10 bolt salisbury question
_jabba_
Posted 09 July 2006 - 10:37 PM
Damien
_UCV80_
Posted 09 July 2006 - 10:44 PM
u could put in another 2.78 if im right
im interested to know
_jabba_
Posted 09 July 2006 - 11:09 PM
Edited by jabba, 09 July 2006 - 11:10 PM.
_lx5008_
Posted 11 July 2006 - 08:27 AM
hi damien, in the large salisbury the diff cases are the same. in banjo the banjo case centre is differant. the 2.78 and 3.08 have the longer mount bolts at the bottom.Can anyone tell me if its possable to bolt 3.08:1 gears to a 2.78:1 centre, i have a 2.78 centre which i know is perfect and makes no noises and a 3.08 currently in the car which is fairly noisy. I was told along time ago that only 2.6 and 2.78 gears could be swaped, same with 3.08 and 3.36 etc... Is that true?
Damien
large salisbury
2.78 2.60 the same
3.90 3.55 3.36 3.08 the same
banjo/small salisbury
2.78 3.08 the same
3.90 3.55 3.36 the same
not only are the matched sets of crown wheel and pinions differant so are the hemipheres. so if you want to change ratios in the large salisbury you have to use the right hemiphere for that ratio.
Posted 11 July 2006 - 10:39 AM
Jabba, its more than likley that its the gears that are making all the noise anyway
_jabba_
Posted 11 July 2006 - 10:34 PM
Well i have a 3.08 hemisphere, but it goes knockknockknockknock under no load and squeeks abit when turning tight corners. Well i wont be able to use my 2.78 centre anyway by the sounds of it, i might just try and track down a large salisbury LSD centre with some 3.08 or higher gears, failing that just use the single spinner 3.55 i have. I ran my combo through the gearbox calc and going from 3.08 - 3.55 adds about 500rpm at 110km/h iirc.but if you have a 3.08 hemisphere you can just change the gears to 3.55? I hope so!
