![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Fitting air con
_Muzzy_
Posted 03 November 2013 - 03:16 PM
Posted 03 November 2013 - 03:21 PM
My LH had aircon, so yes, it is.
_walpolla_
Posted 03 November 2013 - 03:57 PM
Is it possible to fit Air con into a LH.
I actually have an aircon setup for an LH sitting here. Not fitted - its in the "too hard" basket.
I had big plans, but - you know how it goes.
regards,Rod
_Gunmetal LH_
Posted 03 November 2013 - 04:03 PM
Anyone fitted aircon off something else to a Torana? Seems the later model stuff has a lot less bits?
_Muzzy_
Posted 03 November 2013 - 04:17 PM
regards,Rod
regards,Rod
Insterested in selling the set up, is it for a 6 or v8, not that it matters
Posted 03 November 2013 - 04:29 PM
I have early Commodore stuff here. The plan is to have a crack at fitting it to the LJ..................one day.
_sloffador_
Posted 03 November 2013 - 05:18 PM
I have a genuine a/c unit that im putting in my lh
_Gunmetal LH_
Posted 03 November 2013 - 05:33 PM
rodomo what model is it from and does it 'look' like it will fit?
_sloffador_
Posted 03 November 2013 - 05:37 PM
It will fit you replace the existing fan unit under the bonnet with this one and it ducts into
the car via the heater box but I have the vacuum operated box with the correct a/c controls
ill post some photo's if you want
_Muzzy_
Posted 03 November 2013 - 05:42 PM
Posted 03 November 2013 - 07:12 PM
Posted 03 November 2013 - 07:20 PM
I think it's from the Grease Slapper which was originally VB 308 SLE. As mentioned earlier, the components are smaller than the older stuff. I will be running a 12 port head as well which will be a bonus regarding compressor mounting IMHO. Dunno for sure though. Just kept it all for "One day"
Posted 04 November 2013 - 07:49 PM
I have converted my hatch to denso air from a Toyota hilux
_sloffador_
Posted 04 November 2013 - 08:18 PM
Original a/c unit replaces existing blower
Ducted into car but the internal heater box is fitted with vacuum controls to change from heat to a/c
But it is still a genuine torana box inside
Just don't know how good its going to work am having all the internal plumbing upgraded and hidden a bit better
Oh and relocating the ugly dryer cylinder
Edited by sloffador, 04 November 2013 - 08:19 PM.
Posted 04 November 2013 - 08:24 PM
ugh
better ways surely
Posted 04 November 2013 - 08:49 PM
Hope you dont wanna run tripples on your six lol.
The aftermarket dealer fitted type underdash unit my LH had was a lot neater i recon.....
_sloffador_
Posted 04 November 2013 - 08:56 PM
Your proberly right and I think you've given me the incentive to construct a system under the dash
While getting other stuff done
Ill most likely lose glove box
Any ideas would be appreciated
Posted 04 November 2013 - 10:16 PM
speak to lenny (AXISTR) he has a how to thread on a jap conversion.
Posted 04 November 2013 - 10:26 PM
I have had a few different A/C setups in my hatch over the years.
This is a modified heat and cool under dash that allows you to delete the fan and ducting in the engine bay.
_sloffador_
Posted 06 November 2013 - 10:09 PM
Where Did you get the evap and heater/blower box from
#21
Posted 07 November 2013 - 12:15 AM
Vintage air have a few heat & cool under dash units.
http://www.vintageai...g Webpgs 49.pdf
There are a few other heat & cool under dash units around.
http://speedyairspar...ascia-37-2.html
I have seen a few different versions on eBay.
http://www.ebay.com....#ht_1738wt_1018
#22
_1uzbt1_
Posted 07 November 2013 - 10:26 AM
Those underdash can be bought with or without the front dash vents(like whats pictured in links) so can be hidden behind glovebox and piped up to other style of vents.
#23
Posted 11 November 2013 - 09:21 AM
There is a red hatch ( ToranaMat69???? has LT1 engine) with a skyline 86-89 model air con setup. The centre vents are where the ash tray is. It almost lines up with the original heater hose outlet when I tried to fit it. I like this setup but I damaged it and decided I didn't want to cut that section of the dash anyway.
So, I went vintage air under dash and modified it similarly to Ls2lxhatch unit and it works great. However there is no fresh/ recycle. Axistr setup would be my choice if a had to do it again.
Mark
#24
Posted 14 October 2015 - 11:48 PM
ls2lxhatch did you have any problems with frost or condensation at the base of the windscreen when using A/C seeing as those vents would have been open all the time? Got a similar unit (Ashdown Ingrams' OEX brand EVX219) and just need to do the spacer and ducting for demister, but was just worried about the frost.
#25
Posted 15 October 2015 - 07:07 AM
Hi, I am currently in the process of fitting a Vintage Air unit into my hatch. It's a bit early to say whether or not it will work but I think it will. Two biggest issues (to date) have been, how to mount the evaporator behind the dash. My son welded up a plate to the tunnel for it to bolt onto, it's not entirely vertical but I am comfortable that it will not restrict any drainage and I don't think I will need to trim the console at all for it to fit. Did have to give the underside of the dash a few taps on the left side to fit in but nothing major. Other issue for me is where to fit the compressor. I'm trying to keep the bay as neat as possible so looking at getting a bracket made up that will sit it over the passenger side chassis rail. Ducting and hoses under the dash are going to be tight and this is what I'm trying to finalise now (together with drier, heater electric control valve etc.). I'm sure with what the other guys on this site have done or can advise on (and they have a lot more knowledge than I) that you will be able to achieve something that you are happy with. Cheers Ron
