* * * * * 1 votes
Sunbird build thread
158 replies to this topic
#76 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 17 September 2017 - 07:12 AM
Moved house recently so the car had to move, I pretty much threw the wiring in and got it running and drove it with an unregistered vehicle permit to the new house.
Was great to get it running and drive it even though it was only 450m, had some issues getting it started as I didn't know how the Torana ignition switch worked.
The trouble shooting instructions that came with my loom from Ultimate Conversion Wiring had the answer and after bridging the wires from crank to ignition it fired up, thanks Justin for making a good looking neat loom and all the help you have provided on the phone too. Great to hear it running in the car, bit loud without tail pipes but very enjoyable. Everything worked and I took it down the street into it's new garage. Brakes worked at the other end too. The engine bay is a bit of a mess and I don't like my coil mounts but will change that when there is time. Had the ECM, fuses and relays just sitting on the floor in the car as there wasn't time to mount it all.
Although I didn't have a dash I could see the speedo cable wasn't turning which was a bit of a concern as I immediately thought the worst and it might have been a problem in the box but I took the cable out today and found after putting the 90degree and pass through sensor back in it works now. I ran the car today in the garage with the wheels off the ground to test the speedo and also waited till the fans came on switched off, happy all that should have worked did.
Lots to do yet but nice encouraging progress.
Good to see you got it going. Great feeling when it can start and move under its own steam. Little jealous as mine is still packed away at a mates shed waiting for me to move it to my new place. Been about 3 months since have worked on it
#77 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 21 September 2017 - 07:12 PM
Hi Dave, just noticed your comment about the yoke in the gearbox. I will check it but think it goes in far enough.
#78 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 21 September 2017 - 07:33 PM
Hi Tom
Just read start to finish and looking good
Had to smile with the crossmember as i just went through the same thing but with a T10 box
Looking at the yoke going into the extension housing it seems it could need to go in a bit more but not sure if the photo was taken with the car suspended
Normal rule of thumb is with the cars suspension under compression you push the yoke fully in until it stops then withdraw it round 3/4 to an inch for full spline engagement length
Just seems you have a fair bit of the yoke still out of the box - hate to have looked at a potential weak spot in the driveline and not let you know
Cheers and love your work
Hi Dave,
Think it is ok, next pic is from when I measured up for the tail shaft. You can see a grease mark around the yoke, that is the 20-30mm I pulled it back out of the gearbox once it went all the way in and I think it looks about the same as it does now. I remember when fitting it that it only just passed the uni joint on the diff to fit in so don't think it could be much longer. From memory it has about 80mm in the gearbox.
As it is now full of oil I might put tape on it and see if I can pull it out 50mm without it dropping out which I think will mean it is still in enough. At least it is only a small thing to add to the list to do. Thanks for the suggestion.
Justin, hope you get some time to work on your car both for your needs and also many of us here look forward to the next modification
Took the pass through speed sensor and 90 degree gearbox fitting and refitted them, looks like I had something wrong the first time as it worked when I reassembled it. the guy who built my diff recommended running it with the wheels suspended for 10min at 2500 rpm. I ran it for a few minutes so I could see the speedo work but wasn't prepared for 10min in the garage trying to gas myself. It was running long enough that the fans came on and cooled it down a bit and then shut off, happy that is another piece of the puzzle ticked off.
Cheers, Tom
Attached File  P1110576.JPG   172.63K   18 downloads
#79 Bigfella237
Posted 21 September 2017 - 08:12 PM
It would be interesting to put a Torana up on jack stands, remove the rear springs and jack the rear suspension through its full range of movement just to measure how much the slip yoke actually does travel?
#80 myss427
myss427
  • 1,636 posts
Posted 22 September 2017 - 10:28 AM
Have done that on mine, was worried that my new tailshaft would bang into the back of the box as it is only 15mm from the yolke. Its movement was less than 10mm, roughly 7 at a guess, way less than I would have thought. And I did remove the springs and went through full travel movements. It looks tight but was surprised how little it moves, I do have tough mounts etc which would stop the drivetrains forward and rearward movemnt somewhat.
#81 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 03 December 2017 - 06:48 PM
Haven't yet got round to checking the depth of the yoke into the gearbox but did put some tail pipes on.
