Oil pick up flange torque setting 7/16 bolt
6 replies to this topic
#1 _philby26_
_philby26_
Posted 15 November 2013 - 06:15 PM
Hi guys has any one got the tension for the oil pick up flange the two 7 /16 bolts please
#2 hanra
  • 10,978 posts
Posted 15 November 2013 - 07:12 PM
8-10Nm for 253/308
#3 rodomo
  • 18,039 posts
Posted 15 November 2013 - 07:13 PM
Are you talking the head size of the bolt? 7/16" socket fits it? 25ft/lb will do it.
#4 yel327
  • 13,654 posts
Posted 15 November 2013 - 07:38 PM
Be careful with original screws, they are not high tensile and easily stretch and if you are lucky they will snap when torquing them. If not it'll happen later. Best bet is to get some high tensile set screws and use some loctite on them when torquing up.
#5 hanra
  • 10,978 posts
Posted 15 November 2013 - 08:09 PM
#6 _philby26_
_philby26_
Posted 15 November 2013 - 10:01 PM
thanks guys
all done with that issue
One more question what's the best way to prime up the oil pump  ???
#7 yel327
  • 13,654 posts
Posted 16 November 2013 - 07:15 AM
Light grease or vaseline on the gears and fill the filter with oil. That is what i've always done, but once had an issue with vaseline clogging the filter so only ever used grease since.
