K frame mods
Posted 17 November 2013 - 10:24 PM
#2 _greenmachine215_
Posted 17 November 2013 - 10:49 PM
correct me if I'm wrong but nothing from castlemain ever is what it's said to be, 9/10 times you need to make their products fit.
Posted 17 November 2013 - 11:10 PM
Posted 17 November 2013 - 11:54 PM
Depending on where you are having trouble, it might help for starters to trim the steering column back close to the firewall and fit a proper bearing - there is a thread on doing that somewhere.
Posted 18 November 2013 - 01:37 AM
http://www.gmh-toran...orana/?p=249711
Both legs were replaced in this build.
http://www.markswork...t lead page.htm
Steering column trim.
http://www.gmh-toran...-chev/?p=721408
Edited by ls2lxhatch, 18 November 2013 - 01:40 AM.
#6 _LS1 Hatch_
Posted 18 November 2013 - 02:26 AM
I trimmed my steering column back a bit too, and just spent a while building the headers to try and squeeze around and fit as best as possible at least. (not being a header builder before, took me a little while, haha)
Posted 18 November 2013 - 10:41 PM
Posted 19 November 2013 - 12:45 AM
It will be up to the individual engineer to decide if the k-frame is still strong enough once modified. It does look to be significantly weakened however I don't know what has been done inside.
The engine is mounted to the chassis rails via instead of to the k-frame.
Are you using a rag coupler at the steering rack or another uni fo rmore clearance.
Posted 19 November 2013 - 10:35 PM
#10 _pete ls1_
Posted 21 November 2013 - 03:49 PM
you can try my hookers if ya want
#11 _LS1 Taxi_
Posted 21 November 2013 - 05:15 PM
They are a shit fit and were the cause of many headaches.
Posted 21 November 2013 - 11:13 PM
That would be awesome, I can through some beer your way!
Yeah I bought those headers and chopped em up but they really don't fit. Ve manifolds are so close!I needed to mod my castle extractors on both sides.
