HI,
I have a set of king springs in my LX.
I need the front to sit about 1 inch lower.
I have a KHFL 15 (SLR 5000/A9X height according to the catalogue)
I was wondering if the KHFL 14 is even lower?
Posted 23 December 2013 - 06:27 PM
HI,
Posted 23 December 2013 - 07:15 PM
What stub axles are those ?
Posted 23 December 2013 - 07:21 PM
Posted 28 December 2013 - 02:23 PM
I have got in contact with a King Spring supplier and the KHFL 15 is the lowest springs they do on a LX.
Is it worth looking at a different brand springs or should i just send my springs away and get them compressed.
Any feed back will be great.
Posted 28 December 2013 - 03:42 PM
Check some other threads. I think there is some information about this on the HQ brake tutorial thread.
Posted 29 December 2013 - 10:15 AM
Posted 29 December 2013 - 11:31 AM
Posted 29 December 2013 - 11:50 AM
http://www.gmh-toran...28540-15-tyres/
try that thread, its all been done before
and more here
http://www.gmh-toran...gs-and-hqstubs/
Posted 29 December 2013 - 05:09 PM
Are you 100% sure you've got your springs seated properly?
Sometimes the fronts don't seat right and the car sits up about 30mm...
Posted 29 December 2013 - 05:15 PM
Posted 29 December 2013 - 05:18 PM
Pull the shockers and get your head underneath and look up with a torch.
Posted 29 December 2013 - 05:29 PM
Posted 29 December 2013 - 05:43 PM
Yes it's common. You'll have to pull the springs to swap them anyhow so why not just check?
If your springs are in correctly and you have torana stub axles, you can swap to HQ stubs to get another inch lower.
Posted 29 December 2013 - 05:55 PM
Posted 29 December 2013 - 06:44 PM
yes its really easy to not put them in properly, no they won't 'drop' in if they are not seated correctly.
Posted 29 December 2013 - 06:58 PM
I have KHFL14's in mine. They lower the car one inch lower than standard. The right height in my eyes.
Posted 29 December 2013 - 07:37 PM
Posted 29 December 2013 - 07:58 PM
torana.jpg 147.58K 9 downloads
These are the King Spring lows front and rear with HQ front stub axles.
Posted 29 December 2013 - 08:09 PM
Yep pic above is about the same as mine. I have always fitted these springs to my Torry's or the lovels 1 inch lower set they supply.
Posted 29 December 2013 - 08:20 PM
Posted 29 December 2013 - 08:23 PM
Two options.
1. Your springs are seated wrong
2. You have torana stub axles
Are you certain of either of the above??
Posted 29 December 2013 - 08:31 PM
Posted 29 December 2013 - 08:38 PM
Posted 29 December 2013 - 08:42 PM
Posted 29 December 2013 - 08:51 PM
