Hey Guys,
I recently bought a second hand motor that the owner thought had done a ring. When i stripped it down it appeared to just be a blown gasket, rings are fine. But i notice that the piston (#2) with no compression has been kissing the head. At this stage i have only pulled out that conrod and the bearing appears to be fine. Was hoping to put it back together without to much work but obviously don't want to be tearing it down any time soon. The motor was only built 12 months ago and i put a straight edge on the heads and the block (all good). What do you think would cause the piston hitting and should i get that piston, or all the pistons milled down just to be sure
Edited by LX355SLR, 17 January 2014 - 04:20 PM.
