* * * * * 1 votes
Sunbird build thread
167 replies to this topic
#151 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 06 December 2024 - 05:39 AM
Is it just trial and error when you machine these or do you go by a given measurement?
They come with instructions, machine until zero clearance and then remove a small amount, I can't remember but think it was .25mm
#152 Heath
  • 18,401 posts
Posted 09 December 2024 - 02:59 PM
I would have thought less than 0.25mm, I think when I built my front hub stiffeners I possibly only gave them .004" of pre-load? Which is less than half of the above.
Did you find any difference driving the car with the stiffnered on those front stub axles?
Congratulations on the recent motorsport events. That one at Bathurst is so good!
#153 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 17 December 2024 - 10:26 AM
Could be my memory and was .025mm
Once I had zero tolerance it was a very small amount I took off, instructions did say bearings can wear in and might need to re-check in a few weeks and if necessary take some off back of bearing cup. Could also add a shim.
I did notice a difference on the street, thought the pedal stayed firmer longer, at MGCCN hill climb which is very tight I thought the pedal was low again but brakes still worked.
Bathurst hill climb was fantastic, only disappointed I didn't do it sooner.
#154 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 21 February 2025 - 07:14 PM
Went to the Optima street car at Calder last weekend, although the weather was not great for motorsport it was still a great fun weekend and I will go again next year.
Few small mods to the car before I left, after last years trip I wanted a foot rest, column mounted wiper switch and something to stop me pushing the clutch pedal too far.
I had a wipre switch indicator arm I had bought off eBay years ago, on the wiring connector it said 'Suits HX-HZ' and it was easy to fit with minimal effort. Had to cut out some room in the honey pot for the bigger shaft diameter, cut off some of the unnecessary second hi-beam switch and it went in without too uch fuss.
#155 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 21 February 2025 - 07:19 PM
Was great having the wier switch closer, it rained a lot on the way there and a lot on the track.
I recently fitted a foot rest and found it well worth it for such a long drive and also added a stop for the clutch pedal. It is an M8 sleeve nut or long nut screwed to the pedal under the rubber pad with a isolation mount screwed into it, worked well to stop me pushing the pedal too far when excited.
Attached File  IMG_7082.jpg   156.26K   4 downloads
Once again it was a great fun event, slightly less time on the track and it could have been due to the drift show which I guess is a crowd pleaser.
1960KM round trip for 184L car performed great!
Going to look more into handling upgrades for the future.
#156 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 22 February 2025 - 07:04 AM
I also replaced my instrument voltage regulator and lubed my speedo cable as last year the speedo was shaking widly above 130kmh and tacho seemed a bit ambitious.
Both worked, this year tacho was very stable and realistic and speedo cable didn't shake all the way to its stop at 200.
#157 Shiney005
  • 9,720 posts
Posted 23 February 2025 - 09:14 AM
What car is the foot rest from Tom?  It looks like a good fit.
#158 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 24 February 2025 - 07:45 PM
Laurie, its from a VT Commodore.
I had to make a bracket and the plastic got trimmed down at the base as it was too tall. Some pics on the previous page of the bracket.
It looks like its meant to be there
#159 SmacT
SmacT
  • 1,002 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 25 February 2025 - 08:43 AM
Good on you Tom, your car was on all the YouTube clips I saw. Shame about the rain, but looks awesome fun. Planning on joining the fun next year.
#160 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 22 May 2025 - 03:16 PM
I am currently working on fitting some Wilwoods to the rear end and trying to get some more clearance under the car so it can be a little lower.
Unfortunately the LS1 requires catalytic converters and they are big in diameter. While looking for clearance I checked my engine angle and it was about 6 degrees down at the rear, have been doing some reading and see that 3 degrees down might be the best, if I could achieve 3 degrees the angle change would help with exhaust clearance. Unfortunately getting the back of the engine higher puts the tailshaft uni joint too close to the floor at the extra support that runs across the car.
Its hard to see in the picture but there is a second layer of sheet metal that I guess is for strength.
How important is it?
Can I cut it and put in a bit of bent to fit sheet metal hard against the floor and maybe another on the top? I do have a CRS chassis kit and a tailshaft loop just behind the unis.
