XU1 Retainer plate
92 replies to this topic
#51 Ice
  • 15,199 posts
Posted 23 May 2014 - 09:57 PM
Yeah but not tonight CBF
Tomorrow some time
#52 N/A-PWR
  • 9,636 posts
Posted 23 May 2014 - 10:27 PM
Great Man Gene,
I am looking for the PCD on the net, man there is no info out there hey.
I may have to do it the hard way tomorrow too.
what you do is, screw a tight bolt into the harmonic ballancer that has a round/smooth shank on the bolt protruding the harmonic ballancer,
then we measure the shank thickness and divide it by two ( A1 write that down ),
then measure with a vernier from the shank to the outside of the ballancer ( A2 write that down ),
measure the outside diameter of the harmonic ballencer ( A3 and write that down ),
So the P.C.D. = A3 - (( A2 - A1 ) x 2 )
#53 N/A-PWR
  • 9,636 posts
Posted 23 May 2014 - 10:29 PM
we then look for the Nominal Imperial size closest to that outcome, Bingo
#54 rodomo
  • 18,037 posts
Posted 23 May 2014 - 11:56 PM
3/8 UNF is the bolt size.
#55 N/A-PWR
  • 9,636 posts
Posted 23 May 2014 - 11:59 PM
Thank's Rob
#56 N/A-PWR
  • 9,636 posts
Posted 24 May 2014 - 12:13 PM
Hi All,
Now I thought this was going to be easy to measure up and found that my Harmonic Ballancer drilled P.C.D. maybe different to others,
as mine is short of a nominal Fractional P.C.D. size by 0.6mm. Dave I
So my Guess is, the Holden Red 6 Harmonic Ballancer is 2 7/8" P.C.D.
anyone able to clarify this to be correct, or to be corrected?
Found this great Chart - http://www.marylandm...h/cvtchtfdm.htm
Edited by TORYPOWER, 24 May 2014 - 12:16 PM.
#57 _macdou_
_macdou_
Posted 27 May 2014 - 07:05 PM
Dave thanks very much for you hard work and detailed measurements of the retainer plate, much appreciated. Cheers
#58 N/A-PWR
  • 9,636 posts
Posted 27 May 2014 - 08:51 PM
No Worries Ken,
We are just waiting for Gene to give us a Weight,
otherwise I can do that in the next few days too. Dave I
#59 Ice
  • 15,199 posts
Posted 27 May 2014 - 08:58 PM
I hear ya Dave
#60 N/A-PWR
  • 9,636 posts
Posted 27 May 2014 - 09:05 PM
I will bring a Scale in tomorrow Gene
#61 Ice
  • 15,199 posts
Posted 27 May 2014 - 09:12 PM
Ive got scales Dave
#62 N/A-PWR
  • 9,636 posts
Posted 27 May 2014 - 09:18 PM
Ok
#63 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 04 October 2020 - 04:41 PM
Gday all, picked this retainer plate up today off evil bay..🤔 dont see them around much so, figured what the hell.
I did look onto the Dellow web page..
I understand the pressed steel plates are no longer produced...
But even the billet ones, there did not appear to be a current listing for them, the billet ones I was never interested in anyway..
#64 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 02 May 2022 - 11:27 AM
Refreshing this thread a little.
With the weight of a Dellow retainer plate.
Also, what colour were these painted back in the day? The colour of the balancer they were fitted to?
I have seen images of them Black or Chevy Orange.
#65 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 02 May 2022 - 11:41 AM
Chevy orange is for chevys, not Holden built engines. Rocket red is the GMH colour. I have a feeling that i know a guy who had an original 1 of those retainer plates in the past. I will ask & text you, if i find out an answer Jason.
#66 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 02 May 2022 - 12:27 PM
Thanks Gary.
Please correct me if wrong, on Holden Engine Reds, by colours - not specifically by years.
EH began as Holden Red,
then i though HR went to Rocket Red,
later red motors then went to chevy orange colour.
#67 claysummers
claysummers
  • 3,626 posts
  • Name:Clay
Posted 02 May 2022 - 01:41 PM
The EH were definitely a darker red, less yellow, more black in the mix.
#68 snuff1966
snuff1966
  • 186 posts
  • Car:LH G pack
Posted 02 May 2022 - 05:39 PM
Pretty sure Rocket Red went all the way through until VC Commodore, when the XT5 blue motors came out
#69 Indy Orange
Indy Orange
  • 2,931 posts
  • Name:Paul
Posted 02 May 2022 - 07:47 PM
That was called “special red” .HR had that browny red also.
#70 claysummers
claysummers
  • 3,626 posts
  • Name:Clay
Posted 02 May 2022 - 08:41 PM
So rocket red from the mighty HK on. KBS motor coater comes in rocket red.
#71 S pack
  • 15,717 posts
Posted 03 May 2022 - 11:20 PM
Holden Engine Red - EH, HD, HR exc X2 - Dulux spray enamel code 6268
Holden X2 Engine Red - Dulux spray enamel code 8929
Holden HK Rocket Red (used to end of red motor production) - Dulux spray enamel code 10890
Edited by S pack, 03 May 2022 - 11:22 PM.
#72 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 04 May 2022 - 05:19 AM
To the best of my knowledge these retainer plates were paint rocket red with the engine. I would assume that they were painted once fitted to the harmonic balancer and therefore the balancer was unpainted behind them but I'm only guessing with that statement thinking that from a production line point of view that would be the quickest way to do it.
#73 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 04 May 2022 - 07:39 AM
Hi Cheers all,
TBH, the rocket red i came to know by name was probably around the HD-HR (X2 engine red as dave quoted above 8929) era.
I honestly never heard of the HK rocket red,(probly had my head in the sand then).
Makes sense the retainer plate painted the balancer colour.
Anyways live n learn :)
Jaso.
#74 S pack
  • 15,717 posts
Posted 04 May 2022 - 08:08 AM
Jaso, in theory, if you had bought a spray can labelled as Rocket Red then you had bought Holden HK Rocket Red.
That said it is probable the colour may have varied slightly between manufacturers.
#75 Shiney005
  • 9,577 posts
  • Car:Toyota Mirai
Posted 04 May 2022 - 09:31 AM
So what colour was Holden X2 Engine Red? Is it closer to the old EH red or the Rocket red? (Which was still being used with VK in 1985)  I just had a quick google and it came up with a dozen different shades.