Bought some tail pipes made by Redback Exhausts and they were close to fitting and only needed minor trimming here and there.With the car in the garage on jack stands I found it a pain to get the tail pipes in and out of the car while making them fit and cut the ends of and added a flange so the pipes can now be removed without taking the rear springs and shock off.
I also put some heater hoses on and connected them up to the vintage air unit inside and swapped the rocker covers from side to side as I think it will make fitting the coils easier on the drivers side. They have plastic block mounts holding them together and I will add another block mount on the firewall cover just behind where the oil filler cap is now.
Attached File  P1110967.JPG   146.7K   18 downloads
Attached File  P1110972.JPG   156.09K   15 downloads
Attached File  P1110977.JPG   156.22K   14 downloads
Attached File  P1110980.JPG   147.75K   13 downloads
#82 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 10 December 2017 - 07:55 PM
Previously the new coil brackets had been cable tied to the factory coil brackets which wasn't great so I welded some washers to the coil brackets so they could line up with holes mounting threads in the rocker cover and put them on properly. I would prefer the factory coil brackets but they aren't going to fit with the brake lines and booster.  The new ones don't look great but I don't want to look for somewhere else to put them and they don't look terrible
Will have to make the high tension leads to suit now
Attached File  P1110981.JPG   158.83K   13 downloads
Attached File  P1110982.JPG   156.49K   13 downloads
Attached File  P1110983.JPG   152.9K   13 downloads
Attached File  P1110984.JPG   144.27K   14 downloads
#83 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 26 March 2018 - 06:11 PM
Made some coil leads to fit with the mounting position of the coils, bought new ends from Aeroflow and with the crimping tool they were easy to fit.
Attached File  P1120005.JPG   160.54K   14 downloads
Attached File  P1120008.JPG   162.41K   16 downloads
Fitted some carpet recently, I didn't do a great job but the quality is great. From Johnnys Auto Carpets on eBay
Attached File  P1110989.JPG   161.19K   15 downloads
A Rare Spares venetian, I had wanted one for a long time and finally bought it
Attached File  P1110986.JPG   157.09K   14 downloads
And cut out the lower dash and fitted the stereo through, not wired but it fits in and deosn't interfere with the Vintage Air unit. The stereo doen't have a cd player so is much shorter depth.
Attached File  P1120010.JPG   145.95K   14 downloads
The car has been a bit too tall in the front since I fitted the King springs. I did check they were seated correctly and after speaking with Kings decided it was due to the lighter weight of the LS1. They could reset them for $100 plus freight or I could buy some six cylinder springs. The guy at Kings said it would drop the front about 20mm and I bought them, fitted them and it did drop the front 20mm. Looks a bit more normal now.
Wiring is the next priority, once it is done I can run the engine and test the instruments.
#84 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 26 March 2018 - 08:09 PM
Going to be a very clean car when all done. Well done so far,
#85 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 27 March 2018 - 06:21 AM
Your passenger looks keen for a ride.
#86 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 27 March 2018 - 05:34 PM
Thanks Gerry, I am very happy with it so far. Lookin g forward to driving it soon (6 months all going well)
Your right Steve, he is ready, always in the car or garage when I am working on it
Think I have some more pics/updates to post I haven't caught up on
#87 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 17 November 2018 - 06:51 PM
After coming across another topic about the CRS chassis kit and wheel clearance I cut some of the kit I have and now have better clearance at the front wheels, was the last job before taking the car for a wheel alignment.
Only 4km to my local alignment guy and RMS were reluctant but kind enough to give me another unregistered permit so I got to take it out briefly. While it was out the exhaust guy made me some under diff tail pipes and the car sounds great! Car got washed too while out of the garage, first time since it was painted in 2014.
Attached File  P1120538.JPG   153.19K   16 downloads
Attached File  P1120541.JPG   153.6K   15 downloads
Attached File  P1120542.JPG   152.25K   14 downloads
#88 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 17 November 2018 - 06:57 PM
Although I have thought 100 times before I was finished with the wiring behind the dash, today I think I am ACTUALLY close to  finished with it.
