VZ disconnect fuel lines?
Posted 25 March 2014 - 09:09 AM
#2 _LS1 Hatch_
Posted 25 March 2014 - 09:44 AM
Edited by LS1 Hatch, 25 March 2014 - 09:46 AM.
Posted 25 March 2014 - 10:02 AM
#4 _LS1 Hatch_
Posted 25 March 2014 - 10:06 AM
Posted 25 March 2014 - 10:58 AM
Dr Terry
Posted 25 March 2014 - 12:02 PM
Have 06 VZ alloytec that started, ran for a second if that and shut down or stalled. Now it refuses to start alt all. It cranks but not firing at all seems like no spark. This is the second time this has happen. First time it took 2-3 days before it fire up and near 12 mths later it has done it again. I think it's a bad idea to not start the cars every few weeks.
#7 _SRV_
Posted 25 March 2014 - 01:26 PM
Don't know much about VZs but we had exact same problem with VT a month ago, the battery in the key had gone flat. New key and all is well. This icould well be your problem.
#8 _mello92_
Posted 25 March 2014 - 06:00 PM
Posted 25 March 2014 - 06:33 PM
Can't remove the battery from the VZ key.
Slip ring around the ignition barrel hasn't fallen apart? Key making good contact?
I checked it was making good contact with the key.
Posted 25 March 2014 - 07:19 PM
Unrelated but alloytechs have lots of throttle body issues the cause car to go into limp mode and hard to start sometimes
#11 _SRV_
Posted 25 March 2014 - 08:33 PM
Quote: Can't remove the battery from the VZ key.
I just googled and key is same as VS/VT etc. Battery is soldered inside and can't really be replaced without wrecking the case of it anyway, plus when the battery is disconnected it needs to be reprogramed. When you unlock the car with the key buttons do they sometimes not work?
Edited by SRV, 25 March 2014 - 08:36 PM.
Posted 25 March 2014 - 08:42 PM
#13 _SRV_
Posted 25 March 2014 - 08:55 PM
Well there's your problem! Key needs to have power to turn the immobiliser off when key is put in ignition. New keys are $100 or so from key cutting place like Mister Minit. If the key doesn't have enough power on it for them to read the code off it they'll need to contact Holden and give them your VIN nimber in exchage for the code.
#14 _SRV_
Posted 02 April 2014 - 03:31 PM
So, did you get it sorted?
Posted 02 April 2014 - 05:26 PM
#16 _SRV_
Posted 02 April 2014 - 08:04 PM
Bought a new battery for the VT before we got the new key thinking the same, $150 wasted..
#17 _mello92_
Posted 02 April 2014 - 10:25 PM
Have access to a scan tool?
Would be good to see if you have a crank signal, and have a look to see if any other values are abnormal.
Posted 03 April 2014 - 08:15 PM
Lock the car using the key pad, remove the BCM fuse (fuse box behind the battery) and refit after 20 seconds. Unlock the car again with the buttons on the keypad and try to start.
Posted 05 April 2014 - 03:42 PM
Posted 05 April 2014 - 04:07 PM
It will happen again.
It's the key.
#21 _Macca97_
Posted 05 April 2014 - 04:46 PM
next time it happens hit the unlock button as you turn the key, might help it start
#22
Posted 05 April 2014 - 08:17 PM
It's the key.
I think you may be right. I want to sell the car so i will get new key soon.
