4 degrees negative camber, 1mm toe in will fix it!Maybe i better do some stuff to the LJ before Winton...
I'm at least gonna get a REAL wheel alignment from the place my dad took his 4wd to a few weeks back.
Posted 23 October 2006 - 12:36 AM
Posted 24 October 2006 - 06:50 PM
Posted 25 October 2006 - 12:12 AM
Edited by rodomo, 25 October 2006 - 12:18 AM.
Posted 04 November 2006 - 07:05 AM
Posted 04 November 2006 - 08:25 AM
Posted 04 November 2006 - 10:22 AM
Posted 04 November 2006 - 10:48 AM
Posted 07 November 2006 - 03:26 PM
Posted 09 November 2006 - 05:29 PM
Posted 09 November 2006 - 06:19 PM
Edited by Oldn64, 09 November 2006 - 07:05 PM.
Posted 09 November 2006 - 06:37 PM
Posted 09 November 2006 - 07:07 PM
Posted 09 November 2006 - 07:12 PM
Edited by Heath, 09 November 2006 - 07:15 PM.
Posted 15 November 2006 - 12:36 AM
Posted 15 November 2006 - 01:10 AM
Posted 16 November 2006 - 06:20 PM
It would be great to see you there Yella. Bring the family it is a great day out....I'll return you to Winton. What day is it? Mmm, wonder if Yella feels like a little 3.5 hour drive?
Posted 18 November 2006 - 07:33 AM
Posted 18 November 2006 - 10:49 AM
Posted 22 November 2006 - 11:16 PM
FAILED! The "modify the exhaust" to suit extractors has turned into a front to back fabrication (depression is setting inRangie progress report: The engine is in!
But not running
The wiring is 97.63% done. The 74' Rangie came with 3 fuses and 1 (starter) relay from the factory. Mine now has 5 main fuses, 10 accessory fuses and 5 relays. Still have to mod. exhaust, modify acc. cable and pedal, fit carby and dissy, hook up oil cooler and engine breathers, reassemble dash. Also fit radiator and thermo fan. If I run out of time the standard fan might be going on in the mean time. Hoping to test drive Sat. night down to the servo to pick up a tandem and off to Mathoura Sun.
Edited by rodomo, 22 November 2006 - 11:23 PM.
Posted 23 November 2006 - 01:18 AM
i cant wait!!Stay tuned in Members plans, projects and failures for a thread titled: How to fail at building a Commodore flat tracker in 21 days
Posted 23 November 2006 - 06:35 AM
Posted 30 November 2006 - 11:43 PM
Posted 01 December 2006 - 09:31 PM
Posted 02 December 2006 - 12:15 AM
I thought what your thinking and have rewired the Alt light wire through a relay from the battery so that when I turn the Ign off (which triggers this relay) the batt+ stops feeding the lamp and therefore the Alt. But bugger me I can't start the bitch to see if it turns offRodomo,
Take the feed wire (not the B+ but the D+) off teh alternator and tell me whether the rangie will stop then...
Asking too much as the uni joints are different from teh BW to teh v8 rear. only hop you have is use the front half off a vk and teh rear half off a v8 tailshaft. either that or place the vk tailshaft in with teh vk diff yoke. all in all, good luck.
Posted 02 December 2006 - 12:39 AM