Dash is in and works correctly, I have a Dakota digital tach adapter and with the input set to 4 cylinders and the output 8 it reads correctly. Fitted the vintage air controls and ducts and tested just with fresh air and works well.
Attached File  P1120563.JPG   144.05K   15 downloads
Attached File  P1120565.JPG   155.61K   15 downloads
#89 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 17 November 2018 - 07:04 PM
That extra piece of ducting I am going to try and run through the console for the back seat passengers, don't want the dog getting too hot
#90 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 17 November 2018 - 07:05 PM
very good... always nice to be making progress forward... cant be long now till all done
#91 Heath
  • 18,385 posts
Posted 19 November 2018 - 01:31 PM
Nice progress.
#92 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 19 November 2018 - 07:17 PM
Looks great mate, congratulations.
#93 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 20 November 2018 - 07:56 PM
Thanks Gents,
Am very happy with the progress and just in the last few weeks a realizing I am very close to being able to take it for engineering.
I did have a minor setback, my wood grain glove box lid was quite warped and I tried to straighten it in the oven. It is now flatter but not a rectangle. I think I could make a new one if I could get a laminate or sticker made to match the wood grain
Will be looking for a replacement.
#94 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 22 November 2018 - 07:41 AM
A possible replacement? https://www.ebay.com...ItemCondition=4
Cheers, Steve.
#95 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 26 November 2018 - 06:01 PM
Thanks Steve,
Am waiting for the time to tick away
#96 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 03 December 2018 - 06:25 PM
Bought a dust cover for the bell housing and with a bit of cutting it fit,
Attached File  P1120591.JPG   169.48K   19 downloads
Attached File  P1120594.JPG   158.39K   20 downloads
Attached File  P1120596.JPG   155.64K   20 downloads
I had been trying to keep the glove box as a glove box but didn't like the options of where to mount the ECM so eventually gave in. Attached a bracket to the ECM cover and mounted it in the glove box
Attached File  P1120603.JPG   154.46K   18 downloads
Attached File  P1120606.JPG   153.57K   17 downloads
Next job is to make the console fit, my tunnel is taller because of the T56 so I have trimmed it and originally widened the console to try mount the ECM under it but am working on making it standard width again. It is an auto console so I will be making some sort of insert for the manual, don't want to buy a manual insert and have to mash it for the T56 shifter so will make one first to test
Attached File  P1120607.JPG   157.97K   17 downloads
#97 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 22 January 2019 - 01:42 PM
Had some success with the console fitment, any original console wasn't going to fit with the bigger tunnel to suit the T56 gearbox and I had 3 old consoles with different broken areas and managed to patch one up with a cut out piece from another.
I did my repairs with fiberglass on the inside and and made a hole at the front to run a duct to air con the back seat, hope I can get it through the metal frame mount as I install it. Also had to mount the VZ gear stick differently as it was too far of a reach so it is on a bit of angle bracket tilting it back closer to my hand and feels comfortable.
The insert around the gear stick is from an auto as it was all I had and fits pretty good with the modifications.
Piece from one of the other consoles glassed in
Attached File  P1120625.JPG   155.45K   16 downloads
Gear stick mounting bracket
Attached File  P1120618.JPG   147.59K   16 downloads
Plate to cover auto shift hole and attach boot
Attached File  P1120623.JPG   163.17K   17 downloads
How it looks now, square hole is where I am putting the rear demister switch. Now it's time to paint it.
Attached File  P1120633.JPG   155.09K   17 downloads
#98 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 22 January 2019 - 01:53 PM
sometimes it is all about customising and making do with what you have and getting it to your liking.. not someone elses.....(IKnow all about it )....   you have done well.. :clap:
#99 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 10 February 2019 - 07:02 PM
thanks Justin, i like it.
gave the console a coat of paint and put it in, even put a duct hose through it to run air con to the back seat, don't think it will be freezing back there but it will help
Attached File  P1120649.JPG   151.33K   15 downloads
Attached File  P1120652.JPG   154.31K   16 downloads
the vinyl paint in a spray can was easy to use and gives a great result.
another thing off the list
#100 Heath
  • 18,385 posts
Posted 10 February 2019 - 09:57 PM
Neat work mate.
