XU1 Retainer plate
Posted 12 May 2014 - 10:14 PM
PS were these only a 73 Bathurst thing or did other XU1s have them as well
Cheers Gene.
Oh its made by Dellow by the way
Posted 12 May 2014 - 10:22 PM
send us a picture Gene
Posted 12 May 2014 - 10:26 PM
Posted 12 May 2014 - 10:27 PM
http://www.ebay.com....=item3a687f9756
Edited by rodomo, 12 May 2014 - 10:28 PM.
Posted 12 May 2014 - 10:32 PM
Posted 12 May 2014 - 10:36 PM
yep what Rob said is correct .
bath 73 had the steel retainer plate same as dellow one not the alloy thick one on ebay ....
Gene watch the fan doesn,t hit the bolts when you put it on .
Posted 12 May 2014 - 10:39 PM
Posted 12 May 2014 - 10:42 PM
Posted 12 May 2014 - 10:45 PM
The billet retainer on ebay is what Dellow make now. They discontinued the pressed metal type many many moons ago.
Posted 12 May 2014 - 10:47 PM
Posted 12 May 2014 - 10:49 PM
in torrypowers picture what you see faces the radiator , you could grind down head of bolts by a mm or two Gene ,
From experience I would not go with out one of these plates on my holden 6 ...
Posted 12 May 2014 - 10:50 PM
Yep, hardly ever see one for sale.
Posted 12 May 2014 - 11:00 PM
Thanks once again shaun for the infoin torrypowers picture what you see faces the radiator , you could grind down head of bolts by a mm or two Gene ,
so does this mean i can spin the engine up to 7000 rpm lol
Posted 12 May 2014 - 11:01 PM
The earlier steel dellow retaining plate (same as Genes) was a very good copy of the ones gmh used on the 73 bath 150 engines , I have an original and is very very close but no dellow stamping .
7000 not a prob as long as the other bits are up to the job ! he he and have fun ...
Edited by WhiteA9XS, 12 May 2014 - 11:03 PM.
Posted 12 May 2014 - 11:19 PM
_boyrex_
Posted 12 May 2014 - 11:27 PM
Posted 12 May 2014 - 11:33 PM
There is a part number written on it Rob it looks like UM 2092 does that sound right
and thanks once again
Posted 12 May 2014 - 11:46 PM
The Dellow/NOS ones will stop it falling off forwards but they can also go backwards and machine the timing cover away.
http://www.gmh-toran...or-bust/page-10
Dellow catalogue circa mid 1980's lists part number HP1990.
Edited by S pack, 12 May 2014 - 11:48 PM.
Posted 12 May 2014 - 11:54 PM
#21
_boyrex_
Posted 12 May 2014 - 11:56 PM
#22
Posted 13 May 2014 - 12:01 AM
Happy days
#23
_boyrex_
#24
Posted 13 May 2014 - 12:09 AM
Hey S Pack, is your fan modified to clear the bolts?
Genuine 73 Bathurst engine fan.
#25
Posted 13 May 2014 - 12:12 AM
small in diametre
