansion.
Waterless coolant
#51
Posted 02 November 2013 - 06:28 AM
#52
Posted 02 November 2013 - 06:33 AM
In stead of quoting anyone's propaganda, why don't you just answer the question I asked you?You can safely remove the radiator cap when the cooling system is at operating temperature. See around 3:30 in this clip.
I think you are pretty much spot on here mate, about the only application this has is in old thermo syphon systems.I have to ask a really stupid question.
I was under the impression the pressure in the cooling system was both to raise the boiling point and to put the water everywhere it needs to be, not where it feels like being.
If you remove the pressure, will the fluid just go where it wants (path of least resistance) instead of going where it needs to be?
^ Try doing that in a commodore without a litre of coolant flowing all over the ground.
#53
Posted 02 November 2013 - 12:49 PM
Which question have I not answered?
I assume you are nit picking about the expansion of Evans Coolant.
The Evans coolant will expand as it gets hotter as it has to obey the laws of physics.
I thought the video demonstrated that the expansion in the Evans coolant is not significant enough to cause the system generate significant pressure or overflow. The video could be a fake however if it was I would expect there would be plenty of videos on YouTube showing the Evans coolant overflowing when you remove the cap.
Water is responsible for the majority of expansion in water based coolants. The water in the water based coolants will expand enough to require the use of a pressure control radiator cap and coolant expansion/recovery tanks.
I am sorry I can't afford to pay for independent laboratory testing to answer your questions. Here is some more propaganda for you. I hope that Rotax have done some testing before they accepted Evans claims.
Rotax Aircraft Engines recommend and in some case require using Evans NPG+ in their 912 and 914 engines.
If however your cylinder head temperature reaches the "hot" range of the third column, the use of Evans NPG+™ non-aqueous (waterless) liquid is mandatory.
The Evans NPG+™ non-aqueous cooling liquid is mandatory under certain circumstances, but we recommend it for every engine since it offers more efficient cooling, an extremely high boiling point, a very low freezing point, corrosion prevention and unlimited life (no need to renew every two years). Also notable is that it operates at no or minimal pressure which greatly increases safety in case of an in-flight leak.
Edited by ls2lxhatch, 02 November 2013 - 01:04 PM.
#54
Posted 03 November 2013 - 02:33 PM
www.norosion.com/evanstest.h
I can copy and paste stuff too, just asked a simple question and hope that some common sense prevales...
#55
Posted 03 November 2013 - 08:58 PM
Hmmm... these sources don't seem to agree! Obviously each is pushing their own agenda so that's not surprising, but the increase in temperature seems quite believable. The graphs above show a very high top end of the "Normal" operating range. The flammability would be a significant concern if there is any truth to that.Cylinder head temperatures of 115-140oF hotter with the Evans products translates to a stabilized bulk coolant temperature increase of 31-48oF, as compared to No-Rosion and water.
The other reason that Evans products are prohibited at race tracks is that they are flammable. They have flash points in the range of 225-232oF. This means that if Evans coolant were released at or above the flash point, it could ignite. Because we observed coolant temperatures in this range during actual operating conditions, this is a real risk.
#56
_DJH308_
Posted 03 November 2013 - 09:10 PM
just to throw in my 2 cents, although it may have a high boiling temperature, prevent steam pockets and corrosion, its hard to beat the specific heat capacity of good ol water with a little antifreeze.
#57
As your last post demonstrates, posting laboratory test results and propaganda/marketing has its value.
The Evans test results for ASTM D-1384 are similar to the results Norosion reported for the Evans coolant so there is no argument there. When it comes to corrosion protection the Norosion test results are better than Evans. Electrolysis is still possible with Norosion however that is reasonably easy to avoid.
http://www.evanscool...rosion-test.pdf
Norosion report that Evans is thicker than water (2.3 cp) verses around 0.7 cp for typical coolant which again is confirmed by the Evans website. It would be reasonable to expect that pumping Evans coolant will require more horsepower than typical water based coolant. I suspect there is a little bit of marketing when it comes to the claimed 4-5%HP loss but I don't doubt there will be a loss.
