1jz-2jz engine conversion into LC LJ Torana.
#51
_000lj_
Posted 20 November 2013 - 08:55 PM
go the jz
#52
Posted 20 November 2013 - 11:22 PM
Yeah mate having an lc & knowing those engine bays all too well it looks like world full of hurt having engine sit so high.
Saw Mark's lj years ago when trying to unsuccessfully book my car in for work...he had just got the n/s 2j in the bay...well thought out & fair bit of work put into it to do properly.One day I'll check it out again to see how it is now & their black car.
#53
Posted 21 November 2013 - 11:00 AM
its a full credit to him and he says hes a backyarder and a good one i must say,he does this on a budget,well its a big budget lol,man that car has one smik engine bay and you can see frock all wiring,keen to see some pics rowy of your handy work ,if you have pics filed ,go to more option down on corner then go to browse ,double click on photo,then atach file.then add to post .then apply post,keen to see some pics
jason
#54
Posted 21 November 2013 - 03:48 PM
which ever way you go there is heaps of work that needs doing to fit it properly but after doing two I can say its well worth the effortgo the jz
Pictures please.
#55
_000lj_
Posted 21 November 2013 - 09:07 PM
that
the engine is out of the car at the moment so I can get some pics of the tunnel and steering and mounts I have some pics of the
new oil pic up I made last week
#56
Posted 22 November 2013 - 12:49 PM
The Castlemaine Rod Shop have been working on a 1JZ / 2JZ Conversion at the moment for Standard Torana front ends and for our Torana I.F.S kits.
Please check out all the pic's on our facebook page.
https://www.facebook...05313079&type=1
hi wads.would like to know whether you guys could modify the front k frame to get the motor low with engine mounts with it,and whether it could pass for registration,i think that you will find that alot of people would rather go this way than havin the motor perched up like that,and would most likely alieviate some probs with firewall and tunnel,but not entirely,your thoughts on this would be appreciated
jason
#57
Posted 26 November 2013 - 09:08 AM
been doin some thinking,there is another reason for having your motor low,is it the case where if you have the motor higher than the radiator it could cause air to get trapped in the cylinder head chamber and can create hot spots in head.they say you have to bleed the the air out,how does that work,is there some kind of valve that goes on the water neck with a line running somewhere,anyone have pics or know more about that setup,did you have that prob rowy
#58
_000lj_
Posted 26 November 2013 - 09:37 PM
another pic
100mm intercooler
_000lj_
Posted 26 November 2013 - 09:39 PM
Posted 26 November 2013 - 09:43 PM
nice pics there two knuckles on steering rowy,that manifold looks
the goods,huge,did ya move the steering over much from the firewall
#61
Posted 26 November 2013 - 09:51 PM
intercooler takes up the room ,whats the measurement from radiator support panel to water pump,get a 3 core radiator in there,i like the colour of the beast,very tidy
#62
_000lj_
Posted 26 November 2013 - 10:03 PM
other people have done it differently just depends on your mounts and sump being used, I bought the sump/oil pick up of a guy
thinking it
would save me some time on making a sump/oil pick up but it was a pile of shit and I had to remake every thing so it would work
#63
_000lj_
Posted 26 November 2013 - 10:09 PM
if you have a radiator core no wider than 550 just remove the side mounts and reweld them half inch back on the core
#64
Posted 26 November 2013 - 10:11 PM
i see the other knuckle,sorry didnt look at all the pic,ok i see where you have made a bracket for the first knuckle,great job,took thet lip off the firewall.
piping looks tight see why the steerings moved over,mmm booster ,under dash no not legal,i wanted to put a dual diaphram booster in for 4wheel disc brakes,what the friggin hell am i gonna do there.
#65
_000lj_
Posted 26 November 2013 - 10:16 PM
#66
Posted 26 November 2013 - 10:20 PM
that was a rear sump having prob clearing the xmember so u cut the sump to suit?was lookin at pwr radiators ,man this is alot of friggin around.got pics of engine mounts
#67
Posted 26 November 2013 - 10:23 PM
discs on rear rowy?
frock im askin questions,i need to see this in the flesh
#68
_000lj_
if you wont but if you have hq front discs boosted with a vh40 and commodore rear discs un boosted set up, if you jump on the
anchors it will put you through the windscreen if you havnt got a seat belt on belive me lol
#69
Posted 26 November 2013 - 10:27 PM
#70
Posted 26 November 2013 - 10:34 PM
lol.didnt want to run two much plumbing for my liking,the vl v8 ran just one booster and had 4w disc,i wanted to go that way
if i go aspirated on gas i should be right
#71
_000lj_
Posted 26 November 2013 - 10:35 PM
im using the original aluminium mounts on the engine with escort or Cortina mounts cant remember which one as one Is higher
than the other I use the lower of the two then mounts are made on the cross member to suit.i have seen this done using original
torana mounts with custom plates made on the engine that works good also pwr can supply radiator and move your mounting points
you just need to talk to them with you measurements
#72
Posted 26 November 2013 - 10:42 PM
You will if you want it engineered?
#73
Posted 26 November 2013 - 10:45 PM
cool, thanks rowy for a bit of a geezer of your big job,me bell housing to mate the 2 speed glide arrives tomorrow,still scouting for a rear sump,askin engineer tomorrow if i can modify the xmember for clearance for the sump if i get the nod i will go that way.
#74
Posted 26 November 2013 - 10:48 PM
i dont understand that if the vl had disc allround it should be okay for the j lakeside
even the engineer said 2 and i had a big argument with him lol
#75
Posted 26 November 2013 - 10:50 PM
a dual booster is more than capable running the dscs
