Lx quadrajet air filter
5 replies to this topic
#1 _Darylle_
_Darylle_
Posted 01 January 2014 - 04:34 PM
Hi all
I am looking to upgrade from std. air filter to something cooler looking and performing. I like velocity stack look but obviously no scoop limits my options.
Thanks in advance for your suggestions.
#2 _Gunmetal LH_
_Gunmetal LH_
Posted 01 January 2014 - 05:10 PM
From the JEGS site USA
K&N 66-1401XP - K&N X-Stream $63.99
K&N 66-3040 - K&N X-Stream $116.99
#3 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 01 January 2014 - 06:59 PM
Turn the lid upsidedown on the standard aircleaner also helps while still retaining the "stock" look
#4 _The Baron_
_The Baron_
Posted 01 January 2014 - 08:07 PM
Watch those aftermarket aircleaner assemblies on a Qjet. The base plate can foul the rod for the accel pump. I know the drop down bases do.
#5 _Darylle_
_Darylle_
Posted 01 January 2014 - 08:27 PM
O.K thanks for the photos Peter, I have seen this type before (K&N) Will this clear the std. bonnet and how do they seat on the carb? Do they require a base plate or is it moulded into the bottom? The std. lid has been reversed and I know there is a product that fits and looks good hence my original post.
Thanks people.
#6 _Gunmetal LH_
_Gunmetal LH_
Posted 01 January 2014 - 09:11 PM
Would have a bottom plate/hat.
I've only seen the bottom bits used off chrome 'kits' with the top and bottom hats that use whatever filters, which have the top and ring(?) filters replaced with the K&N bits.
They seem to sit lower over the carb (to allow a taller filter than stock) and have a couple extra bumps in the bottom plate to clear the carby bits.
I found I have to get mine turned to just the right spot to clear the linkages etc.
You might be able to trim down the standard bottom plate/hat?
Edited by Gunmetal LH, 01 January 2014 - 09:12 PM.
