I think its a lot bigger than you guys think? 520 tall x 110 diameter and weighs 5kg, you must be able to get another 5kg of gas in it surely...? A lot more than 3 disposable bottles at any rate
Mig gas co2?
#76
Posted 21 March 2014 - 05:04 AM
#77
_judgelj_
Posted 21 March 2014 - 03:43 PM
"Our cylinder is a C size and holds 0.6 m3 compared to an E size 4 m3."
#78
_ausdev_
Posted 26 April 2014 - 05:03 PM
I have a question for the mig experts out there ......
Will i blow more holes with gasless wire as opposed to using gas.....I am using gasless, as i am old school stick welder from way back but am finding when welding thin panel steel patches in, i struggle to start the arc for spotting on low settings. Will patch welding be easier with gas...?
Many thanks...Aus
#79
Posted 26 April 2014 - 06:50 PM
Hi Alby,
from my experience, thin sheet requires the correct amps/volts to do the job right, so you need a welder that can control low amp/voltage well, now gas will always be better because the gas is shielding the weld to stop it from porosity, which gives the welding that nice crackling effect as you weld. Dave I
#80
Posted 26 April 2014 - 07:42 PM
You should blow less holes, because you can be using thinner wire for starters.
Think the gasless is 0.9mm I use 0.6mm with gas. Lots easier welding thin stuff.
#81
Posted 26 April 2014 - 07:43 PM
Many thanks...Aus
#82
Posted 26 April 2014 - 07:44 PM
great info there Rob
#83
Posted 26 April 2014 - 07:48 PM
#84
_judgelj_
Posted 27 April 2014 - 04:01 PM
Yeah i hear you there im working on it dont worry! But gas less is not great. I'm getting a little bit better at welding it but i still prefer the ease of gas.
