V8 Prototypes Alive by Modern Motors Sept 1983 Barry Lake
322 replies to this topic
#201 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 15 December 2016 - 04:11 PM
The Normal LJ wiring runs on the flat part of the inner guard, does on the XW7 Drawing for the Engine Bay set up.
#202 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 16 December 2016 - 05:56 PM
Cheers for the diagram LC69GTR, I'll add it to my records :D, it is interesting that most of this stuff seems to be privileged information even 44 years after the event.
#203 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 18 December 2016 - 11:25 PM
There is a reason for it.
#204 gtrboyy
gtrboyy
  • 3,209 posts
Posted 19 December 2016 - 12:15 AM
xgtr that's 90's mod we all did when hidden wiring became the trend.
Notice in diagram alt charge wires snakes it's way to starter then another battery-starter cable.
Got that XW-7 street machine mag stashed somewhere but forgot details.
Assumed they used kingy alternator bracket on passenger side as lh/x wasnt out yet?
They have smaller battery like xu1 or moved it to other side?
#205 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 01:20 AM
Cheers gtrboyy, It does seem like a bit of a rush job though.
Most of the holes are either rough or crooked, I get the feeling from the amount of insulation on it whoever did the job was a little concerned with heat, even has a sewn up silver insulated sheath at the starter end of the loom.
There is a wire from the positive end of the battery terminal still in place which actually extends to over 1700mm, which I thought was a little long.
There is a lot of weirdness and coincidence going on with this car, a few of which I haven't even mentioned yet.
I thought I had it pegged as an old rally car but a v8 of all things? it has a standard steering rack dated 9/72 unmodified, the last motor it ran seems to have been a 6cyl though at least on the reg anyway.
last known reg was 1977 with an engine bearing the number 31943R, which is the motor I believe was fitted by Holmesford in 1975, no records of reg seem to exist between 72 and 77.
I've been charged with one of those cars to research Lol!   :banghead:
#206 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 01:33 AM
This was a little strange I thought, Yellow stubs.
#207 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 01:41 AM
Or a rather strange looking accelerator pedal.
#208 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 19 December 2016 - 03:34 AM
They hk discs on there.steering arms??
#209 S pack
  • 15,723 posts
Posted 19 December 2016 - 07:46 AM
Repro LC/LJ Torana discs.
Looks like someone wanted to tart it up with orange calipers, yellow stubs and orange steering arms.
Accelerator pedal assy to suit throttle cable.
#210 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 09:39 AM
XW7 Wiring set up for the 308 V8, this is the artist impression from the XW7 Drawing that was in street machine. Street Machine Magazine must of been worried about Copy right from Holden, so did it how they did it.
#211 yel327
  • 13,633 posts
Posted 19 December 2016 - 10:50 AM
Kingswood alternator bracket was the same as other V8 Holden or Statesman from the same Series, and it differed for HT-HG to HQ, plus for A/C cars was different. But the one in that Street Machine diagram is not from a Holden or Statesman, it is on the wrong side and looks to pivot at the bottom rather than the top.
#212 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 11:25 AM
Orange paint is pressure pack crap and just flakes off (even did the wiper motor) the yellow paint is much more durable I think.
#213 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 11:55 AM
That late 80s, early 90s trend of painting everything in fluoro colours......... Yuk!
#214 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 12:26 PM
Nice parcel shelf though (even if someone did ruin it with speaker holes :furious:) it's made from 2mm steel plate with racing harness attached.
#215 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 12:52 PM
Brand new Alt Bracket for V8 LJ on the XW7 Parts List
#216 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 02:11 PM
Like I said anyway. It's just an old rally car ;)
#217 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 02:36 PM
Been a 000 X Dealer on the Warranty Disc it could of been in NZ or South Africa for them missing year as X is for Export  :)
#218 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 02:44 PM
It changed hands several times throughout 75 though, south yarra, kew and frankston, didn't sell and all the while it carried april reg, AOMC is simply missing the record, I know there should be a record of it changing hands but there simply isn't.
Notice how they got the year wrong also, I don't think it ever had tags?
#219 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 03:05 PM
What are the odds of two white 000 code cars ending up in the same area one after the other when both would have had signs of being an engineering car?
How many white 000 code GTR's did GMH have in it's possession which happen to pre-date june 72?
#220 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 03:22 PM
JL127067 was your cars original Engine number, LDN028 would be at AOMC for sure
#221 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 03:26 PM
Was your car in the same Area ? Rego papers on your GTR have Princess HWY Dandenong on it, your car was  out at GMH Dandenong and that is 33kms from Port Melbourne,  i reckon your car was used by a GMH Boss out at GMH Dandenong ????? as his company car.  Strange as its a 000 X Car and it missed the Boat.
Edited by xu2308, 19 December 2016 - 03:31 PM.
#222 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 03:33 PM
Sorry Al, should have been more specific, I meant the Wansley car in the Age, and yet you mentioned he sold it in 75?
#223 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 03:37 PM
Makes it a special export  ;)
#224 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 19 December 2016 - 03:40 PM
​Wamsley told me he Sold it in 1975, his words.
Untill we get a rego number on the Wamsley Car, we only have the Age Newspaper Clippings, Vic Roads Archives need a rego plate for Wamsley Car to find its info out.
#225 xgtr
xgtr
  • 169 posts
  • Name:Blake
  • Car:lj coupe
Posted 19 December 2016 - 03:47 PM
I'll try and make the association with the Wansley car to the 000x with VicRoads and see how it turns out, maybe I need to be more specific this time.