I could do with the extra clearance.
Attached File  IMG_8002.jpg   132.07K   2 downloads
#161 Shiney005
  • 9,720 posts
Posted 23 May 2025 - 10:18 AM
The big rib that gives the floor it's strength is slightly behind that area, and it's on the top of the floor pan. I'd reckon the one you are looking at was put in place by the factory in the event the tailshaft came adrift and tried to punch its way through the floor.  Seeing as you have the tailshaft loop I can't see why you couldn't cut it out. How much horsepower is going through the body?
Attached File  1975-holden-lh-torana-s-sedan 7.jpg   191.89K   5 downloads
#162 yel327
  • 13,718 posts
Posted 23 May 2025 - 11:48 AM
That's where your front and rear floors join across the member itself, and it also supports the front seats. Modifying it in a W body (HQ-WB) or H body (HD-HG) is a big deal and requires engineering. It'll cost  bit to do it just in engineering. Better off not lowering the car!
#163 claysummers
claysummers
  • 3,664 posts
  • Name:Clay
Posted 23 May 2025 - 01:23 PM
I think anywhere from 3 to 6 degrees is acceptable. On a carby engine, the angle between carb and driveline is generally around 5 degrees. Remember that you want a slight angle at the uni joints or they won’t rotate the needle rollers, resulting in premature failure. I also read somewhere that LS era pickups in the US were 6 degrees from factory.
#164 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 28 May 2025 - 06:23 PM
I spoke to the engineer and he said 5 would be acceptable but would prefer I try for 3 and its ok to remove the support thats in the way as my tailshaft loop will make up for it.
Engine, gearbox and k-frame are on the ground under the car for access,
Attached File  IMG_8021.jpg   109.64K   5 downloads
#165 rexy
rexy
  • 3,761 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 29 May 2025 - 09:39 AM
Can you make your engine mounts lower instead? Or have you run out of sump to crossmember clearance?
I have cats on the LS in my LJ and they are fairly compact. The lowest point on mine is the custom pipes…
#166 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 29 May 2025 - 06:34 PM
Laurie: that pic is very roomy, I am going to take the interior out on the weekend and have a look, If the main support is inside everything should be fine. Currently have 240kw at wheels.
Yel: I have spoke to the engineer, he is Torana experienced (has 2) and said I can proceed with removal as my tailshaft loop is 1/4".
Rexy: i have small hands and can just get my pinky finger under the sump, I might even need a few mm for this engineer so unfortunately that is why I am looking for room elsewhere.
My cats are about 4" diameter, would be interested in some more compact if they are still available. Got any pics or dimensions?
The hump I am likely to cut will only be cut on 1 front or rear edge and then I will flatten it and weld back to the floor, depending on what I find inside I might add something else there too.
#167 rexy
rexy
  • 3,761 posts
  • Name:Rexy
Posted 29 June 2025 - 04:47 PM
Finally got the LJ in the air.
Attached File  IMG_6541.jpeg   168.91K   2 downloads
Attached File  IMG_6542.jpeg   121.96K   2 downloads
Attached File  IMG_6544.jpeg   91.55K   1 downloads
Attached File  IMG_6545.jpeg   129.01K   2 downloads
These are 23 cm long, 17 cm wide and 10cm high. Fit unobtrusively under the car and flow well enough for the car to run 11.3 down the quarter with a relatively mild LS1.
Edited by rexy, 29 June 2025 - 04:51 PM.
#168 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 29 June 2025 - 05:44 PM
Thanks for the pics and dimensions Rexy,
There looks to be more room under the LJ than my LX.
I have been busy with work and then flu slowed me to a complete stop for the last week so I haven't got it back together.
Hoping to be back underneath next weekend to put it back together and see if I gained anything or have issues elsewhere.
I did remove the 12v reverse lockout solenoid and replaced it with a smaller spring loaded device, takes up much less room and getting rid of the 12v solenoid means I no longer need road speed signal to the ECM so I can also remove the electronic output device under the car that was inline with the speedo cable, its been annoying me for a long time so I'm glad its gone.
T56 TR6060 Billet Reverse Lockout Solenoid Delete T-56 TR-6060 - Michigan Motorsports
