Cleaning Inlet Manifold
9 replies to this topic
#1 rexy
rexy
  • 3,714 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 17 May 2014 - 05:43 PM
Anyone got any useful home based methods for returning a 30 year old aluminium intake to its former glory?
It's not too bad with some areas of white discolouration and a few rust stains on its background general grotty appearance.
Thanks.
#2 hanra
  • 10,934 posts
Posted 17 May 2014 - 05:51 PM
I media blasted mine then coated it in ACF-50. Took me a while to rinse all the media out of it!!!
C16EBE7D-F1F5-4EFF-AC76-529497E2B697_zps
Edited by hanra, 17 May 2014 - 05:53 PM.
#3 Ice
  • 15,188 posts
Posted 17 May 2014 - 05:56 PM
Ive been told to use carby cleaner i havnt used it as yet but its suppose to work
#4 _LS2 Hatch_
_LS2 Hatch_
Posted 17 May 2014 - 06:38 PM
To get rid of all grime one filth off Harley engines and my boat engine, I use Alluminium/mag wheel cleaner. Gets it looking pretty good every time.
Cheap and worth a go as a starter
#5 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 17 May 2014 - 07:06 PM
AS above post carby cleaner or give it a light blast and then maybe powder coat it
#6 _LS1 Hatch_
_LS1 Hatch_
Posted 18 May 2014 - 12:46 AM
I use etching wheel cleaner on them too if they are not too bad...(and pressure wash them off)...if not I just run them down to the local blaster for $20 and they look like new after that anyways. :)
#7 Monaroman
Monaroman
  • 47 posts
  • Name:Keith
  • Car:Monaro
Posted 18 May 2014 - 10:58 AM
Mag wheel cleaner, the acid based one, (not the stuff they sell in part stores they call mag wheel cleaner) will clean it as well as oven cleaner. Oven cleaner can be bought at the supermarket. Acid based mag wheel cleaner you can get at the factory chemical sellers.
Keith
#8 71xu1
71xu1
    Dave
  • 1,274 posts
  • Car:LC GTR XU1
Posted 18 May 2014 - 11:03 AM
Lacquer thinners also does quite a good job, media blasting will bring it up to wow.
Edited by 71xu1, 18 May 2014 - 11:05 AM.
#9 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 18 May 2014 - 08:39 PM
Bead blast and Accelagold, will help with corrosion in the future and is heaps better for not water marking and is cheap. Depends if you like the yellowish appearance.
#10 _LXSS350_
_LXSS350_
Posted 18 May 2014 - 09:48 PM
The aluminium is somewhat porous and on the V8 (as cast) certainly has some fluid/dust collection points that don't drain. Beadblasting really is the best way to bring it up and remove what is in-grained. I normally use a dremel / die grinders and a range of the small sanding discs to remove the more obnoxious casting lines and dags before throwing it in the beadblast cabinet. Depending on the look and originality needed - you can also use a clear powdercoat or colour (I have used aluminium or silver grey shades). The good thing with finishing in powdercoat of course is its heat resistant and makes the manifold far more resistant to staining.
But if its originality and a clean factory look then a blast every year or so takes a day and doesn't cost the earth.
Edited by LXSS350, 18 May 2014 - 09:49 PM.