Based on everything discussed so far the pros don't even come close to outweighing the cons of using Evans coolant. I will stick with my Toyota spec coolant, or maybe look into using Norosion.
#58
Posted 03 November 2013 - 09:14 PM
I believe that Rotax are saying that you can safely increase the hot operating temperature range if you raise the boiling point of the coolant.
The first two graphs show a higher pressure radiator cap (which increases the boiling point) increases the safe hot operating temperature.
Edited by ls2lxhatch, 03 November 2013 - 09:20 PM.
#59
Posted 03 November 2013 - 09:17 PM
I'm with ya on this one buddy but anti-freeze? In QLD? I'm in Melb and have only ever used a straight corrosion inhibitor mixed with water. Castrol. Used to be able to buy it in Woolies here.
#60
_DJH308_
Posted 03 November 2013 - 09:22 PM
sorry rodomo, my mistake i meant anti-boil/corrosion inhibitor just a cause of habit
#61
Posted 04 November 2013 - 07:11 AM
Yep, I was just commenting that this could be convenient for the Evans marketing if their coolant isn't efficient enough to keep temperatures down around the thermostat temp as No-rosion claim.I believe that Rotax are saying that you can safely increase the hot operating temperature range if you raise the boiling point of the coolant.
#62
Posted 04 November 2013 - 11:21 AM
Rotax state that Evans NPG+ provides more efficient cooling. Rotax basically repeat the Evans marketing claims in the next paragraph.
Based on the discussion so far it is hard to believe that Evans coolant is more efficient than all water based coolants. At the same time it is hard to believe that Rotax would recommend Evans without doing their own testing to confirm the Evans marketing claims.
It could be that because Evans can safely run at much higher temperatures than water based coolant this increases the difference between ambient temperature and the coolant temperature thus increasing the cooling system efficiency.
http://www.evanscool...om.au/faqs.html
In a 38°C environment (under bonnet) a radiator that is 121°C will dissipate 25% more heat than one at 104°C.
If you have no choice but to run an engine at 250 F+ then Evans coolant would be more efficient than water based coolant.
Edited by ls2lxhatch, 04 November 2013 - 11:31 AM.
#63
Posted 04 November 2013 - 01:32 PM
Had to laugh at this, one could also say that in a 38°C environment a radiator that is 90°C will dissipate 100% more heat than one at 38°C...In a 38°C environment (under bonnet) a radiator that is 121°C will dissipate 25% more heat than one at 104°C.
#64
Posted 04 November 2013 - 01:53 PM
#65
Posted 05 November 2013 - 11:12 AM
Frack, for what it's worth transmission fluid will cool the engine, it would probably also run over 100deg c but there would still be a cooling effect.
It too would offer 100% no steam or corrosion....
As I said, these things have their place, If I owned a 1900's water cooled thermo syphon system car I would have no doubt I would run such products, but where I want temps in the 90/100 deg C range on my holden V8 then I will stick with the water/inhibitor coolant and only use anti freeze when visiting the snow.
#66
Posted 05 November 2013 - 11:17 AM
#67
Posted 05 November 2013 - 12:10 PM
Some of your ancestors are still arguing the square vs round wheel.
#68
_oldjohnno_
Posted 05 November 2013 - 01:50 PM
OK, I know I said I couldn't look at this thread anymore, but I've been taking my medication and I think I can do this without exploding.
I've had a look at what the Evans people wrote, and I'm forced to conclude that either they are working under an entirely different collection of laws-of-physics to the rest of us, or - more likely - they are being deliberately misleading.
Water has always been the default engine coolant, it's not perfect but as a coolant it's bloody hard to beat. There are two reasons for this, one is that it has a higher specific heat than any almost any other substance. So high in fact that it is used as the standard for specific heat: 1 calorie per gram. Specific heat BTW refers to how much heat can be absorbed or held by a specific quantity (in mass) of a substance.
