hi, is there a common earth or something on a lx instrument cluster, ive got one where no warning lights are working including the indicator arrows, the actual indicators work and the instrument lights still work, just the warning ones not so, any ideas?
lx warning dash lights
#1 _2wild4u_
Posted 17 November 2013 - 06:14 PM
Posted 17 November 2013 - 06:56 PM
The instrument lights, indicator lights (arrows) and high beam light all have a common earth through the main wiring connector, however, the engine warning lights are not connected to this earth. They earth through their respective circuits.
Power to the instrument lights is supplied via the headlamp switch.
Power to the warning lamps is supplied via the ignition switch.
Power to the indicator lights is supplied via the indicator switch which is in turn supplied by the ignition switch.
Have you tested the bulbs?
