POR15 and Other Rust Convertors
92 replies to this topic
#76 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 05 January 2016 - 10:56 PM
Ive used KBS rust seal and you really need to rinse off the converter properly.
While im happy with with its prep and application I had issues with the finish.
I used satin rust seal , when i brushed it on,  it would dry with what I would call a semi gloss look.
However when i sprayed it, it definitely looked satin.
Another issue is the satin top coat which is UV stabilized, when sprayed would dry more flat than satin.
#77 _Macca97_
_Macca97_
Posted 06 January 2016 - 11:43 AM
rust seal is, on and dry, I didn't use the 3 step, just got the metal cleanish, 2 coats, looks good,
#78 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 06 January 2016 - 02:48 PM
So you're saying both the satin rust seal and top coat give a slightly more glossy finish brushed on and flatter when sprayed?
Edited by tuxedoss, 06 January 2016 - 02:48 PM.
#79 _Bomber Watson_
Posted 06 January 2016 - 03:06 PM
I havnt used those particular products, but it would make sense as film thickness seems to change the sheen.
Spray satins/matts on heavilly usually gives a glossyer finish than spraying them on lightly.
#80 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 06 January 2016 - 09:08 PM
What I'm saying and Bomber reiterated is that when KBS is brushed on , it will dry more glossy than the stated finished product.
The Rust seal definately looked Satin when it was sparayed.
But I what I found is that the "Rust Seal Satin black"  and the "Rock Hard Chassis Top Coat  Satin Black " products where not the same satin finish.
I had to spray the Rock Hard chassis black top coat satin, very heavily to make it look satin. Otherwise is would have turned out Flat not satin.
#81 MARKL
MARKL
  • 94 posts
  • Name:Mark
  • Car:Hatch
Posted 08 February 2016 - 09:26 PM
Given the hate we all have for the 'r' word (so much worse than either the 'f' or 'c' words in my view) and that some of the posts in this thread are getting onto 10 years old I was hoping some of the original posters in this thread could give their long term comments on the effectiveness of POR15, KBS etc. Long term feedback like this would be of great benefit to anyone doing a current or future project(and this is the sticky).
How has it stood up?
Has rust come back? If it has was this due to the product being crap or other reason? Poor prep, rusted through from other side, physical damage etc?
Has it cracked, delaminated, peeled etc? (you read some forums and everyone says POR15 cracks, other forums and no one has that problem)
Would you use the same product again? Have you found a better product?
Long term thoughts on cavity waxes? Any particular good/bad?
Any tips for Torana problem areas and treatments used? Especially things like hatch C pillars, plenum chambers, cavities etc where access is between poor and nil?
Edited by MARKL, 08 February 2016 - 09:27 PM.
#82 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 21 January 2018 - 08:38 PM
What is the kbs like to weld through??
#83 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 21 January 2018 - 09:07 PM
You cant weld through it dude.
#84 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
Posted 22 January 2018 - 10:42 AM
Bugger
#85 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 25 May 2020 - 10:05 PM
This has been a good test for KBS.
A client of mine asked me to weld up a cactus shape from a photo she supplied. I used mild steel rod and mig welded the joins.
Then I prepped it with Rust Blast and two coats of Rust Seal black gloss.
This has been hanging on an exterior wall for 7 years without a trace of rust forming. Yes, the gloss has turned to mat but I'm really happy with the result.
Marty
Attached File  IMG_1078.jpeg   182.33K   8 downloads
#86 Bigfella237
Posted 25 May 2020 - 10:57 PM
That's no good, Marty... it's cactus!
(Sorry, couldn't resist.)
Nice piece of lawn art though (if you'd call it that), shows how simple a great effect can be with a little imagination! I reckon a free-standing 3D version of that would sell like hot cakes at bunnings.
Does KBS come in green?
#87 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 26 May 2020 - 01:52 PM
I didnt think they had that many..
Attached File  Screenshot_20200526-134851.jpg   445.28K   11 downloads
#88 Heath
  • 18,393 posts
Posted 26 May 2020 - 03:17 PM
Adrian at KBS says that the Rust Seal is not UV-stable. He said if you're painting a bullbar or something, then you absolutely are supposed to coat it in the "Black Top" or something afterwards (if you leave it a while, you need to scuff it up in ~240 first) or it'll go chalky & cloudy.
If that cactus was coated in Rust Seal and then Black Top, it would be a much better test. It SHOULD still be the same as the day you painted it.
Edited by Heath, 26 May 2020 - 03:19 PM.
#89 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 May 2020 - 06:23 PM
Marty
It's not something on an adult store wall, is it Marty ? Gary.
#90 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 May 2020 - 08:27 PM
Hi Heath,
I did realise that at the time but was told the product doesn't loose its protective quality if no Black top applied, so this was a great test for that and matt looks better than gloss in this instant.
Hi Gary, took me a while to see it but now I do. Could be better than the 'Rabbit' .......the 'Cactus'
I've tried silver and it isn't as effective as black.
#91 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 26 May 2020 - 11:06 PM
I think i got an old tin when i bought the silver.
Was hard on top only after 6 mnths.tin was near full and
was stored propper.was abit peeved off by that..still
used what was in the tin after cracking the top.was all seperated .gave it a good stir and used it.hasnt got
a long shelf life i dont think...
#92 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 26 May 2020 - 11:18 PM
Did you paint out of the tin? that will do it every time. You need to stir and pour into another cup and get lid back on tin ASAP. it cures with air and moisture. Also helps if you have a MIG squirt some argon gas in the tin, gets rid of the air. But there is also a shelf life, depending where you buy from you need to check how old it is, some places have it sitting on shelf a long time. I've found the new it is the better it goes on.
#93 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 26 May 2020 - 11:58 PM
Yeah stirred it slowly bro as to not get air bubbles
in it and poured it into another small container.
Id say i got an old one.i doubt i will use anymore as
Its quite expensive when you dont use much..