So far so good. But a high specific heat is only useful if the heat can be conducted into and out of the coolant. Again, water has a very, very good thermal conductivity at 0.58 kW/(m.k).
By comparison ethylene glycol has a specific heat of 0.5 calories/gram and a thermal conductivity of 0.25 kW/(m.k).
If cooling is the only concern then straight water will win every time. Personally I run water with as little glycol as is necessary to prevent freezing; straight glycol isn't a very good coolant by comparison. Of course there are downsides to water - it corrodes, it freezes and it may cause electrolysis. But usually a little additive is all that is required, hopefully not so much as to seriously degrade the waters excellent cooling properties.
Water tends to boil easily at low pressure, but if the system is allowed to run at a moderate pressure (<15psi) then this ceases to become a problem too. Is it a hazard? A gallon or two of hot water at around 10psi doesn't scare me - after all I've got about 300litres of scalding hot water at about 60psi in a tank in my ceiling, and it runs through pipes and taps all through my house. Miraculously, I've managed to not cook myself so far.
Now to the magic Evans stuff. It obviously has a lower specific heat and/or thermal conductivity than water. Actually it's even quite a bit worse than glycol going by their own charts. There is no way that you could say it was anywhere near as efficient as water, and this is highlighted by the significantly higher running temperatures. The only upside that I can see is that if for some reason the engine got very, very hot the stuff wouldn't boil away and you'd be less likely to have localised damage. But wouldn't it be just as good to not let it get so hot in the first place, perhaps by using a more efficient cooling medium?
There is one more thing I'd mention:
Now, it's true that the the volume of heat transferred is in direct proportion to the temperature gradient across the working fluid and the cooling air. But again the numbers are suspect. The difference between (121-38) and (104-38) is about 25%, it's just a shame it doesn't work that way. To get a true answer you'd have to work in absolute temperatures, in this case 394K and 377K. Obviously the real difference is much less than 25%, and the magic waters effectiveness is much less than claimed, less than straight glycol let alone water. They either are ignorant of the laws of thermodynamics (extremely unlikely) or are being deliberately misleading. Again.
Now if you want to run this stuff go for your life, I don't care. I just wanted people to know that there is a bit of a gap between what they claim in their marketing materials and the reality.
Edited by oldjohnno, 05 November 2013 - 02:02 PM.
#69
Posted 05 November 2013 - 06:40 PM
Thank you for that - hard to put it more concisely.
#70
_Ned Loh_
Posted 06 November 2013 - 10:38 AM
interesting read oldjohnno.
any opinion on redline water wetter??? http://www.redlineoi...?pid=74&pcid=10
I don't have any cooling issues (stock std cooling system, except for electric fan), so I've never seriously considered it, but I have heard first hand accounts of positive results, and hence I am curious. As you'd expect, the page is full of carefully worded marketing spin.
#71
_oldjohnno_
Posted 06 November 2013 - 12:27 PM
At the risk of being Captain Obvious, to gain something there first has to be something there to gain....
#72
Posted 06 November 2013 - 12:44 PM
I have always been dubious of water wetter for all the same reasons above. Water is hard to beat on specific heat and thermal conductivity.
#73
_oldjohnno_
Posted 06 November 2013 - 12:56 PM
I guess if you can improve the heat transfer by improving the "wetness" then there's no reason why it wouldn't work. But if there are no cooling issues at present then there really isn't anything to be gained.
If however I had an application where the cooling was marginal I'd have no qualms about adding a bit of water wetter. To me it sounds like a good way to make the most of the water.
#74
_Lazarus_
Posted 06 November 2013 - 01:17 PM
#75
_Ned Loh_
Posted 06 November 2013 - 01:56 PM
Hence I haven't used it as I have no issues...but...i am aware of a person who had a marginal system and swore that the water wetter helped temps (the person I remember, but it must be nearly 10 years ago and forgotten the fine details)
EDIT: Oldjohnno, just saw your next post. So possibly a band aid in marginal system then.
Edited by Ned Loh, 06 November 2013 - 01:58 PM.
