Tail shaft date code.
Posted 03 May 2014 - 09:29 PM
I have two lj tail shafts,just like to know what the codes say.
Cheers Graham . image.jpg 194.4K 22 downloads image.jpg 222.35K 31 downloads
#2 _sunburst73-xu1_
Posted 16 May 2014 - 05:56 PM
Hi Graham
Been looking in to this of late myself and I'm little confused on why there are different date stampings(eg. some with letters and some without)
From what I have seen the ones that have just numbers are fairly easy to distinguish.
The pic below, this tail shaft came out of a 9th month 72 Adelaide built 4door that I wrecked.
35.2 would be 35th week of 1972
101_1726.JPG 174.35K 16 downloads
The other shafts that have letters I can only assume that the letter means the month of the year but could be wrong.
Who knows on why they had different formats, could be another Adelaide/Brissy thing.
I have other good examples of codes on tail shafts here, when I get a chance I post some more up.
cheers Dane
Edited by sunburst73-xu1, 16 May 2014 - 06:03 PM.
Posted 16 May 2014 - 10:32 PM
That's three tail shafts all with different style of codes.
Hopefully someone out there has some answers.
Great job on you're xu-1 Dane lovely car.
Cheers Graham .
Posted 18 May 2014 - 11:13 PM
torana lj specifications:for propeller shaft issued august 1971, revised august 1973.
#6 _sunburst73-xu1_
Posted 19 May 2014 - 07:54 AM
Thanks for the info Anthony, I wounder why some shafts got a letter code and some didn't?
For the LC/LJ at least I have seen more without then with.
Posted 19 May 2014 - 08:05 AM
Hi Dane
I think Anthony is saying the letter code denoting the propeller shaft's engine/transmission application was added to the date code around mid 1973?
Dave.
Edited by S pack, 19 May 2014 - 08:07 AM.
#8 _sunburst73-xu1_
Posted 19 May 2014 - 07:28 PM
Cheers Dave, early morning fuzz.
Got it now.
Posted 22 May 2014 - 12:12 AM
Mine has a E and my new old stock one is F.
Regards John.
Posted 21 May 2015 - 06:43 PM
JD
Posted 21 May 2015 - 07:07 PM
James,1972 is black stencil,1973 is yellow stencil being a gtr or xu1 must be a E,week and then year.
Posted 22 May 2015 - 12:47 PM
While on the subject would any have the tail shaft code for LC GTR 3/70
#13 _sunburst73-xu1_
Posted 22 May 2015 - 05:39 PM
James I will try and find the template I made to do mine tho obviously you may need different numbers.
Failing that I have a tail shaft here that has a perfect date code on it that I can send you some dimensions, just give me a few days.
cheers Dane
Posted 22 May 2015 - 06:21 PM
JD
Posted 30 May 2015 - 09:35 AM
I am no expert on the LC/LJ toranas. Are all of the tail shafts painted red? My friends LJ two door started its life as an automatic but at some stage a M20 went in. The tailshaft is red I will check the date codes on it today.
Phillip
