Banjo Diff's
13 replies to this topic
#1 _Anth 05_
_Anth 05_
Posted 06 April 2014 - 01:27 PM
Hello everyone,
I'm new to the site so firstly I would like to say hi.
I am just about to start my LH project which has been in the pipeline now for over 12 months. I'm now in the process of pulling her apart and sending her off to be prepared for the spray booth.
I need to know if anyone can tell me if there is a difference between a 6 cyl banjo diff and one from a V8. I'm hoping to keep my car as original as I can during the re-build but I am replacing the 6 cyl with a newly built 308 and so far I can't get a straight answer from any research that I have been doing.
I have been told that the diff's are the same except for the Yoke. Is this true?
#2 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 06 April 2014 - 06:53 PM
Welcome to the forums. Apparently the slr5000 have a baffled diff (I find this hard to believe as I have asked some relatives who worked at Pagewood and cant recall special diff cases being installed on the line). The tailshaft obviously would be of a greater diametre.
In terms of banjos the 5000 could be optioned with LSD.
I also have a feeling they are all fine spline axles as opposed to course spline.
The search engine is your friend here.
Phillip
#3 hanra
  • 11,033 posts
Posted 06 April 2014 - 07:26 PM
Hi Phillip, here is the axle baffle as fitted to my LSD fine spline SL/R 5000 housing.
0F038599-3F3F-45C1-8ED6-56643F07049C_zps
#4 S pack
  • 15,764 posts
Posted 06 April 2014 - 09:18 PM
Phillip
G/day Philip.
As Hanra has shown in his diff housing pic baffled diff housings and fine spline LSD were standard in SLR 5000.
Dave.
Edited by S pack, 06 April 2014 - 09:18 PM.
#5 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 07 April 2014 - 11:21 AM
Thanks Brad and Dave I am not arguing. I suppose the part number for the casing will those be unique?
#6 _Anth 05_
_Anth 05_
Posted 07 April 2014 - 12:20 PM
Hey thanks guys for your input much appreciated. Can you tell me what the baffles are for or why they were incorporated in the diff's. Looks like I have a job now of trying to locate one or having one manufactured...
Is there any chance Hanra may have some more photo's of the diff so I can see what I need to achieve.
Anthony
#7 _SableMet7/73_
_SableMet7/73_
Posted 07 April 2014 - 06:28 PM
Helps to keep the oil in the center under cornering...init?
Is there much difference between LJ & LH banjo housings?
If not & your havin a go at your own, I can help with a copy of a template of
the baffles in my XU1 housing.
I made up another housing to use both long & short bolt centers & as my
original housing barely had the WM left which I didnt want restored.
J
#8 rodomo
  • 18,063 posts
Posted 07 April 2014 - 09:47 PM
I'm tippin' V8 ones don't last as long as six's on average.
#9 hanra
  • 11,033 posts
Posted 07 April 2014 - 10:19 PM
Edited by hanra, 07 April 2014 - 10:20 PM.
#10 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 12 April 2014 - 08:41 AM
I'm sure in Fiv Antonio's book GTR XU-1 there's specs on making the baffles, I assume they would be the same for both LH and LJ.
Sorry to thread steal but while we're talking about banjo diffs, I was at the wreckers the other day and saw a 3:36 banjo centre sitting on the passenger seat of a Kingswood, all the teeth appeared to be in good condition so I grabbed it. With the centre not in a car how do I tell if it is a LSD or not?
Thanks James
#11 _walpolla_
_walpolla_
Posted 12 April 2014 - 11:22 AM
First one is LSD second one not.
Rod
http://i62.tinypic.com/1265n5k.jpg
http://i61.tinypic.com/ve6cy1.jpg
Edited by walpolla, 12 April 2014 - 11:27 AM.
#12 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 12 April 2014 - 12:50 PM
Thanks Rod,
It looks like the one I picked is not a Lsd then. I wouldn't have expected it to be but I thought I'd check. Are many of the parts inter changeable to make it worthwhile keeping as spares?
JD
#13 _walpolla_
_walpolla_
Posted 12 April 2014 - 01:31 PM
I think the crown wheel and pinion would be useful and interchangeable as a set.
Rod
#14 N/A-PWR
  • 9,644 posts
Posted 12 April 2014 - 02:38 PM
2.78:1 LSD Banjo's are good Anthony,
Welcome, but if your Power is too Much, you will need a Salisbury Diff. Dave I
