difference between lc and lj dash ? gtr xu1
17 replies to this topic
#1 liswar2
liswar2
  • 1,516 posts
  • Name:Wazza
Posted 13 December 2013 - 11:58 AM
hi , i am aware of the speedo 120mph,
lj no gap for lc push through wire clip,
dte on gauges 2/72 etc
on the front of the dash there are the 1 hole for brake light , upper
 or a dash with 2 holes ?
what does this differentiate please ? any thoughts , info ?
thanks liswar
#2 _oz772_
_oz772_
Posted 13 December 2013 - 12:56 PM
If you do a search, there is a thread with photos somewhere in the LC/LJ section from memory. [Not sure what you mean by the 120mph speedo; all XU1's had that (your topic states you are referring to GTR XU1 dashes)].
#3 liswar2
liswar2
  • 1,516 posts
  • Name:Wazza
Posted 13 December 2013 - 10:11 PM
thanks , i will search the dashes in lc/lj
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 13 December 2013 - 10:44 PM
Hi
Does this help?
Bazza
#5 _oz772_
_oz772_
Posted 14 December 2013 - 12:52 PM
Since this instrument panel has been mentioned, can someone definitively say how the highlights around the instruments were finished on the LC only? Photos in a brochure I have of a 1970 GTR seems to indicate these highlights were chromed, like the big Holdens. Does anyone know if that was the case, or were they finished in silver highlights like the LJ, (and as per restoration work done by Dash Original these days)? Thanks.
#6 Potta
Posted 14 December 2013 - 02:45 PM
I can't give you a 100% answer, but I've never seen one that looks like it was chromed, and when it wears off it doesn't peel off, it wears like paint.
#7 _oz772_
_oz772_
Posted 14 December 2013 - 04:27 PM
Yeah, that is what has me confused. I have seen a NOS lower dash that has the highlights chromed, and the photo in the brochure indicates the instrument surrounds are chromed. However, brochures can be misleading. And as you say, the highlight on the instrument panel cracks off like paint.
#8 _oz772_
_oz772_
Posted 14 December 2013 - 05:28 PM
This is the photo that indicates they were chromed
But maybe it is a trick of the brochure??
#9 Potta
Posted 14 December 2013 - 11:26 PM
Yeah I see what you mean it certainly does look chromed but they haven't given the same treatment to the knob surrounds or the edge on the console.
Maybe its a trick of the light?
#10 liswar2
liswar2
  • 1,516 posts
  • Name:Wazza
Posted 16 December 2013 - 11:18 AM
excellent info all round , thanks all
#11 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 23 December 2013 - 02:19 PM
My GTR Dash is a LJ type as it has the screw holes in the bottom,,,,in the pic above it's the Top Right dash.
It does have the mounting clamps like the LC. I've always wondered why I could never put screws in so I could mount the bottom.
Learned something new here after having the car since 2006 with previous owner fitting the GTR Gauges
#12 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 December 2013 - 03:14 PM
Hi Gooley
With the LJ, 2 of these gizmos clip into recesses in the bottom part of the dash opening. The screws going in from the front of the cluster then have something to purchase into.
Bazza
#13 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 23 December 2013 - 03:44 PM
are these clips available ??
#14 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 December 2013 - 04:13 PM
Hi
Not that I know of. I got one from a wreckers and the other i found stuck in the steering column support bracket where it had fallen to.
Bazza
#15 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 23 December 2013 - 07:00 PM
thanks mate
#16 gooley
gooley
  • 529 posts
  • Name:Jason
Posted 24 December 2013 - 08:36 PM
Hi Gooley
Bazza
OK thank you for that Bazza... I'll see what I can actually use....I'm not actually fussed with it... but at least I know now what to look for and use if I ever come a cross one
#17 toranasaurus
toranasaurus
  • 54 posts
Posted 04 September 2023 - 09:27 AM
#18 toranasaurus
toranasaurus
  • 54 posts
Posted 04 September 2023 - 09:30 AM
Hey, the instruments were originally vacuum metallised or essentially sprayed on aluminium so giving a chrome look when new and when fading looking a bit like paint as it didnt have any auxiliary coating to protect it.
