HQ-WB bonnets
7 replies to this topic
#1 rexy
rexy
  • 3,722 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 29 December 2013 - 05:58 PM
Not sure where to put this so went for first category visibility.
Are there differences in the outer skin ( top side ) appearance of the bonnets from HQ to WB or are they all the same? I need one for the HQ ute.
Thanks in advance.
#2 _Macca97_
_Macca97_
Posted 29 December 2013 - 06:07 PM
HJ-WB are different to HQ, but one tonners are the same as HQ not sure about wb tonners though, hope this helps
Danny
#3 S pack
  • 15,708 posts
Posted 29 December 2013 - 06:20 PM
HJ to HZ Tonners had the HQ bonnet.
WB had HJ - HZ sed/ute/van/wag/prem/statesman bonnet.
#4 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 29 December 2013 - 08:02 PM
Answer Yes ....but as the above post
if you have a HQ front apron panel single or twin ...you would need a HQ bonnet
but you can put the later panels on a HQ
#5 rexy
rexy
  • 3,722 posts
  • Name:Rexy
Posted 29 December 2013 - 08:54 PM
It has a single headlight HQ front on it. Do the HJ to WB bonnets fit the same from a panel gap point of view? I will be cutting a large hole out of the top of it anyway.
#6 76lxhatch
  • 7,205 posts
Posted 29 December 2013 - 08:58 PM
It will fit in the hole but the swage lines at the cowl edge won't line up, they are different width apart
#7 _Lazarus_
_Lazarus_
Posted 29 December 2013 - 09:38 PM
You can't use the later bonnet unless you change the whole front and the swage lines. If you don't change those lines on the plenum then the bonnet doesn't sit down properly. It's not difficult (for a good panelbeater) but probably not worth it unless you have a complete HJ / WB walk off front laying around.
Good HQ panels can be hard to find but fibreglass HQ bonnets are available. You might be able to get Taiwanese ones too (steel).
Edited by Lazarus, 29 December 2013 - 09:43 PM.
#8 rexy
rexy
  • 3,722 posts
  • Name:Rexy
Posted 29 December 2013 - 11:45 PM
Excellent. I suspected as much. The search continues...
